Roush Cold Air Intake for 6.4 litre diesel - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 03-30-2009, 12:50 PM   #1 (permalink)
black08's Avatar
First time posting. I am currently testing a Roush cold air intake ststem on my 6.4 litre and was wondering if anyone else has one on their truck? My truck is a 2008 F-450 4x4 4.30 rear with 26000 miles on it. I haven't had it in long enough to see any big fuel economy results ( over a few tanks, hand calculated ) but one big difference is the response of the throttle. Way better off the line and in the mid range as well. There is a noise difference with it on there though especially during a regen. Anyone else with this kit?
black08 is offline
Old 03-30-2009, 03:00 PM   #2 (permalink)
Its the same thing as the AirAid. You're likely to find more folks with it.
rvBrad is offline
Old 04-07-2009, 11:12 PM   #3 (permalink)
black08's Avatar
First full tank of fuel I got 14.2 MPG (Canadian) hand calculated. This is an improvement from 12.5 to 13.2 but the biggest improvement is the response off the line and on acceleration in the mid power range. I am not going to jump to any conclusions until I have run a few tanks of fuel through with it in.
2011 F-350 4X4 DRW Lariat Black, Black Interior, Loaded except sunroof and nav.
2008 F-450 4X4 XLT Dark Blue Pearl, Stone Interior
Job 1, 4.30 Rear. Stock except for a set of 245-70-19.5 Bridgestones and a Roush Cold Air Intake.
black08 is offline
Old 04-07-2009, 11:51 PM   #4 (permalink)
burnetma's Avatar
I will be watching for updates.
FYI, I am averaging only 11.4 MPG.
2008 F350 FX4 Crew, 4x4, 6.4L, Torqueshift, 4.30, tow command, leather, power everything. 75k+ miles. Built 4/17/2007 (Job 1), Purchased used 3/16/2009
2010 Mustang GT Premium - 4.6L-3V, 5 Speed, Grabber Blue - Now this is FUN!
1997 F250 EXT Cab, 4x4, E4OD, 4.10, 273k+ miles.
Modifications: Pyro & boost guage, 202 T-stat, transmission cooler & Tymar - SOLD!!!!!!!
2004 John Deere 5420 MFWD Utility Tractor with 541 MSL Loader.
burnetma is offline
Old 04-13-2009, 11:44 PM   #5 (permalink)
black08's Avatar
Second full tank hand calculated was 13.2 MPG. I am still impressed with the improved performance. If you are looking for a big increase in fuel economy alone, so far I would say it might not be worth it. I will continue to keep track and report.
black08 is offline
Old 04-14-2009, 04:48 PM   #6 (permalink)
burnetma's Avatar
How is the quality of the unit? Does it seem like a $334 part?
burnetma is offline
Old 04-17-2009, 04:45 PM   #7 (permalink)
black08's Avatar
It looks just like the air raid unit. I am on the fence as to whether or not it is worth that kind of money. I am testing this one for a dealership so I don't even know what they want for it.
black08 is offline
Old 04-30-2009, 12:16 AM   #8 (permalink)
black08's Avatar
Third tank came in at 14.5 mpg. The dealership changed my MAF sensor to try to cut down on the excessive regens, every 150 to 170 Km ( 90 to 110 miles ) when not towing and every 74 Km ( 46 miles ) when towing. I haven't towed since it was installed but when not towing it has made a difference.
black08 is offline
Old 05-04-2009, 11:54 PM   #9 (permalink)
black08's Avatar
MAF sensor made no difference to the regen cycles. Tank # 4 came in @ 14.4 MPG
black08 is offline
Old 11-17-2009, 01:53 PM   #10 (permalink)
I have just bought the cold air intake and just after leaving the shop the check engine light came on. I call Roush and they say if you reset the code reading up to three time the error will correct itself. Well I have don it five times now and still the same code appears.
Any ideas?? Ford F350 6.4 2008
Howard91167 is offline
Old 11-19-2009, 01:37 AM   #11 (permalink)
BeatMarti's Avatar
It would be useful to know what codes are causing the check-engine light to come on. You may have a different problem aggravated by the new intake.
I have a K&N on mine (F550 Job 1 50K miles) for about 10K so far. No problems, installed easy and is said to not cause codes - and it did not. I like the slightly increased turbo whine. With 30 to 35 lb of boost pressure one can actually hear the air suction noise...:-)
BeatMarti is offline
Old 11-19-2009, 07:23 AM   #12 (permalink)
Evo B's Avatar
I've been waiting to hear some reports on this intake as I've been wanting to buy it, but dont want the headache's that some others have with the check engine light comming on. Wonder if some dealerships would not frown apon this intake simply because it's roush?
Evo B is offline
