Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading and adding aftermarket equipment to your 2008 Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 10-24-2009, 06:08 PM   #16 (permalink)
Stymie's Avatar
Originally Posted by Matt0987 View Post
I believe that if you get the exhaust first you will free up the breathing of the engine. Lower egts. And make the tuner perform better when you get around to it. If you install the tuner first it will be limited by the back pressure from the stock exhaust.
you are only half right. this is about 6.4's. you can not remove the dpf without a tuner. without removing the dpf all you are doing is chaning out the tail pipe and in that process you accomplish nothing. zero zilch nada.
i agree a tuner with stock exhaust on these trucks is not a good idea.
as far as best intake, AFE or the S&B. you can't go wrong with either.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline
Old 10-24-2009, 06:17 PM   #17 (permalink)
Matt0987's Avatar
Oh yes. I forgot.
'03 Excursion, 7.3L, 4X4, 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Bilstein shocks, Rancho steering damper. Airlift 5000. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter, 2m-70cm Yaesu ft-8500.
Matt0987 is online now
Old 10-24-2009, 09:44 PM   #18 (permalink)
71stang99's Avatar
Its good to know what products work as a CAI did wonders on my supercharged 03 Cobra. This truck with the turbo sure is a different animal, I would have thought decent gains just with the CAI. I am not looking for max power just some improvements without getting crazy with hi power tunes as I wish to tow. Same thing goes with the exhaust, a midpipe and catback was worth the money.
2009 F350 FX4 CC PSD
71stang99 is offline
Old 10-24-2009, 10:05 PM   #19 (permalink)
senix's Avatar
i use the banks air ram with no problems.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
Old 10-25-2009, 01:09 AM   #20 (permalink)
Stymie's Avatar
on a diesel you rarely see power gains without adding fuel to the mix.
17x9 Pro Comp 7189
Stymie is offline
