Whistling noise from defroster area!!! - Diesel Forum - TheDieselStop.com
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
post #1 of 17 (permalink) Old 06-26-2010, 08:17 PM Thread Starter
There is an extemely loud obnoxious whistling coming from what appears the defroster area. The window has never leaked ever after sitting with a few feet of snow on it for weeks. Most loudest when driving on a very windy day on the freeway. Also less loud when window opened a little bit.
Would appreciate any and all suggestions.
May I post this request on the other forums as I don't suppose it would pertain to any certain engine.
Sandy
SandySoCal
2003 "The Tank", King Ranch F350,Auto, 4X4, FX4 Crew Cab, Chestnut.
SandySoCal
sandyw is offline
post #2 of 17 (permalink) Old 06-28-2010, 10:52 PM
I not sure of an answer but my pickup has a bad whistle too when driving into the wind. The wind needs to be blowing across the vehicle from the passenger side to create the noise. It sounds like mine comes from the top about where the sirus antenna is. I have taken that off and resealed it but didn't help. I have taped the top of the window seal with mailing tap but still leaks. I don't have any overhead lights, so I am not sure what else it could be. I would appreciate any suggestions.
bossly is offline
post #3 of 17 (permalink) Old 06-29-2010, 10:17 AM
tvandyck7's Avatar
Mine does this as well with a strong crosswind. Just driving at highway speed doesn't make it do it. There has to be a substantial crosswind. I just figured it was air getting trough the weather stripping on the driver's door. I was thinking about doing the mod where you install tubing inside the weatherstrip to tighten it up.
As for the windshield/defroster whistle, have you tried turning your recirculation on and off to see if the noise changes? You could have trash or dirt in your fresh air vent/valve that is letting air leak through. That's just my .02. I'm not even sure that's how the system works or if it is possible to get something in the vent.
2009 F-250 6.4L PSD CC SB Lariat Ultimate FX4, 3.73LS
Mod List:
-51 gal RDS direct fill auxillary fuel tank
-SEIC High Idle
-H&S Black Maxx Running the Hot Damn +300 Tune
-S&B Dry CAI
-Diamond Eye 5" Turbo Back Race Exhaust
-Custom 10" Sub Box Behind the Center Console
-Coastaltech SYNC-LP1 Lockpick
-Westin Bull Bar
-Westin Taillight Guards
-Recon LED Smoked Dodge Cab Marker/Clearance Lights
-Billet Fender Vent Inserts
-Zone Offroad 4" Lift
-20x10 BMF Novakane 8's
-35x12.50r20 Nitto Trail Grapplers
-'11 Super Duty Rear Seat Cargo Tray w/410W Power Inverter
tvandyck7 is offline
post #4 of 17 (permalink) Old 06-29-2010, 10:29 AM
That sounds just like my pickup. Could you let me know if the tubing fixes the problem.
bossly is offline
post #5 of 17 (permalink) Old 06-29-2010, 10:40 AM
tvandyck7's Avatar
Will do. There is a thread on here with the instructions for doing it. Read more about it here: Door Seal Mod-Really Works Well
Mod List:
-SEIC High Idle
-S&B Dry CAI
-Westin Bull Bar
post #6 of 17 (permalink) Old 06-30-2010, 04:59 PM
bigblockbill's Avatar
Mine does it to. It can be a cross wind from either side and which ever side the wind is coming from is the side that whistles. Very annoying and startled the heck out of me the first time. I posted something about it here a year or two ago and did not get any good feedback. I am thinking its from up around the bottom of the windshield more than the door rubbers but who knows.
2008 F350, Crew Cab, FX4, SRW,
job 3, Long Bed.
bigblockbill is offline
post #7 of 17 (permalink) Old 06-30-2010, 11:11 PM
I think mine sounds like it is around the window, but its hard to pinpoint the spot. Mine only whistles when a crosswind is blowing across the vehicle from the passenger side.
bossly is offline
post #8 of 17 (permalink) Old 07-25-2010, 01:00 PM
mine whistles when my wife closes off her dash vents and fan is on one of the higher settings
danxltsport new 08 lariat sc lb 6.4 ....... traded 05 black cc lb diesel xltsport black leather trailer tow....... traded 00 cc lb duelly diesel "lariat LE" w/banks stinger+
drmaland is offline
post #9 of 17 (permalink) Old 07-25-2010, 01:08 PM
PSDfreak's Avatar
I've got a whistle that I have pin pointed at the passenger side mirror turn signal. Depending on the conditions it will whistle at freeway speeds...I had someone riding with me put there hand over it and it went away. My buddy said he had the same thing. I'm going to see if ford will replace it when I go in for service in a couple weeks.
●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4 Straight Pipe w/5 Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
post #10 of 17 (permalink) Old 07-26-2010, 11:28 PM
My new truck has less than 2000 miles and it sounds like it is coming from the bottom passinger side of the windshield. Seems to be almost every time at freeway speed. It is going in tomorrow to get fixed. I will post what they find.
2010 F350 Crew Cab KR 6.4L
WPWillis is offline
post #11 of 17 (permalink) Old 11-10-2010, 04:29 PM
Mine started doing the same thing. First time I had driven in a heavy cross wind. Didn't matter if it was from the left or right, in fact I turned around and it did the same thing. I caught it on video to show the dealer but haven't been in yet.
WPWillis: Did you ever get yours fixed?
Easyrider6 is offline
post #12 of 17 (permalink) Old 11-12-2010, 08:53 AM
Let us know what the dealer says when you show them the video. I have not taken mine in or done anything about it yet.
job 3, Long Bed.
post #13 of 17 (permalink) Old 11-12-2010, 09:07 AM
Same issue for me
The noise statted for me about 1 month ago, after 1 year of ownership and about 20K miles.
Mine occurs when there is a crosswind coming across from the passenger side.
I suspect it has to do with the seal that runs down the middle of the plastic cowl at the base of the windshield. The seal on mine is starting to pull apart. When I get a spare hour or two, I will cover it up with tape and drive around to see if I can locate the issue.
Tim
dbossman is offline
post #14 of 17 (permalink) Old 11-12-2010, 09:09 AM
smotrs's Avatar
My Photos: (16)
Mine does it too, but it has a deep sound rather then high pitched. Also, sounds like it's coming from the front defrost or windshield rather then the door sides.
I recall a previous thread where the result was that the windshield needs to be resealed. It may not leak, but it results in that foghorn type whistle sound. Just need to get my Jeep back so I can drop the truck off.
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT
Avic-Z2 (Z3 Mod) Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, 6-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares (color matched)
Ravelco Anti Theft Device
Originally Posted by George Bush
Wait, what did you just say? You're predicting $4 a gallon gasoline?. . . That's interesting. I hadn't heard that.
smotrs is offline
post #15 of 17 (permalink) Old 04-05-2011, 01:06 AM
Whistle?
Anyone ever get a fix for the whistle? MIne started around 20-25K miles and only seems to do it in crosswinds from the right also.
Strange....but someone has to have managed to fix it by now huh?
JIM
540Hotrod is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
