plug and play turbo timer - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 10-21-2009, 07:08 AM   #1 (permalink)
Does anyone make a plug and play turbo timer for the 6.4? I really don't want to drill and tap a manifold if I came find a plug and play unit.
GWRRA member
NRA Life member
2009 F350 CC XLT, 4x4, LB, PSD, dually ESOF, Towboss,Highway Products 5er box, Ultimate liner, Viair 450C air compressor and 2.5 gal air tank, 2008 Honda 1800 2008 CSC trike conversion,2008 KZ Sportsmen Sporster 35PX2 , 2009 Cargo Craft 7x 14 enclosed trailer,1998 Lance Legend 500 truck camper
chickie is offline
Old 10-21-2009, 02:55 PM   #2 (permalink)
Yes, take a look at dieselsite
2008 F-350 King Ranch 4X4, job build 3, tuned by Spartan
RIP: 95 F-350 Powerstroke, 4X4, 5 Spd, Crew Cab,Long Bed, 4" Superlift on 35" BFG All-Terrain, Diesel Innovations 4 Bank chip, 4" exhaust, DIY Tymar, Ranch Hand repalcement bumpers
2004.5 Cummins 600, 2500 Larimie, 4X4, LWB, 48RE, Full billet DTT, FASS fuel system, TST, SMARTY, Flux 3 injectors, Helix cam, Di-Procol (Boost, EGT, Trans, Rail, Fuel), AFE PG7 stage 1, JL Stealth box, Donaldson, 315 BFGs. (893 on fuel )
2005 Chevy 2500 Duramax, Diablo tuner, PYRO.
powerstrokin03 is offline
Old 10-21-2009, 03:21 PM   #3 (permalink)
SFC1984's Avatar
I was wondering about this. My solution was to use the remote start. You can press the RS button with the truck on and turn the key to remove it while the engine still runs. I can then go about my business and either turn the engine off myself with the RS button or just let it shut down on it's own with the engine idle shutdown on the RS, which I think will shut the truck off after 10 mins of sitting.
SFC1984 is offline
Old 10-22-2009, 08:15 AM   #4 (permalink)
LTFFNREMTP's Avatar
I have a Striker TT turbo timer from Painless performance on my 7.3. They do not have instructions in their manual for installing it on a 6.4, but i'm sure with a test light you could easily find your connections. This timer has settings for 0,1,2,3,4, and 5 minutes, with a 55 minute option. Each time it defaults to the previous setting of 0-5 minutes, and 55 minute is on demand each time.
Pretty simple hookup. Break sense wire, hot "in" wire, hot "out" wire, key on wire, ground and then a wire for accessories. (I have my AC as my accessory) Comes with everything needed, including T-taps and zip ties. No drilling or cutting wires.
I'm sure somebody could chime in and give you what wires you would hook to.
'99 F250 CC-SB 4x4, AFE Stage 2 intake with Pro-Guard 7, Dieselsite coolant filter, DiPricol Full gauges, AIC, On board air + Buell emergency series air horns, Striker turbo timer, Striker I module, Cyclops anti-theft module, TC lockup and 6.0 trans cooler. Powerslot Cryro'd rotors and Hawk LTS pads.
LTFFNREMTP is offline
Old 10-22-2009, 06:28 PM   #5 (permalink)
The diesel site module is all plug and play no splicing of any kind
Old 10-22-2009, 08:10 PM   #6 (permalink)
I have used the TLS on my 2002 since 03 without problem. It is a plug/play with only holes needed for a momentary switch and a off/on switch. It can be set in increments of 1 thru 10 minutes or up to four hours. Time is set with momentary switch and off/on switch then set and key removed from iginition. Engine can not be started with key until switch is turned on (hidden). It can also be used to pump up oil pressure prior to starting engine. An accessory jit was available allowing you to use the emgerency brake to activate also but after installing felt it was a waste of money
Fordpowerstroke350 is offline
