Tuner, Exhaust, Air Intake? Rate them in priority. - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 10-14-2009, 10:06 PM   #1 (permalink)
Just ordered a 2010 F-250 6.4, 3.55, 4x4 CC SWB King Ranch. I am looking for Long life, MPG, some more power, and a quite ride. Most of my driving is 2 lane hwy with small hills and a lot of interstate. I think I am going with the Spartan 275 Tune. I have been around the industrial diesel many yrs. Just not looking to increase the sound level in the cab anymore than i have to.
The question is:
On a scale of 1 - 10 how much difference will which larger air intake make?
On a scale of 1 - 10 how much difference will 4" or 5" pipes make or should I keep the stock pipes?
Great Website. I am learning a lot about the super duties here.
kimwoodson is offline
Old 10-14-2009, 11:00 PM   #2 (permalink)
Stymie's Avatar
if you get a tuner, and run larger than a 210 tune, the intake is required. it will suck the filter minder in and tell you the filter is plugged. the exhaust isnt required, but helps alot. with a muffler, the in cab noise is kept very well in check.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline
Old 10-15-2009, 07:27 AM   #3 (permalink)
How much difference will i get between the 4" and the 5" exhaust?
Old 10-15-2009, 10:10 AM   #4 (permalink)
I have the 5 inch magnaflow and its really quite in the cab. Mostly I hear the intake...
2009 F250 CC/LB 4x4 6.4 Sterling Grey
AFE Stage II PG-7, Spartan with 310 and tcm and magnaflow exhaust
sdcarguy is offline
Old 10-15-2009, 03:33 PM   #5 (permalink)
All three kinda go hand and hand. If you are getting the 275, go with a 5" exhaust, any brand downpipe or turbo back with a muffler. You wont hear very much with a muffler and the windows up. If you are going to spring 2 grand+ for the programmer and exhaust, might as well throw 3 hundred more for the intake.
inino is offline
Old 10-15-2009, 03:55 PM   #6 (permalink)
smotrs's Avatar
My Photos: (16)
Performance wise, no difference. You will get a slightly deeper sound from the 5" over the 4".
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT
Avic-Z2 (Z3 Mod) Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, 6-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares (color matched)
Ravelco Anti Theft Device
Originally Posted by George Bush
Wait, what did you just say? You're predicting $4 a gallon gasoline?. . . That's interesting. I hadn't heard that.
smotrs is offline
Old 10-16-2009, 01:31 PM   #7 (permalink)
DSTRBD's Avatar
Feedback Score: 3 reviews
Start with the tuner, then the exhaust, then the intake. A 4" exhaust is all you really need, but the 5" does sound pretty mean. I run the 4" straight piped Flo-Pro kit on my truck and it is plenty aggressive for me. Let me know if I can help with anything.
Performance Truck Products
Call 888-516-4644 or Chat Live On Our Site
DSTRBD is offline
Old 10-19-2009, 12:21 PM   #8 (permalink)
DSTRBD's Avatar
Well, if you get the one of the big three (Spartan, SCT, Edge Race) you can get acquainted with it and learn how it works first and then add the exhaust.
DSTRBD is offline
Old 10-19-2009, 09:42 PM   #9 (permalink)
HUH thats funny i have the 250 tune on mine and have never seen the filter blocked light and im always on my truck. I have flo pro 5" straght pipe on my truck and the cab noise is not loud at all.
09 Oxford 4 door is offline
Old 10-21-2009, 11:00 AM   #10 (permalink)
DSTRBD's Avatar
Though the intake is not required, its highly recommended. The filter minder being sucked down is an indication that more air is needed than what the stock system can provide.
DSTRBD is offline
Old 10-21-2009, 11:46 AM   #11 (permalink)
senix's Avatar
I did the reverse. got the intake and then the programmer. Did it in this fashion as many people have trouble with the intakes.
Secondly I wanted to retain my DPF for now.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 14K.
senix is online now
Old 10-24-2009, 04:14 PM   #12 (permalink)
71stang99's Avatar
What is the best intake? One can read all of the ads so when the dust settles which one is?
71stang99 is offline
Old 10-24-2009, 05:52 PM   #13 (permalink)
Matt0987's Avatar
I believe that if you get the exhaust first you will free up the breathing of the engine. Lower egts. And make the tuner perform better when you get around to it. If you install the tuner first it will be limited by the back pressure from the stock exhaust.
When I was doing mine, see my sig for what I have done, I read from the manufacturer that there was a horse power range recomendation for the 4" and 5" exhaust. Based on their, MBRP, recommendation I went with the 4" exhaust. I never plan on having 450 hp or more generated by my engine.
Their system also has a nice sound to it. Stainless, of course.
They also have, and I do not recall if they did when I got mine, a nice "Laker" type set up where the system splits into two and comes out in front of the rear tires.
But I would, and did, go with the exhaust, then the tuner.
If you read the forums regarding the air intake on this site you will find recommendations to save your money unless you are looking to just dress up the looks of things under your hood. For in depth arguments for this recommendation I would suggest that you search for those forums.
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
Matt0987 is offline
Old 10-24-2009, 06:17 PM   #14 (permalink)
Matt0987's Avatar
Oh yes. I forgot.
Matt0987 is offline
Old 10-24-2009, 09:44 PM   #15 (permalink)
71stang99's Avatar
Its good to know what products work as a CAI did wonders on my supercharged 03 Cobra. This truck with the turbo sure is a different animal, I would have thought decent gains just with the CAI. I am not looking for max power just some improvements without getting crazy with hi power tunes as I wish to tow. Same thing goes with the exhaust, a midpipe and catback was worth the money.
2009 F350 FX4 CC PSD
S&B Intake
