SEIC and Upfitter Switch - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 11-25-2007, 01:18 AM   #1 (permalink)
Does it matter which upfitter switch you hook up the SEIC (PTO) wire too?
New Rig On Order - 2011 F350 Lariat CC - Black/2 Tone Diesel
Rig - 2008 F350 Lariat CC - Black - Medium Stone Interior - Diesel - TOTALLED
Towing - 2008 Jayco G2 29FBS
Head Unit- Alpine CDA-9887
Front Stage Amp - Alpine PDX-4.150
Sub Stage Amp - Alpine PDX-1.600
Front Stage - Boston Pro60's
Subs - (2) Boston G110-4
Sound Deadener - Dynamat Extreme
2008screw is offline
Old 11-25-2007, 04:25 AM   #2 (permalink)
loft306's Avatar
Re: SEIC and Upfitter Switch
No but here are what there rated for:
<div class="ubbcode-block"><div class="ubbcode-header">Code:</div><div class="ubbcode-body ubbcode-pre" style="height: 128px;"><pre>
Ford upfitter switches: Ign-Hot-ACC
Aux-1 [30-amp] Circuit No. CAC05 Wire Color: Yellow
Aux-2 [30-amp] Circuit No. CAC06 Wire Color: Green / Brown
Aux-3 [10-amp] Circuit No. CAC07 Wire Color: Violet Green
Aux-4 [15-amp] Circuit No. CAC08 Wire Color: Brown
• Found: above and to the right of parking brake release handle by the relay pack. </pre></div></div>
the above is from: the 2008 SEIC manual LINK
I'd choose #3 or #4
~ Mike
2008 BLACK F350 XLT RC SRW 4x4, 6.4, Auto,3.73ls, ManualTransferCase,PTC-Heater. Pic's She is Sweet...
DORA recieved:9/14/07 || ReceiptDate:9/14/07 || SerializeDate:11/01/07 || SegmentDate:11/01/07 || SequenceDate:11/10/07 || BlendDate:11/13/2007 || GesitmatedBuildWeek: 12/10 || ProducedDate:11/21/07 || GateRelease:11/21/07 || ShipDate:11/24/07 || ArrivalDate:11/30/07 || SoldDate:11/30/07 ||
1992 F150 | 1987 E250 | 1983 CutlassCiera | 1979.5 K5 blazer
loft306 is offline
Old 10-07-2008, 11:24 PM   #3 (permalink)
Send a message via AIM to Grampsride
What is the SEIC wire hooked to one of the upfitter switches for?
Grampsride is offline
Old 10-08-2008, 10:51 AM   #4 (permalink)
Flip the switch on the dash, and the truck up idles to about 1.2k to provide additional load on the engine (helps prevent wet stacking for extended idling and while using the Power Take Off PTO).
OMC
OMCUSNR is offline
Old 10-08-2008, 01:03 PM   #5 (permalink)
F450Mikey's Avatar
I hooked mine up to the 4th switch. The whole mod took 5 minutes.
2008 F450 Dark Shadow Gray Lariat "Pick Up" Job 1
2006 Weekend Warrior FSC 2800
2005 Honda CRF 450R
F450Mikey is offline
Old 10-08-2008, 04:40 PM   #6 (permalink)
CaptinCrash's Avatar
OMC
what is wet stacking
sorry about frequent miss spellings I'm severly dylexic
A true Desert Racer For life
1997 f250 4x4 ex.cab long bed 7.3l Scalzo Racing Chase 1
Airraid stage 2intake
Real Men Use The Green Pump
CaptinCrash is offline
Old 11-18-2008, 11:59 PM   #7 (permalink)
Causes: A diesel engine, like all internal combustion engines, to operate at maximum efficiency has to have exactly the right
air to fuel ratio and be able to sustain the operational temperature it was designed to run at for a complete burn of
the fuel. When a diesel engine is operated on light loads it will not attain its correct operating temperature.
When the diesel engine is allowed to run for extended periods below its designed operating temperature, unburned
fuel is exhausted and noticed as wetness in the exhaust system, hence the phrase “W
et Stacking.”
Engine Effect: When unburned fuel is exhausted out of the combustion chamber it starts to build up in the exhaust side of the
engine resulting in fouled injectors and a build up of carbon on the exhaust valves, turbo charger and exhaust.
An excessive amount of deposits can result in a loss of engine performance as gases bypass valve seatings,
exhaust buildup produces back pressure and deposits on the turbo blades reduces turbo ef
ficiency. Over short
periods permanent damage will not be incurred, but over longer periods damage will occur as deposits scar
and erode key engine surfaces. (see diagram one)
Another result of running below the designed operational temperature is the pistons rings, fitted to the
piston to allow expansion of the piston as the engine temperature rises, do not attain their level of designed
tightness required to adequately seal the space between the cylinder walls. This results in unburned fuel and gases
escaping into the oil pan and diluting the lubricating properties of the oil, leading to premature engine wear
Why Avoid: Having discussed the effect of “Wet Stacking” on the diesel engine, the reasons for avoiding the condition are now known, but in addition to the adverse engine effect the designer and user of a system have to consider:
Expense: Excessive “Wet Stacking” will shorten engine life by many years and before planned replacement.
Pollution: Many urban areas are restricting the level of smoke emissions “Wet Stacking” produces.
Power: Even before an engine is damaged deposits will reduce maximum power. A prematurely worn
engine will have a lower maximum power than it was designed to develop.
Maintenance: An engine experiencing the effects of “Wet Stacking” will require considerable more maintenance
than an engine that is adequately loaded.
'08 F-350 Lariat CC Gold 4x4 Diesel
dswift is offline
Old 11-19-2008, 08:42 AM   #8 (permalink)
Martin #6's Avatar
It's that easy.........simply connecting a couple of wires together?
Early 99 F-250 4X4, built 9/98, 3:73LS, ATO trans with Chevron 30wt Drive Train Fluid, Garrett 38R BB ceramic coated 1.0 turbo, High Flow ceramic coated outlet, Non-ebv pedestal, BHA, Beans billet intakes, Teminator HPOS w/ R-IPR, Spearco 7.3 IC, 6.0 trans cooler, BWD ceramic coated bellowed up-pipes, DI regulated fuel return, AirDog, SWAMPS Stage II singles, BD Torq-loc, BD 4" in-line exhaust brake, 4" exhaust with ceramic coated downpipe, Live tuned by DP Tuner, Tymar, Racor CCV4500, Coolant filter, 203 T-stat, Pre and post pyro's, OilGuard by-pass filter.
SOLD
2008 F-250 4X4 Lariat CC. Job 3
No longer stock.
Martin #6 is offline
Old 11-19-2008, 09:30 PM   #9 (permalink)
yes it is.
1991 YJ
Dad has a 2004 6.0L all stock.
1960 CJ5 all stock
1987 F-250 XLT lariet 6.9L [img]/ubbthreads/images/graemlins/cool.gif[/img] 3.55 limited slip, 4 speed, auto meter pyro, Napa water temp and oil pressure, 344,460KM on her. Injector pump rebiult at 255,000 KM Here are some pics of her
budtoh3zo is offline
Old 11-23-2008, 10:22 PM   #10 (permalink)
It amazed me how quick and easy this mod is to do took less than 5 minutes all you got to do is find the wire which is not hard to find and then double check its the right one then tripple check..... ect... then splice it and either solder it to the uplifter switch wire or get a wire wire connector.
2008 Ford F-250 4x4 6.4 Powerstroke Diesel cc/sb grey
2007 Ford F-450 4X4 Powerstroke Diesel, Knapheid Flatbed,Farm truck, Turbo timer, Buckstop Bumper, Warn 16.5 TI winch, PIAA Lights, FUll tools chest, Gooseneck Hitch
2006 Chvrolet SIlverado 2500HD 4X4 Duramax Diesel Allison Trans, Stock
Two John Deere 7320 Series Tractors Mfwd
Case IH Mx 275 front duals, MFWD
Steiger 335
2003 Polaris Ranger 4X4
2008 Polaris Ranger
Duramaxfarmer07 is offline
Old 11-23-2008, 10:41 PM   #11 (permalink)
compman72's Avatar
My Photos: (9)
Which wire did you use for SEIC?
Is is the yellow/green wire that we need to be using?
I currently have mine hooked to the BCP.
2008 F250 XL Crew cab, manual 4x4, 6.4L, Job 3, TorqueShift, w/ Decor group, Camper Pkg, Off Road Pkg, LWB, Power Equipment Group, Tow Command, Knapheide Utility Bed with sliding top. Built 2/5/2008 & Purchased 9-1-08
08B07 Flash 1-16-09
Firestone Ride Rite Air Springs 3-20-09
Radiator (end cap leak) @ 34,100 miles 11-19-09
11B23 PCM Recalibration 4-11-11
Hydroboost Replacement (leaking Power Steering Fluid) @ 82,866 miles 7/25/11
Upper & Lower Hoses (new design) @ 90,000 miles 11/10/11
compman72 is offline
Old 11-26-2008, 12:08 PM   #12 (permalink)
Martin #6's Avatar
FYI. If you have the satellite radio system then the upfitter wires are difficult to find and access. It's much easier to remove the module to make the connection to the upfitter wires.
SOLD
No longer stock.
Old 11-26-2008, 10:04 PM   #13 (permalink)
Lightningfast01's Avatar
I used #4 because it was the lower amp switch and I wanted to save the high current circuits for larger accessories. I just used the purple with green stripe BCP wire. Battery Charge Protection uses a 1200rpm kick up and varies to maintain proper battery voltage if you are using a winch or high current drain accy. Also, BCP does not lock the torque converter. The SEIC does lock the converter.
Upfitter #1 is my air compressor
#2 is one set of aux lights
#3 is a second set of aux lights
#4 is high idle.
I say wet stacking is an old legend linked to pre historic diesels. If you pay attention you will notice the truck modulates its own idle RPM when cold. Engineers have programmed these trucks to maintain a proper burn by calculating intake air temps, oil temps, coolant temps etc.
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline
Old 11-27-2008, 09:48 AM   #14 (permalink)
compman72's Avatar
My Photos: (9)
I would also think that with the new style of injectors (able to squirt 5 times/ cycle) that the PCM knows when it is idling and will reduce fuel flow to where the engine is to idle with a minimum amount of fuel.
08B07 Flash 1-16-09
