6.4L Upgrades and Aftermarket - EngineUpgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
spartan set the alarm on my dashdaq at 1600, so i'd say anything above that for extended periods is bad
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE Try the SEARCH Button Because It's Probably already been asked
mine routinely sees 1300 towing 18000 pounds and I beleive Ford defuels the engine at 1350.
My rig is typically 17,000 lb. Driving mountain passes I've seen temps easily reach 1400. I use an Edge Evolution on setting #1 (economy) and I set the alarm to 1500. I've never hit the alarm as the defueling safety program kicks in between 1400 and 1430. When that happens, the temp will drop down to the high 1200 for a little while (about 30 seconds), then it will start raising again.
If a regen happened shortly prior to such full power climbing, the temperatures remain a bit lower (since they relate to exhaust backpressure AND EGR activities). But, in general, I ease off the gas pedal a bit when the temps are approaching the high 1300 to prevent the safety defueling to kick in.
