S&B Intake = Check engine & wrench - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 03-01-2009, 10:26 PM   #1 (permalink)
Hey guys, I have a job 1 F-250. At 24,000 miles I finally did the new computer flash and after a few hundred miles I did my first modification. I put the S&B intake on and everything was perfect for about 500 miles. Today after lunch I went out and started the truck and I had a wrench in my display and a check engine light. After about 10 seconds at idle the wrench went away but the check engine light remains. The truck runs fine but that wrench thing is kind of scaring me. Is this normal with my intake or not? I went with S&B because I didn't think they were supposed to trigger the light. I don't have a programmer or anything to pull the codes.
Josh
smashedheadcat is offline
Old 03-02-2009, 12:37 PM   #2 (permalink)
It probably has a P0401. Take it to a dealer with the intake installed. Don't take it off and take it in. The tech working on it will run around in circles trying to verify the concern or throw parts on it that it dosen't need.
I'm a mod friendly Ford Diesel Technician located in Sacramento California area.
Gofaster23 is offline
Old 03-02-2009, 04:53 PM   #3 (permalink)
Send a message via AIM to PSD POWER007
FWIW, I've never had a problem with my S&B intake. Been running it for almost 50k miles.
Also, you need to have the code read so you can determine if it is even an intake related issue. It could be ANYTHING...
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke
Banks CAI, Magnaflow Turbo Back exhaust, Innovative Diesel custom tuned Livewire, Bilstein shocks, 05+ Harley headlights with HID conversion
2008 Subaru WRX STI
305whp/369wtq
PSD POWER007 is offline
Old 03-02-2009, 06:59 PM   #4 (permalink)
Lightbulb
i would be interested in the code also, from what I have read the P2002 is a good possibility. This is due to the DPF learning the Delta of air flow thru it in the first 3k miles. After that, if you change the air intake you upset the delta and the DPF realizes that more air is flowing thru it. I think if you were to put it on when the truck waqs brand new, it would learn the flow correctly.
2008 F-450 Lariat loaded on order 7/3/07 delivered 9/13/2007 Pueblo Gold and all the goodies except Nav radio and moonroof and Fisher 8'6" X-blade
2005
F-350 Lariat LOADED CC SRW LB 6.0 SOLD
Med. Wedgewood Blue
All Options except moon roof
8'6" Fisher X-blade SS
2003 PSD 6.0 Lariat CC SB SOLD
All options but the moon roof
Scottb NY is offline
Old 03-02-2009, 07:08 PM   #5 (permalink)
Thanks for the response guys. This morning when I went to work the CEL was on (no wrench). When I went to lunch, the light was off and it is off now. I'm curious to what it could be but heck, as long as it's gone I'm not too concerned. If it comes back, take it to the dealer with the intake still on is the recommendation? Thanks again!
Old 03-03-2009, 05:08 PM   #6 (permalink)
Unless you know the dealer real well, DO NOT take it to the dealer with the CAI on. They can void the warranty (don't know if they will, but they can). Job1 trucks are touchy when it comes to the air intake. I've played with two different Afe's and the S&B and it would throw codes on all three. Usually it was the P2002. After a while the light would go off but I could tell truck wasn't running as well (coulda been in my head). When I cleared the code, light would go off and truck would run fine for about another 500 miles then the light would come back on and same thing. Some Job1 trucks are fine, others are not.
ljstoy is offline
Old 03-03-2009, 05:20 PM   #7 (permalink)
I had the same issue with my afe. Except the latest reflash has been good so far. I own a job 1 truck. The kit was good until I took it in for service and then the CEL started happening. Well the latest reflash I now have 3k miles on the afe with no issues whatsoever. A friend of mine bragged about his s&b kit and that it didnt throw codes. Well after the latest reflash he started having issues. Who is laughing now.
bajzashop is offline
Old 03-04-2009, 06:59 PM   #8 (permalink)
The light is off now, I just put 100 miles on it or so and it hasn't come back. The truck seems to run normal, always has.
Off subject but I thought these intakes were supposed to make the turbos louder. The only time I hear it is when I've got my foot almost to the floor with it in 2nd or 3rd gear, and it only sounds like a dog whistle at best.
Josh
2011 F-450
2003 Cobra
HP Twin 50mm Turbos
PA 4r70w Auto
Built Solid Axle
Old 03-04-2009, 09:10 PM   #9 (permalink)
2008GoldThunder's Avatar
My aFe intake was throwing the P2002 code every 400 miles and would extinguish after 200 miles. My truck is a Job 2 and I had the reflash [CSP 08B07] done in January 2009. As a result, I did not get the customary CEL after 400 miles. After 800 miles, I re-installed my updated SCT with latest Firmware & Tune Revision, which also allowed for aftermarket CAI selection [a change from the previous software version]. I have had no CEL's with over 1,000 miles since last illumination. Seems like either Ford's reflash or updated SCT software has resolved my issue!
BTW, aFe has a sweet spool up sound similar to a Learjet starting up. I have heard other owners report S&B intakes as being somewhat quieter during spool up in comparison.
2008 F-250 XLT CC LB 4X4 6.4L PSD Job 2 Pueblo Gold [BFG 305/65R18 T/A KO Tires, 2.5" Ready Lift, Rize Industries Dual Steering Stabilizer Kit w/ Bilstein 5100 Series Monotubes, Roadmaster Rear Suspension, Hellwig RSB, Bilstein BST HD Shocks, Firestone Ride-Rite Heavy Duty Air Helper Springs, Air Lift Wireless Air 72000 - Automatic Leveling Digital On-Board Compressor System, Aries SS Bull Bar, Line-X Bed Liner, A.R.E Bed Lid, Valley Class V Hitch, AFE Pro Dry Stage II Type Cx Intake w/Torque Boost Tube, MBRP SS Exhaust System, SCT Livewire Extreme Programmer, SecureView Rearview Mirror / Backup Camera / Video Display System (4.5" screen), EGR Bug Guard Hood Protector, Husky Mud Guards & Floor Mats, AVS Smoked Vent Shades]
2008GoldThunder is offline
Old 03-04-2009, 09:34 PM   #10 (permalink)
TreverAdamo's Avatar
exactly what i have been saying from the time i got mine but if close off the open side of the intake you will hear teh turbos a little better driveing on the street because you have less of that wooosh i sound it makes!
08 250FX4 SB CC
6.4 silver
job 1
picked up 4/1/07
TreverAdamo is offline
Old 03-06-2009, 12:18 AM   #11 (permalink)
i never had the issue like that - my s&b never threw a code - however, i noticed after time that my mileage was worse with the intake than with the stocker, and that my regens were way whacked out compared to how the truck went through a regen and how often it did.
2005 gto black/black - sold.............
2008 gl550 silver/black
2008 f250 cc fx4 silver & gray/black
z71burb is offline
Old 03-15-2009, 08:12 PM   #12 (permalink)
Update: Check engine light still hasn't come back however the wrench has come back twice. It happens on start up and seems to go away after the first 30 seconds of driving or so. The truck appears to run completely normal with the wrench there. Anyway, 30 seconds or so, and it's gone. I just drove to the dunes the weekend and pulled a trailer (about 6000 lbs) 165 miles or so each way. No wrenches.
Josh
2011 F-450
2003 Cobra
HP Twin 50mm Turbos
PA 4r70w Auto
Built Solid Axle
