High Idle Switch????? - Diesel Forum - TheDieselStop.com
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
post #1 of 5 (permalink) Old 10-05-2007, 12:19 PM Thread Starter
What is the deal of the mod for a high idle switch? What does it do and why would you do it? Can it be done with the 2008 diesels?
thanks for any info you can provide
New Rig On Order - 2011 F350 Lariat CC - Black/2 Tone Diesel
Rig - 2008 F350 Lariat CC - Black - Medium Stone Interior - Diesel - TOTALLED
Towing - 2008 Jayco G2 29FBS
Head Unit- Alpine CDA-9887
Front Stage Amp - Alpine PDX-4.150
Sub Stage Amp - Alpine PDX-1.600
Front Stage - Boston Pro60's
Subs - (2) Boston G110-4
Sound Deadener - Dynamat Extreme
2008screw is offline
post #2 of 5 (permalink) Old 10-05-2007, 04:39 PM
Re: High Idle Switch?????
I'm not sure the exact procedure but it can be done they hooked mine up to the #4 upfitter switch. It works quite well. You need to be in park with E brake on and turn on the #4 switch, it holds your idle at 12-1300 RPM. Works great when it is -30 out, it keeps your temps up and the cab warm.
2008 F350 4X4 CC SB 6.4L Lariat White
2007 F350 4X4 CC SB 6.0L Lariat FX4 White
2006 F350 4X4 CC LB 6.0L Lariat FX4 White
Sold
To many 7.3L and 6.0L's to list
4MCNTRLS is offline
post #3 of 5 (permalink) Old 10-05-2007, 04:58 PM Thread Starter
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 4MCNTRLS</div><div class="ubbcode-body">Works great when it is -30 out, it keeps your temps up and the cab warm. </div></div>
So you would only need this mod in cold weather. Where I live in the middle of winter it only gets anywhere from 5 degrees celcius to -15 degrees celcius (that is 41 degree Fahrenheit to 5 degree Fahrenheit)
post #4 of 5 (permalink) Old 10-05-2007, 05:14 PM
having a high idle is good for multiple reasons..... its nice to have for jump starting people, charging batteries on my trailer, or if you are going to be idleing for a while..... it keeps the motor from diesel pooling. Plus you have 4 upfitter switches anyways...... why not use one for a free option that your truck has built into it?!?!
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ Black Interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Icon Lift Kit, Icon 2.5" Piggy-Back Shocks, KMC Beadlocks w/ 33" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Line-X, MotoBar, Gentex Temp/Direction Mirror, Baja Designs 22" Onx Pro Light Bar
RRose is offline
post #5 of 5 (permalink) Old 10-05-2007, 05:37 PM
Yes it can be done to the 08 trucks. Another pro to using the high idle is that the alternator will produce more current at higher rpms rather than at idle.
2008 F-250 Superduty Black Extended-cab Short-bed XLT
2006 F-150 King Ranch Dark Stone Crew-cab Short-bed
ff1809 is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
