Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading and adding aftermarket equipment to your 2008 Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 06-15-2008, 10:52 AM   #1 (permalink)
Synthetic Oil - who has switched?
1. How many of you have switched to Synthetic Oil?
2. How many miles did you have on your truck when you switched?
3. What oil are you running?
4. How long are you going on your oil changes.
5. And did you notice any mileage change?
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
RRose is offline
Old 06-15-2008, 12:22 PM   #2 (permalink)
Engine31's Avatar
My Photos: (9)
I'm going to Amsoil any day now. I have 3000 ml on her after a hard tow of 500 ml's with long 7 & maybe 8 percent grades towing around 18,000 lbs in dusty conditions.
I have the oil sitting here and will analylize the engine oil to determine if it is too soon.
Will update.
F450 Lariat 4X4, red, 4.88's, everything but the moonroof, S & B Intake, Banks exhaust, Amsoil.
Engine31 is offline
Old 06-15-2008, 12:43 PM   #3 (permalink)
Will update.
GEEZ..... talk about a torture test!
I mainly am looking for the fuel mileage increase. If it will affect my fuel economy in the positive way.... I am going to do it.
RRose is offline
Old 06-15-2008, 01:18 PM   #4 (permalink)
I did not realize this was a 6.4 forum when I posted I have a 7.3
I switched to Delvac 1; 5W-40 @ 30,000 miles.
The # 1 reason was for easier starts in cold weather, the second was hoping for better fuel economy.
I normally change the oil 3 x @ year or every 4 months which would be 3000 to 5000 miles.
As diesel cost have gone up I have been using the truck much less and now I am doing the oil changes 2 x @ year and the last oil change had only 2700 miles on it so I switched back to old dino oil, for the summer months.
I feel my truck has always gave me good fuel economy the actual gain with Delvac1 is hard to measure and Mobil states there is a 6% gain.
My average for a 80 mile daily commute has been 18, and on a road trip of 1200 miles I averaged over 20
I have not seen a drop in fuel economy since I switched back to dino oil (Rotella T 15w-40 to be exact)
I have noticed the truck does use less fuel the past week when temps were up in the high 90's
2000 F250 S/D 4x4 C.C. 7.3 PSD AUTO. XLT , Line-X bed liner, ARE cab high cap. / 2006.5 VW Jetta TDI my baby diesel.
Phil Sag is offline
Old 06-16-2008, 07:14 PM   #5 (permalink)
Amsoil 5w-40 CJ-4
I had about 14,000 on the truck when I made the change (now 21,000).
I am going to take oil samples every 10,000 miles.
I also have a by-pass filter.
mileage change....not really.
2008 F350 DRW crew cab, FX4 package. S&B cold air intake. FS 2500 by-pass oil filter, B&W Turn over hitch.
2008 Jayco 34RLQS 5th wheel camper
2004 Victory Kingpin
Retired U.S. Army
Panama
SW Asia
Somalia
Blackhawk Helicopter Mechanic.
Ray324 is offline
Old 06-17-2008, 12:01 PM   #6 (permalink)
Originally Posted by Ray324 View Post
Amsoil 5w-40 CJ-4
When did AMSOIL have their oil certified to CJ-4?
OMCUSNR is offline
Old 06-17-2008, 12:09 PM   #7 (permalink)
Does the certification make you feel better?.You always come on here try to be a Know it all!
4STAR is offline
Old 06-17-2008, 12:30 PM   #8 (permalink)
Shell Rotella 5W-40. Have been using it for 21,000 miles. 2 oil analysis have come back perfect after chaning every 7000. No difference in mileage.
2004 F250 6.0, 4" T-back MBRP, AFE Stage II/PG7, Accufab elbow, Pyro, Trans, Boost pillar mount, SCT running Extreme Street, ITP reg return, AirDog, Oilguard bypass, CCV mod, Diesel Site coolant filter, harpooned, Daystar levelling kit, Viair onboard air with Siege train horns, heated mirror switch, Hella 500 Driving and Fog lights behind Billet grille, back-up lights, Kenwood 7019 in-dash DVD, Alpine S in the doors, 2 10" JL subs with Alpine amp.
Next: Mag-Hytec diff cover and trans pan, meth injection
ryano2121 is offline
Old 06-17-2008, 01:32 PM   #9 (permalink)
Supporting Member
bugman's Avatar
My Photos: (15)
When the manufacture requires an oil that is CJ4 certified I think that it should. If you even go to the Amsoil site you will see for yourself that even they don't have a recommended for the 6.4 engine.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
bugman is offline
Old 06-17-2008, 03:30 PM   #10 (permalink)
The certification costs alot of money.Go to any amsoil website.The DEO 5w40 is a low ash formula!
4STAR is offline
Old 06-18-2008, 08:20 PM   #11 (permalink)
AMsoil
I put what is on the bottle, I did not say ANYTHING about certification. WOW!!! Don't use it if you think Amsoil is using mis information, or is not right for your truck. I was just trying to answer a question.
Sorry I guess you are a Diesel expert!!!
Please refer all questions to OMCUSNR
Retired U.S. Army
Panama
SW Asia
Somalia
Ray324 is offline
Old 06-18-2008, 10:35 PM   #12 (permalink)
first oil change at 10,000 miles
Mobil Delvac 1 ESP; which is CJ rated synthetic.
The oil analysis on factory fill was fine with no red flags,
will change again at 20,000 miles with the Mobil Delvac 1 ESP.
If oil analysis comes back ok, (concerned about fuel dilution with these long changes) then I will continue with the synthetic.
No improvement to fuel economy that I can tell and I have records since purchased. Now have +17,000 miles on truck.
If the 20k change analysis comes back with any fuel dilution then I'll go to 5,000 mile changes with dino oil.
Bob
08 F350 DRW 4x4 Lariat CC 6.4 torqshift wide track front axle 4.10LS
07 Montego Bay 34RLB3 5th wheel
(traded the 04 w/ 56K mi. on 3/25/06; the 06 w/ 45K on 10/1/07)
bnmccoy is offline
Old 06-19-2008, 11:08 AM   #13 (permalink)
You know Ray, I'm no more an expert on diesel's than I am on Blackhawk copters, but I know how to read a manual, & I used to work SUBSAFE for the Navy. I'll use what the manual says.
OMC
OMCUSNR is offline
Old 06-19-2008, 01:32 PM   #14 (permalink)
Stymie's Avatar
for the cost of synthetic, for it to be beneficial to use for the purpose of fuel mileage, you would have to see a significant change, and run very extended intervals.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 Pro Comp Xtreme Mud Terrains
Try the SEARCH Button
Stymie is offline
Old 06-22-2008, 06:26 PM   #15 (permalink)
Sometimes it is not about the $$$$$ For me it the the protection.
In Aviation, the use of Synthetic has been around for decades. Why?? It stands up to heat MUCH better, and does not break down. My Turbine Engines can go over 700c. Flows well when VERY cold, and we don't change the oil very often, sometimes not for a couple years.
So for me the choice was easy.
Foot note...... The founder of Amsoil was a Fighter pilot.
SO pick the FULLY Synthetic of your choice!!!!
Retired U.S. Army
Panama
SW Asia
Somalia
Ray324 is offline
