By-pass oil filter - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 10-01-2007, 09:31 PM   #1 (permalink)
By-pass oil filter
I am considering adding a by-pass filter for the engine and was wondering which one would be best for the 6.4 application? I found a-lot of info on the oilguard filter and seen an ad about the Amsoil system. They both seem to claim that they are the best. Does anyone have an real knowledge about these systems, or are there others that may be better? Thanks.
2008 F-350 4X4
RNGMSTR is offline
Old 10-02-2007, 08:38 PM   #2 (permalink)
Re: By-pass oil filter
anyone?
2008 F-350 4X4
RNGMSTR is offline
Old 10-02-2007, 08:43 PM   #3 (permalink)
Banned
I have a Amsoil kit.I use the largest filter available which is 10 " long.Works fine for me.I mounted the filter on the frame rail.
sicaj is offline
Old 10-02-2007, 10:31 PM   #4 (permalink)
Any idea as to how the Amsoil filter compares to the oilguard or any others that may be available?
2008 F-350 4X4
RNGMSTR is offline
Old 10-05-2007, 11:30 PM   #5 (permalink)
guardrail22's Avatar
Amsoil
see album
won't go under hood on the 6.4
New Truck
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver, 2010 NAV and Sync
____________________
2008 Carrilite XTRM5
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch,
Delivered 11/27/2002
towing a 2005 Pilgrim 306RL-SS w/Hensly Arrow
guardrail22 is offline
Old 10-09-2007, 04:02 PM   #6 (permalink)
any reason it couldn't be mounted someplace right on the frame?
2008 F-350 4X4
RNGMSTR is offline
Old 10-09-2007, 10:07 PM   #7 (permalink)
done all the time. buy extra hose
New Truck
Traded In Nov 07:
Old 10-10-2007, 07:48 AM   #8 (permalink)
Go to Amsoil.com and look at the information online. They
will show you all the different kits and typical installation
for your truck. One peice of advice. If you are going to
run an Amsoil bypass filter, run the oil, EaO-88 oil filter
along with the Bypass filter. That way you will be getting
your money's worth. Running the bypass with conventional oil
will not gain you anything. I got over 100,000 miles on my
7.3 running Amsoil. You will need to use the new 5W-40 Amsoil
Diesel oil for your new truck.
2002F250 <font color="red"> RED </font>Lariat, CC, 7.3L PSD, AMSOIL 5W-30HDD, Amsoil ATF, Rear Differential, Dual-Bypass Oil Filter, DI Prepump & Tank Mod, DI H/X Mod, DI Fuel Regualtor, New DI Four Positon Chip, Autometer Phantom 3-Pillar, 30 micron Dahl100 filter, AIS Air Filter, Magnaflow XL 4" turbo back exhaust w/ 5" tip, Baldwin Coolant Filter, Magnifine Trans Filter, Racor CCV4500, Sonnax Accumulator Valve/Tricumulator Spring, ISSPRO Turbo Temp Monitor, Optima Yellow Tops, V10 Trans Cooler, AirLift Air Bags,B20 Biodiesel.
Performance by Diesel Innovations
Snow White Supporter
2002BigRed is offline
Old 10-10-2007, 04:06 PM   #9 (permalink)
Banned
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 2002BigRed</div><div class="ubbcode-body">Go to Amsoil.com and look at the information online. They
Diesel oil for your new truck. </div></div>You don't need to use Amsoil if you don't want to.Also you can still save money if you use conventional oil filter with bypass system!Use your own judgement.Over 100,000 miles on A 7.3L with [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img] conventional oil is no big accomplishment!
sicaj is offline
Old 10-11-2007, 12:01 AM   #10 (permalink)
thank you all for your replys, but does anyone have a real world comparisan as to which is the better by-pass system? Amsoil, Oil-guard, or others???
2008 F-350 4X4
RNGMSTR is offline
Old 10-11-2007, 10:13 AM   #11 (permalink)
Banned
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ddave</div><div class="ubbcode-body">thank you all for your replys, but does anyone have a real world comparisan as to which is the better by-pass system? Amsoil, Oil-guard, or others??? </div></div>I guess the answers you are recieving are not good enough.Call the manufacturer of each kit and ask them!It's not like you are spending $5,000 on a kit,they only cost a few hundred dollars [img]/forums/images/%%GRAEMLIN_URL%%/confused.gif[/img]
sicaj is offline
Old 10-11-2007, 04:08 PM   #12 (permalink)
already called both manufactures (read first post) They both claim to have the better product. I was wondering if anyone had experiance in the real world with the each product and there thoughts, Not just what a salesperson that is obviousley going to push there product has to say. Dosen't matter if both kits were $5, I would still prefer to have the better of the two.
2008 F-350 4X4
RNGMSTR is offline
Old 10-12-2007, 04:47 PM   #13 (permalink)
Stalwart's Avatar
If you buy Amsoil you have to join their cult . . . [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
Stalwart is offline
Old 10-12-2007, 05:37 PM   #14 (permalink)
I run the fs2500 and I love it from filtrations solution
onebadf150 is offline
Old 11-11-2007, 11:26 AM   #15 (permalink)
I prefer the FS2500. My 4X4 has 690,000 miles, the FS2500 was installed at 4,000 miles. The 4X2 has 214,000 miles, the previous Cummins ISC had 300,000 when I sold it. The total miles 1,200,000 FS2500 equipped without any problems or concerns. The PSD trannys have FS2500 filtration.
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95 Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
HighwayPrisoner is offline
