I got a new 450 and i need to go faster than 85 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Closed Thread
Old 06-29-2009, 09:19 PM   #1 (permalink)
CaptinCrash's Avatar
whats the best programmers that eliminates the top speed for the 09 6.4s i also use it to tow horse and race cars almost 90% of the time
sorry about frequent miss spellings I'm severly dylexic
A true Desert Racer For life
1997 f250 4x4 ex.cab long bed 7.3l Scalzo Racing Chase 1
Airraid stage 2intake
Real Men Use The Green Pump
CaptinCrash is offline
Old 06-29-2009, 10:26 PM   #2 (permalink)
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
SCT, DiabloSport, among others....soooo many out there.....Superchips maybe? not sure if the last one has one for 6.4.
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 06-29-2009, 11:44 PM   #3 (permalink)
bugman's Avatar
My Photos: (18)
You might want to check out your gearing, I'm not sure if the 09's have the 4.88 but it could be the 4.33's. The truck may be just about toped out at 85mph. Also I doubt that your tires are rated to go much faster than that. The F450 was designed to drag a lot of weight around and not race.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 06-30-2009, 03:08 AM   #4 (permalink)
Jim
well i do both so i need some help here
Old 06-30-2009, 09:32 AM   #5 (permalink)
gypsybill's Avatar
My Photos: (13)
You might want to check the speed rating of the tires before you go too fast... the stock Conti's that come on the truck are speed range "N" or 87 mph. Just a thought...
Bill
2009 F450 Lariat 4X2, Sterling Grey over Black
ReTrax Tonneau, AirSafe 25k 5th Wheel Hitch
2010 DRV MS 36RSSB3
gypsybill is offline
Old 07-01-2009, 05:28 AM   #6 (permalink)
i no its not the gearing because in hitting the rev limiter and tires I'm covered i'm sponsored by good year So whats the best chip guys
Old 07-01-2009, 07:14 AM   #7 (permalink)
Mark Kovalsky's Avatar
Just wondering, do they cover wrecked tow vehicles and trailers due to blown tires? The tires on your truck are only rated to go up to 87 MPH. Above that they tend to come apart.
Mark
Mark Kovalsky is offline
Old 07-01-2009, 03:04 PM   #8 (permalink)
Banned
I was amused that he "needs" to go faster than 85.... I can only assume that he feels he will be late for his life altering accident...
Back when I was younger, I spent far too many nights scraping folks off the highway with a stick and a spoon....
Now? I occasionally help teach younger guys how to scrape people off the highway with a stick and a spoon.
If these guys want to create these tragedies, the least they could do is wait until it is convenient for the people that have to undo this crap.
GrampyJim is offline
Old 07-01-2009, 04:29 PM   #9 (permalink)
Dick Cutting's Avatar
My Photos: (27)
He's just looking to visit Crow-Bar Motel. The speed limit while towing in CA is 55.
No need to discuss operating illegally. Furthermore, it is in violation of the site's membership agreement.
Thread can be locked.
TheDieselStop.Com Moderator & Photo Editor
May '02 F-350 7.3L SC Lariat 4x4 Auto SRW LWB, Currently 2/2012 - 266K+ miles
June '97 F-350 7.3L Reg Cab XLT 4x4 Auto SRW, OEM Radio w/CD, Currently 2/2012 - >183K+ miles
Dick Cutting is offline
Old 07-02-2009, 09:35 AM   #10 (permalink)
If he has a sponsorship he could have a need for increased speed that isn't on a public roadway.
Spartan is what i would get if I had a desire to pitch my warranty.
LandShark-47 is offline
Old 07-03-2009, 11:54 PM   #11 (permalink)
Y thank you land shark for understanding my needs and yes goodyear would cover my stuff if a tire came apart but i trust they wont so ill ive heard is spartan anyone else have a suggestion thanks
Old 07-04-2009, 09:23 AM   #12 (permalink)
You need to add a vendor gear box to allow you to run at lower RPM. I drove an F450 a few weeks ago and the final rearend ratio was like 3:55 with the box engaged. It helped a lot in the Fuel mileage area.
To remove your speed limiter you will still need a programmer.
dfuser is offline
Old 07-05-2009, 04:25 AM   #13 (permalink)
what is that do u mean a gear venders
Old 07-05-2009, 08:24 AM   #14 (permalink)
It's an aftermarket overdrive that can be switced from direct drive to overdrive to further reduce the gearing of the vehicle. However, this setup can only be used when the truck is running in two wheel drive since it bolts onto the back of the transfer case and only provides an overdrive for the rear wheels. I don't see how it will help though, a speed limiter is a speed limiter and the computer knows how fast the wheels are spinning because it's it's an electronic signal from the vehicle speed sensor. Here is a link to the Ford section of Gear Vendor's website.
Gear Vendors Under/Overdrive Ford Truck-Car-Van 2-Wheel Drive 4-Speed and 5-Speed Automatics.
Hope this helps you.
ponyexpress94 is offline
Old 07-08-2009, 01:11 PM   #15 (permalink)
brock187's Avatar
Buy a Spartan Phalanx and don't look back
Buy a Spartan and don't look back. No trace of it in the computer, crazy horse power, and speed limiter delete. I have one on my 08' and I researched all of the tuners for almost a year before I made my mind up! No regrets yet! I have 35x13.00x20 Toyo Open Country's and was getting 13.4mpg pre Spartan, but now post Spartan, I'm getting 16.3mpg around town, and 18.2mpg hwy. PLUS, IT WILL LET YOU DO WHAT YOU WANT WITH YOUR TRUCK, AND NOT WHAT SOMEONE ELSE THINKS IS BEST FOR YOU!!!!!!
"UNBREAKABLE"
--2008-JOB3-F-250 Lariat-4x4-w/ 6.4 Liter Diesel --*Crew Cab-16lb Reese Fifth Wheel Hitch
*Spartan Phalanx Tuner w/ Dashdaq Controller w/
*75hp, 150hp, and 210hp Tunes.
*35x13.00x20 Toyo Open Country Tires
*10x20 Chrome Pasati Rims
brock187 is offline
Closed Thread
