6.4L Upgrades and Aftermarket - EngineUpgrading and adding aftermarket equipment to your 2008 Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
I am interested in buying a Spartan tuning device for my 09 F350. I regularly tow 10,000lbs in hilly terrain. I notice they have a wide variety of hp levels. Is there a description of what each tune does and what they are designed for? How do you decide which one to use? I'm not into drag racing, just economy and towing. I've tried emailing Spartan at the address on their web site with these questions but their email just bounces back "5.1.0 - Unknown address error 550-'5.7.1 Mail from 64.59.134.9 rejected; by cwm dnsbl'"
if you buy a new spartan tuner, it comes with 8 preset tunes. I DD the 250 tune, and i tow with the 175 tune.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE Try the SEARCH Button Because It's Probably already been asked
Kerry
The recommended tow tune is 150hp, but you can tow with larger tunes. You just have to use you head and monitor the gauges with the Phalanx (DashDAQ). It comes with 12 pre-loaded tunes starting with DPF on road tunes from 40, 75, 120, and 150hp. It also has off tunes starting at the 40, 75, 120, 150, 175, 210, 250, and a stock off road tune in the basic package. Any tune from 210 down has built-in safety features like a stock file. If you egt's get too high it will defuel. The 250 and above tunes are not the same and are considered race tune and will shift a lot harder that stock. They are made that way so the transmission will not slip. Let me know if you have any other questions, or email techsupport@spartandieseltech.com
on, i have no clue, off, im seeing 3-4 mpg over stock in mixed driving, i have yet to put a solid highway tank on it
17x9 Pro Comp 7189
Most people seem to use the 210, 250, or 275 tunes for daily driving as well as towing. Mileage also seems to be the best in these tunes , 2-4 MPG gain. If you have any questions, feel free to give me a holler.
if i need this truck to last at least 125,000 miles what tune would be mostly likely to get me that far without problems? or would i be better off to just leave it stock?
I would say the 210. It shifts better than stock, has plenty of power and all the built in safeties like a stock tune. Plus the egr valve is kept closed when running which helps to keep trash from being re burned through engine and has lower boost pressure. Egr valve will cycle when the engine is at an idle to help keep it from sticking.......
