Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading and adding aftermarket equipment to your 2008 Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 11-14-2008, 07:56 PM   #1 (permalink)
Skinz2Win's Avatar
Post Tuner
I have an 2008 F-250 Lariat and was wondering if I installed a tuner in my truck would the factory know I installed a tuner and void my warranty? Watchin all these videos and reading everyone's enjoyment of a tuner has me itchin to get one. I have 10k on my truck and bought the extended warranty,so I don't want to void it.
Skinz2Win is offline
Old 11-14-2008, 10:36 PM   #2 (permalink)
Supporting Member
bugman's Avatar
My Photos: (16)
Figure it this way, if they want to find evidence of a tuner they are going to find evidence of a tuner weather it is connected or not. These 6.4's are showing that they are a very hardy engine even with people running tuners. I have two friends that have them. One is a job one that is bone stock and the other is a job 3 that has 80,000 miles on it with half of them with a tuner and no problems with either one. Just be aware that something could happen and if you go in on the flat bed with the tunes programed you may be out of luck.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is online now
Old 11-15-2008, 12:42 PM   #3 (permalink)
jonrjen's Avatar
Why is it so many people want to "Play outside of the box, but expect the box to protect them for doing so"?
As the old saying goes, "If you are going to Play, be prepared to Pay"
2008 F-550 Regency Conversion Hauler 6.4 PSD
2006 Ford F-250 XL V-10 6-Speed
2006 Ford F-150 Crew Cab XLT
2005 Lincoln LS Sport
1977 F-600 Cab-Chassis V-8 4-Speed 2 Speed rear
1997 Travel Supreme 40' triple slide 5th wheel
38 +or- head of Texas Longhorn Cattle..."REAL COWS Have HORNS"
jonrjen is offline
Old 11-15-2008, 02:55 PM   #4 (permalink)
InnovativeDiesel's Avatar
With our SCT device, there will be no evidence that the truck was programmed once you have returned to stock. Return to stock before going to the dealer, so that the truck is easier to diagnose for an issue. You can take your truck back to the dealer for various issues, not related to tuning. So, you are better off returning to stock so there are no excuses.
If you have any specific questions, please contact us.
Innovative Diesel Performance
410-620-3020
http://www.innovativediesel.com
The Original SCT Custom Tuning Dealer!
We are the first and most experienced custom tuner for the 6.0L truck!
*No gimmick's and no marketing ploys.*
Only the best custom tuning, from stock to highly modified trucks. We have a proven track record and tune the fastest and most powerful Ford vehicles in the industry.
IDP thrives on carrying only the best parts and great customer service. Over 5000 parts ready to ship for your diesel truck!
InnovativeDiesel is offline
Old 12-02-2008, 09:48 AM   #5 (permalink)
Cabzbad's Avatar
Just so you know.....If you have major engine problems....they will pull motor and tear it appart....and then they will know if you have a tuner...its is very obvious if you do. The way they can tell is the spray pattern on top of the piston....If I recall correctly. I should know because I had a motor pulled and I was there when the tech pulled the heads off and he showed me the increaced spray pattern. So if they really want to know they will find out.
Cabzbad is offline
Old 12-02-2008, 10:59 AM   #6 (permalink)
There's no fuel outside of the bowl with the correct tuning. There are programmers and modules that modify the injection event enought to spray outside of the bowl and leave a star pattern. However, your pistons will look like stock with the correct programming.
410-620-3020
Old 12-04-2008, 05:22 PM   #7 (permalink)
Lightningfast01's Avatar
The PCM will have a P1000 not ready OBD code until a new drive cycle is stored. I usually tell them I reset the batteries to try to fix the issue to explain the code. My dealer considers a P1000 to be a you re-flashed it code. I ran an Innovative tune for 50K miles and when the dealer tore my truck down for head gaskets the pistons looked stock. I also have seen an injector stick open and torch a piston like butter.
If you use SCT you may need to get the tuner unlocked after a dealer reflash. Otherwise it will keep your old stock data in memory next time you use it.
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline
