By-pass oil filter - Page 3 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 12-02-2007, 12:35 PM   #31 (permalink)
Re: By-pass oil filter
Installed mine last night. Best location I could figure was horizontally on the reinforcement on the underside of the body behind the R/F wheel well splash guard. Keeps it tucked in for protection and the lines as short as possible. There just isn't any room for ANYTHING on these trucks.
Stealth03TDI is offline
Old 12-12-2007, 09:25 PM   #32 (permalink)
truck now has just over 1100 miles on it and the oil is only a shade darker than brand new oil!
2008 F-350 4X4
RNGMSTR is offline
Old 12-18-2007, 06:16 PM   #33 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: pepsi</div><div class="ubbcode-body">Mounted mine right behind the the front licence plate. The filter is on it's side but it only makes a mess every second oil change. It's in an easy place to spray a little varsol. Oil line routing was easy as well. I took off the licence bracket to drill the holes. Needed to use an air drill as the space is a little cramped. Once you had the holes started you could drill from the bottom with more room. Hardest part of the job was finding where to put it, once that's done it's easy going. The other hard part is seeing your oil on the dip stick. Takes about a week to get some colour in it for an accurate level check! Cheers GT </div></div>
do you have any pics ??
onebadf150 is offline
Old 12-19-2007, 10:39 AM   #34 (permalink)
More Trivia:
Just to compare theirs to other filter companies, I talked to AMSOL tech support yesterday. He stated their bypass filters are rated at 5 microns.
Old 12-24-2007, 09:41 AM   #35 (permalink)
Ray324's Avatar
don't know why they would say that, it says 2 micron in the filter it self.
right from there web sight. https://www.amsoil.com/storefront/bf.aspx
Higher Efficiency
AMSOIL EaBP Filters have an efficiency of 98.7 percent at two microns. At normal operating RPMs the EaBP Filter will filter all of the oil in a typical five quart sump in less than 10 minutes.
2011 F350 Lariat 4x4 FX4 DRW Super Cab. 5th wheel hitch prep. Reese 25K hitch. Rhino Liner.
2010 Jayco Recon 40D Toy Hauler
2009 Victory Vision.
Retired U.S. Army
Panama
SW Asia
Somalia
Blackhawk Helicopter Mechanic.
Ray324 is offline
Old 12-25-2007, 12:35 PM   #36 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ray324</div><div class="ubbcode-body">don't know why they would say that, it says 2 micron in the filter it self.
Higher Efficiency
</div></div>
Amsoil is giving the nominal figures not absolute. The Amsoil elements are only approx. 67% efficient at trapping anything under 10 microns. I had there dual remote with a eao-26/eabp110 on my 7.3L and was not all that impressed with there stuff.
2008 F-350 4X4
RNGMSTR is offline
Old 12-25-2007, 10:01 PM   #37 (permalink)
Ray324's Avatar
point me to where you got this data????? I am always looking for better stuff.
Again on the filter it says 2 micron.
explain the difference between absolute and not....
Retired U.S. Army
Panama
SW Asia
Somalia
Ray324 is offline
Old 12-28-2007, 12:07 PM   #38 (permalink)
Do a search on the internet. There are independent labs doing the research, just look for one that has tested whatever filter you are interested in.
2008 F-350 4X4
RNGMSTR is offline
Old 09-26-2008, 09:53 PM   #39 (permalink)
jerzydiver's Avatar
Any one interested in a deal for the AMSOIL BYPASS SYSTEM???
BMK11 mount kit
EAP 110 ea filter (large filter)
bk 1102 all oil filler cap
bk 1101 all oil filter cap
2 bp 242 90 degree elbows for oil caps
Complete kit ready to install 400.00 delivered to your door. pm me if interested!.
Thanks Dennis
Rhino Kustoms LLC
AMSOIL - Synthetic Oil, Motor and Engine Oil, Lubricants, Air Filters and Oil Filters
Rhinokustoms@comcast.net
06 F350 XLT Crew Cab LWB FX4, power Captain Chairs / Snow Plow Packsage camper package / tow command / Amsoil oil bypass filter/ Billet Badges / A Pillar Quad gauges / overhead quad gauges / ExtremeAir compressor / Trian Air Horns / FX4 package / High Idle/Aux switch mod / Go Rino Push Bar / Go Rhino Rear hitch step / Hella Black Magic Driving Lights / Rhino Lining bed liner./ MRBP Cool Duals / KC 6x9 Long Range lights mounted to Third Brake Light / Pro Comp 305 x70 R18 Xtreme Mud Terrians</p>
jerzydiver is offline
Old 10-14-2008, 12:52 PM   #40 (permalink)
With over 29K on my truck, is it too late to get this kit? I will not have the cash to do so until after the first of the year, and by that time I will be close to 35K on her. I change my oil between 5K and 8K, and use Motorcraft filters. I am all about adding options, but this will have to wait a few months if it is not too late. Thoughts?
Michael
2008 F350 XLT, SC, LWB, SRW. 6.4 L. 4x4. 6 spd. Job 1. 32,000 miles. GONE
2009 VW Jetta Sedan, 2.0L TDI, 6spd, Silver, Protection Pkg.
2004 Explorer XLT, Silver, 4.0L, 4x4, STOCK
CMB430 is offline
Old 10-14-2008, 04:33 PM   #41 (permalink)
jerzydiver's Avatar
It would not be too late to install. It will still help in the long run increase engine life.
Old 10-16-2008, 09:42 AM   #42 (permalink)
Is there anything to be gained by changing the factory oil filter out half way through a use cycle. For instance, if I am going to change my oil at 7,000 miles, would it accomplish anywhere near the same level of clean as a by-pass if I changed the factory filter at 3,500 miles? I know it will not hurt anything, but how much do I stand to gain?
Michael
CMB430 is offline
Old 10-18-2008, 10:43 PM   #43 (permalink)
Did we decide where to best mount the FS25000???? For some reason I have a hard time with a horizontal mount. It doesn't seem 'right'! But if we have some success, I'm game......
PagosaRob is offline
Old 10-19-2008, 12:18 AM   #44 (permalink)
Since the system is under pressure, it really doesn't matter how its mounted, other than its a mess to change filter elememnts.
OMC
OMCUSNR is offline
Old 10-24-2008, 02:13 PM   #45 (permalink)
Boating_fool's Avatar
I am considering a Bypass Oil filter. Has anyone at any time on any diesel engine, had a warranty claim denied or service dept trouble due to a bypass oil filter? It seems like it would be an easy target to a service manager to blame engine problems on.
I have found one place the FS2500 is sold online for $719, are there any other places?
Vincent
Vincent
Greencastle PA (Unfortunately)
2008 F250 CC SWB King Ranch 4x4 6.4
Boating_fool is offline
