Spartan Towing Trip Data (2000 Miles) - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 08-30-2009, 07:38 PM   #1 (permalink)
brock187's Avatar
OK, so I just hooked to my camper for the first time since I installed my Spartan tuner, Dash-daq, and kit and I can say it is a beast of a tow truck now! I left North Carolina and drove 1036 miles to Illinois through mountains and averaged 10.9 miles to the gallon with the 210 HP Tune. The power and shifts were incredible! I did notice on one of the taller mountains (Going up) that I got dangerously close to overheating my tranny. Now I have heard tons of suggestions, but now I will tow in 150HP when going up those mountains.
On the way back from Illinois (Down hill), I was averaging 11.6MPG. I never saw the tranny get close to hot on the return trip.
Overall, my camper weighs between 14,000 and 14,500lbs when I tow it loaded and I feel the ideal tune for my setup would be the 150 if going mainly up through mountains, but 210 on open road or going downhill through mountains. I think I'm gonna order the 275 tune for the torque converter lockup feature!
"UNBREAKABLE"
--2008-JOB3-F-250 Lariat-4x4-w/ 6.4 Liter Diesel --*Crew Cab-16lb Reese Fifth Wheel Hitch
*Spartan Phalanx Tuner w/ Dashdaq Controller w/
*75hp, 150hp, and 210hp Tunes.
*35x13.00x20 Toyo Open Country Tires
*10x20 Chrome Pasati Rims
brock187 is offline
Old 09-01-2009, 03:52 AM   #2 (permalink)
sawtooth's Avatar
I'm getting ready to make a similar trip. Did you head up hwy 77 which is what i'm planning to do this weekend? I'm asking cause i will be towing 8000lbs which is a tractor and trailer combined and was considering using the 210 tune. Maybe I should just stick with the 150 tune to be safe.
2008 Job 3 6.4 F250 Lariat CC 4x4 Dark Stone
ATS Color Matched Street Flares
Eaton ELocker "front" and Truetrac Limited Slip "rear"
sawtooth is offline
Old 09-01-2009, 11:21 AM   #3 (permalink)
smotrs's Avatar
My Photos: (16)
Remember, it only takes 15 minutes to switch tunes. If you start to experience high temps, pull over, take a break and load the lesser tune.
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT
Avic-Z2 (Z3 Mod) Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, 6-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares (color matched)
Ravelco Anti Theft Device
Originally Posted by George Bush
Wait, what did you just say? You're predicting $4 a gallon gasoline?. . . That's interesting. I hadn't heard that.
smotrs is offline
Old 09-01-2009, 01:28 PM   #4 (permalink)
what tranny temps were you seeing?
jascott is offline
Old 09-02-2009, 08:25 AM   #5 (permalink)
brock187's Avatar
Which Tune and Tranny Temps
Sawtooth,
Yes, I took 77! I would say you will be fine with the 210 tune at 8,000lbs! I was towing 14,000-14,500lbs. I never had a problem, but I am very meticulous about watching my guages while towing.
jascott,
I don't remember an exact temp, but I had the boys at Spartan make me a setup with all the parameters I need on one cool screen and I noticed I was getting close to the red! I also saw my OEM Tranny Temp guage almost redline, and I have made that trip on that same route with the same load a couple of times without ever seeing the tranny temp needle move!
I was experimenting with the 210 tune and overall it was awesome!
To be on the safe side, I will tow with the 150 tune the next time I take that route through the mountains!
"UNBREAKABLE"
brock187 is offline
Old 09-02-2009, 09:07 AM   #6 (permalink)
sawtooth's Avatar
brock187,
yep i'm going to go with the 150tune as well then. Going to pick up the load tomorrow and head out. Thanks for the input.
sawtooth is offline
