Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading and adding aftermarket equipment to your 2008 Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 07-17-2008, 11:38 PM   #1 (permalink)
BooStJunKey's Avatar
Intake systems
I'm new to this forum, but I'm trying to decide on the best air intake or at least one that seems to have the best balance of reliability and performance. I've read about the AFE and the S&B and the pros and cons with each. I was reading diesel power and saw an add for Injen. I have used injen for other applications and they are great but has anyone tried this intake system or know how it stacks up to all the others out there. Also, do we have a consensus on what everybody seems to have the best success with now, from reading past threads it seems that S&B is a favorite. Thoughts?
BooStJunKey is offline
Old 07-18-2008, 12:00 AM   #2 (permalink)
HeMiSlAyEr's Avatar
My Photos: (5)
The best intake is the stock one. For perfomance and reliability it can't be beat. The only reason to get an aftermarket intake is if you have or have plans to get a larger turbo or injectors.
2005 F-350 Superduty Powerstroke 6.0L
Superlift 4" lift, Superlift SSR Shocks, Superlift Dual Stabilizers, Skyjacker 4 Inch Drop Pitman Arm, 20" KMC XD Series, MBRP 4" Dual Exhuast Turbo Back, MBRP 6" Dual Wall Tips, MBRP Muffler Delete, Volant Cold Air Intake, SkyJacker Extended Brakelines, Rancho Steering Shock Absorber, Edge Performance Platinum, Banks Performance Intercooler Kit, Recon Clear Cab Roof Lights / Clear Mirror Lenses / Illuminated Door Sills(Black), Fabtech Pre-Runner Bar, 5 in. Lights, Infinity Speakers, Lund Roof SunVisor, 13% tints, Custom Switch Box, Custom Subwoofer Box(No Middle Back Seat), JL W3 8" Subwoofers , Infinity Reference Amplifier, Battery Capacitor, Nitto Mud Grapplers 35 12.5 20, Mag-Hytec Rear Diff Cover
HeMiSlAyEr is offline
Old 07-18-2008, 10:53 AM   #3 (permalink)
i have to disagree, stock pulling a small load (9k) it will pull the filter minder in all the way pulling hills, with no load you get on it it will pull it in half way, that is alot fo restriction in the stock intake, switched to S&B and pulling larger loads (15k) up the same hills and the filter minder doesnt budge, plus getting alittle better MPG .4-.5 or so. so for these trucks S&B cant be beat IMO
08 F-250 Black FX4 Every option
SCT 158 HP TUNE DPF Delet
S&B Intake
RBP Exuast
Straight pipe from DP Back
8" Fabtech lift
38"15.5"20 baya claws on rockstars
Rize traction bars
rize duel stabilizer
fox res. racing shocks all corners
bigtruck311 is offline
Old 07-18-2008, 11:15 AM   #4 (permalink)
HeMiSlAyEr's Avatar
My Photos: (5)
oh ok ill give you that. I just dont know that because ive never have towed with a stock filter. of course everybody has their opinion.but if he does a search around the forum alot of people say the stock is pretty good.
Old 07-18-2008, 01:21 PM   #5 (permalink)
Stalwart's Avatar
You must have a pretty dirty filter! I just towed with a GCVW of 35,500 with my F450 and the filter minder didn't budge. I was at full throttle and 3000 rpm for several long hills and if that won't do it, I don't know what will. BTW, I'm at 19,000 miles on the stock air filter . . .
Stalwart is offline
Old 07-18-2008, 01:23 PM   #6 (permalink)
i have put on an S&B and have noticed the same results .5-.6 also pulling larger loads has been better,
i had showed the dealership the filter system at first service and they are now offering it as a add on when somone purchaces or brings thier truck in for service. has not thrown ANY codes as well.
Smoke
Smoke650 is offline
Old 07-18-2008, 03:56 PM   #7 (permalink)
so it sounds like the favorite of Aftermarket Intakes/filters is S&B...that's kinda what I thought.
Old 07-18-2008, 04:11 PM   #8 (permalink)
thecougar's Avatar
I must be missing something. How do you know if the filter minder is moving while you are driving? If you are pulling a load I would think you are in the cab rather than under the hood.
Does Edge Insight or similar display this info?
2008 F-250 6.4l Lariat SuperCab Long Box 4x4
thecougar is offline
Old 07-18-2008, 04:29 PM   #9 (permalink)
It is easy to watch the filter minder with optional under hood surveillance system. A good way to keep an eye on those horses. The Edge Insight does not offer any Insight for the filter minder, or any Insight on the price of diesel.
02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 843,784 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
04 Grand Marquis LS sure wish it had a BTS!
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95 Bus
92 Buick deuce and a quarter
HighwayPrisoner is offline
Old 07-18-2008, 06:13 PM   #10 (permalink)
Stalwart's Avatar
Wink
Because it locks into place, so you can check it visually, and you have to press a button to reset it . . . what use would it be if you had to watch it while pulling?
Stalwart is offline
Old 07-19-2008, 05:44 AM   #11 (permalink)
back on topic...has anyone tried the "injen" air intake systems for diesels? I would be curious to see how it stacks up against s&b and other favorites.
Old 07-31-2008, 01:58 PM   #12 (permalink)
DSTRBD's Avatar
People like to repeat what they read and take it as gospel. The stock intake is NOT as good as the S&B unit. You will notice quicker spool-up as well as a slight mileage gains. We have never had a code issue with the S&B unit either. It is our top seller and what I ran on my personal truck.
www.performancetruckproducts.com
888-497-3666
Got Questions? Chat LIVE On Our Site
DSTRBD is online now
Old 08-01-2008, 12:44 AM   #13 (permalink)
Since you're a fellow DWYER, I'm going to believe you....
Any chance you've got special deals running for a S&B intake for a '08 F250 PSD?
timid1 is offline
Old 08-11-2008, 06:08 PM   #14 (permalink)
Havent seen any comments on banks system. The add says 31% more air. I am thinking about the ram air by banks. Pulled my 14k 5th wheel from WV to CA, pulled some pretty big hills once into CA and filter minder never budged with stock filter(only 6k miles on truck). But thought about cold air intake to improve fuel economy. every little bit helps.
2008 F250SD. 4x4 CREW CAB. Firestone air bags. B&W goose neck hitch.
TIGIT101 is offline
Old 08-12-2008, 07:48 PM   #15 (permalink)
Has anyone tried a true flow XDI filter (True Flow XDI Air Intake System #20710)? Their product looks pretty good and would seem to pull a lot more air, plus the airbox is powercoated which I would think is more condusive to keeping the heat out. Have any of you guys had any experience with an intake kit like that?
