STICKY ... COMMON ACRONYMS - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > General Discussion > News, Comments, and Suggestions > News, Comments, and Suggestions FAQ
News, Comments, and Suggestions FAQ Frequently asked questions in the News, Comments, and Suggestions forum.
Old 05-04-2005, 01:55 PM   #1 (permalink)
My Photos: (11)
Sticky ... Common Acronyms
fol is current list as of 11 A.M. 5/04/05
Larry
4x2 Two Wheel Drive
4R100 auto tranny on SuperDuty trucks 99-'03 7.3L
4x4 Four Wheel Drive
4X4L Four by Four Low
ABS Antilock Braking System
AC Air Conditioning
ACC - Accessory Position of ignition key
ACC Air Conditioning Clutch
AIC Auxiliary Idle Control (see APCM)
APCM Auxiliary Powertrain Control Module (FORD's name for AIC)
AP Accelerator Position
API - American Petroleum Institute
APS Accelerator Position Sensor
ATF Automatic Transmission Fluid
BARO Barometric Pressure Sensor
BB Bulletin Board
BBS Bulletin Board System
BOO Brake On/Off
BT(T)T Back/Bump To(The) Top
BTW By The Way
CC Crew Cab (4 door)
CDR Crankcase Depression Regulator
CLV - Calculated Load Valve
CPS Cam Position Sensor
CCV Crank Case Ventilation
DI Direct Injection
DILLIGAF Does It Look Like I Give A Flip
DLC Data Link Connector (OBD connection)
DORA Dealer Order Receipt Acknowledgment
DRL Daytime Running Lights
DRN Dead Right Now
DRW Dual Rear Wheels, dually, Dooley
DTC Diagnostic Trouble Code(usually P-xxx/xxxx)
DVOM/DVM Digital Volt-Ohm Meter/Digital Volt Meter
DWHUA Driving with Head Up "You know what"
E4OD auto tranny on pre-'99 Ford heavy pickups
EB Exhaust Brake
EBP Exhaust Back Pressure
EBPR/EPR Exhaust Back Pressure regulator
EBPS exhaust back pressure sensor
EBV/EBPV Exhaust Backpressure Valve
ECM - Engine Control Module
ECT Engine Coolant Temperature
EEC(M) Electronic Engine Control (Module)
EGR Exhaust Gas Recirculation
EGT Exhaust Gas Temperature
EOT Engine Oil Temperature
ESOF Electronic Shift On-The Fly
ESP Extended Service Plan
FAQs Frequently Asked Questions
FICM Fuel Injector Control Module (6.0 term for IDM)
FIPW Fuel Injection Pulse Width
FOC Free Of Charge
FUBAR Fouled Up Beyond Any Repair/Redemption
FWIW For What its Worth
FYI For Your Information
GAWR Gross Axle Weight Rating
GCWR Gross Combined Weight Rating
GEM Generic Electronic Module
GP Glow Plug
GPC Glow Plug Controller
GPR Glow Plug Relay
GVWR Gross Vehicle Weight Rating
GVW Gross Vehicle Weight
GW Gross Weight
HEUI Hydraulic-actuated Electronically-controlled Unit Injector
HPOP High Pressure Oil Pump
HPX or H/X - High Pressure oil crossover mod that connects the two HP oil rails together
IAT Intake Air Temperature
ICQ I seek you - internet chat network
ICP Injection Control Pressure
ICPR Injection Control Pressure Regulator
IDI In Direct Injection
IDM Injector Driver Module
IMHO In My Humble Opinion
IMNSHO In my not so humble opinion
IRT In Reply To
JFYI Just For Your Information
IPR Injection Pressure Regulator
IVS Idle Validation Switch
JMHO Just My Humble Opinion
JMVHO Just My Very Humble Opinion
KOEO Key On Engine Off
KOER Key On Engine Running
LB Long Bed
LMLM Lean Mean Linking Machine (That's Me]
LMAO Laughing My "You know what" Off (less funny than ROTFLMAO, but more funny than ROTFLOL)
LOL Lots of Luck
LOL Laugh Out Loud
LS Limited Slip
LWB Long Wheel Base
MAF Mass Air Flow Sensor
MAP Manifold Absolute Pressure Sensor
MIL Malfunction Indicator Lamp
MTCW My Two Cents Worth
MVSO My Very Strong Opinion
NGS New Generation Star (Ford vehicle diagnostic scan tool)
OASIS On-line Automotive Service Information System
OBD On Board Diagnostics
OD Over Drive
OEM Original Equipment Manufacturer
OOC Out of Commission (Broke!)
OTC Overhead Trip Computer
OTOH On the Other Hand
PATS Passive Anti-Theft System
PBA Parking Brake Applied
PCED Powertrain Control/Emissions Diagnosis service manuel
PCM Powertrain Control Module
PCV Positive Crankcase Ventilation
PDL Power Door Locks
PITA Pain In The "You know what"
PM Power mirors
POS Piece of "Smelly Stuff"
PPIII - "Portable Programmer" - device similar to the SCMT made by HyperTech
PS Power Steering / Power Stroke
PSD Power Stroke Diesel
PTO Power Take Off
PTTTM Power Telescoping Trailer Tow Mirrors
PW Power Windows
PWM Pulse Width Modulation
RABS Rear Anti Brake System
RC Regular Cab
ROTFLMAO Rolling On The Floor Laughing My "You know what" Off (more funny than either ROTFLOL and LMAO)
ROTFLOL Rolling On The Floor Laughing Out Loud (less funny than either LMAO or ROTFLMAO)
SB Short Bed
SC Super Cab (extended cab)
SCMT Super Chips Micro Tuner (similar to a chip that uses the DLC to reprogram the PCM)
SD Super Duty
SNAFU Situation Normal All Fouled Up
SOL Short of Luck
SOS Same Ole Stuff
SOTP Seat of the Pants
SRS Supplemental Restraint System (air bags)
SRW Single Rear Wheel
SWAG Scientific Wild "seat-of-the-pants" Guess (slightly better than a WAG but not by much)
SWB Short Wheel Base
TANSTAAFL There Ain't No Such Thing As A Free Lunch
TC Torque Converter or Transfer Case
TCC Torque Converter Clutch
TCIL Transmission Control Indicator Light (OD off)
TCM Transmission Control Module (new for 6.0)
TCS Transmission Control Switch (OD off Button)
TFT Transmission Fluid Temperature
TPS Throttle Position Sensor
TSB Technical Service Bulletin
TTB Twin Traction Beam
TTM Turbo Temp Monitor
TTM Trailer Towing Mirrors
TTT To The Top
VAC Volts Alternating Current
VDC Volts Direct Current
VECI Vehicle Emissions Control Information
VIN Vehicle Identification Number
VREF Voltage Reference
VSS Vehicle Speed Sensor
WAG Wild Seat-of-the-pants Guess
WOT Wide Open Throttle
WRT With Reference To (an administrative term)
ZF Some Crazy German hand-shaker Transmission
Last edited by SmokeyWren; 12-16-2008 at 08:49 PM. Reason: convert to VBulletin format
Larry M is offline
Old 05-07-2005, 07:08 PM   #2 (permalink)
Re: STICKY ... COMMON ACRONYMS
ACT - Air Charge Temp
AFAIK - As far as I know
BB - Big Block
BFH - Big F...... hammer
BHAF - Big Honkin Air Filter (Cummins way)
BP - Barometric Pressure
BW - Borg Warner Made T-cases, Turbos, etc
C6 - Ford Tranny used from ? to ?
CAC - Charge Air Cooler
CAT - Catalytic Converter
CTD - Cummins Turbo Diesel
DC - Diamler Chrysler
DMAX - Duramax Diesel
EFI - Electronic Fuel Injection
EVP - EGR Valve Position
FOMOCO - Ford Motor Company
FPR - Fuel Pressure Regulator
GPS - Global Positioning System
HTS - Hope this Helps
IFS - Independent Front Suspension
IIRC - If I remember correctly
IIRR - If I remember Right
IRS - Independent Rear Suspension
IMO - In my opinion
LED - Light Emitting Diode
LMAO - Laughing my *** off
LSD - Limited Slip Differential
NP - New Process Made T-cases, Transmissions
SB - Small Block
TOP - Turbo Outlet Pipe
(LarryM Theres a mistake on VIN)
Hellishstroke is offline
Old 06-11-2005, 07:42 PM   #3 (permalink)
My Photos: (6)
FWHP- flywheel horsepower -USA
FWTQ- flywheel torque -USA
FWHP- frontwheel horsepower -(Toyota's rumored diesel pickup)
FWTQ- frontwheel torque -(Toyota's rumored diesel pickup)
would the real whatabudro please stand up
whatabudroz is offline
Old 06-20-2005, 01:28 PM   #4 (permalink)
Hi Larry, what does HCFM mean? Seen it used here alot.
'05 F-250 Lariat crew cab FX/4 short box, auto, Lariat Luxury, upfitters, tow command, remote sensors, heck, everything but a moonroof!
2005 Honda Rancher 350
2004 Mahindra 6000
2002 PT Cruiser
RealRancher is offline
Old 06-20-2005, 05:51 PM   #5 (permalink)
My Photos: (11)
Actually it's the HFCM and that is the Horizontal Fuel Conditioning Module that is down under the driver's side seat along the frame rail. It incorporates several functions found in various locations on the 7.3L engine such as a pre filter (10 micron), water separator, fuel heater, fuel pump and the DTRM functions of the mixing chamber.
Larry
Last edited by SmokeyWren; 12-16-2008 at 08:54 PM. Reason: convert body to VBulletin format.
Larry M is offline
Old 07-07-2005, 11:38 PM   #6 (permalink)
drdenny1's Avatar
Larry
Larry,
What does DTRM stand for? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2000 F350 SD 4X4 CC LB Lariat
4"DPPI Turbo back
aFe Magnum
50/80/110 Bill's flip chip W/PMT1,and a DP 120
A-Pillar Autolites Trans/EGT/Boost-GOS Racing
APCM(AIC)
Boost Bleed off
4" Lift W/315's
Dual alt's.
ATS housing
Wicked Wheel
Banks 1.0 A/R housing
ISSPRO TTM
Warn Premium Hubs
J/S IDM
Racor 4500 CCV
ARG SuperPump and Gear
GOS Racing-Head Light Harness
2004 Sprinter 292FWRLS
SOLD: 97 F250HD CC SB 4X4 7.3L E4OD 4.10
drdenny1 is offline
Old 07-14-2005, 01:14 PM   #7 (permalink)
ptsuperd's Avatar
My Photos: (28)
CRD Common Rail Diesel
TDI Turbo Direct Injection
ptsuperd is offline
Old 07-17-2005, 09:18 PM   #8 (permalink)
Send a message via ICQ to oldfatman7
FIPL ???
Thanks Dan
93 F350, 7.3turbo, E4OD cc dually 2wd
oldfatman7 is offline
Old 09-16-2005, 10:46 AM   #9 (permalink)
dvb
MIL-TP41 ... "Make it like the print for once"
Dan.
... 2002, F-350, Lariat, Oxford White, CC, 4X4, DRW, 172 WB, PSD, Auto Trans, Dana 60 front & 80 rear 4.10 axles, Camper Pkg, Dual Alt's, Off-Road Pkg, Class ? Hitch, Tubular Steps, ESOF, Adj. Pedals, Line-X bedliner, Three ISSPRO gauges, BrakeSmart brake controller, Oilguard bypass oil filter, Heater hose ball valve, Magnefine tranny filter, Magnefine power steering/power brakes filter, Baldwin coolant filter, Reese 20K 5'er hitch, Fumoto oil drain valve, Rancho RS9000X shocks, Centramatic wheel balancers on front & Rear, AIS air filter/intake system, Blue Ox Bedsaver, Truck Covers USA's "rigid roll top bed cover".
2006, (34') Hitchhiker II, 32.5 FKSBG 5'er
MOR/ryde "IS" suspension, Kodiak hydraulic disc brakes.
Not as lean, not as mean, but still a Marine ---- Semper Fi ----
http://community.webshots.com/user/xdvbx
dvb is offline
Old 10-08-2005, 02:55 PM   #10 (permalink)
My Photos: (5)
I've got one that you don't have listed
KYABB
Kiss Your Arse Bye Bye
Used in a Run Away situation.
Example: Assume crash position and KYABB [img]/ubbthreads/images/graemlins/smokin.gif[/img]
DED [img]/ubbthreads/images/graemlins/cool.gif[/img]
6.0L, F-250 XLT, Torqueshift, S/C, L/B, FX4, 3.73 LSA, T/C, ESOF, ASG, Upfitters, SEIC, Rhino
Truck Build Date: 02/05/05 Kentucky
Engine Build Date: 02/03/05 Indianapolis
RIP - '99 7.3L w/cackle F-250 XLT S/C, L/B
DownEastDiesel is offline
Old 12-16-2005, 04:09 PM   #11 (permalink)
AIH Air Intake Heater. Couldn't figure out what this was till I googled it and found it elsewhere.
'01 F250 CC SB 4x4 Platinum Edition. 4-speed auto.
Doggus is offline
Old 12-17-2005, 08:42 AM   #12 (permalink)
SmokeyWren's Avatar
My Photos: (44)
That's because somebody has bastardized the term. Ford calls it the Manifold Intake Air Heater (MIAH), and lots of folks drop the "M" and make it IAH.
We also have an Intake Air Temperature (IAT) Sensor, but folks usually don't call it the AIT sensor. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
SmokeyWren is offline
Old 04-06-2006, 01:10 AM   #13 (permalink)
My Photos: (22)
LPOP....Low Pressure Oil pump
Check out what I recently bought:
2002 Quicksilver Z06 Corvette
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red"> Carolina PSD club </font>
Get Your Tuning Here: www.DP-tuner.com and your Fuel kits here: www.ITPdiesel.com
TheHammer69 is offline
Old 04-17-2006, 02:39 AM   #14 (permalink)
Banned
My Photos: (38)
HTH = Hope This Helps
gregrob is offline
Old 04-17-2006, 11:23 AM   #15 (permalink)
My Photos: (22)
SKDO = Some Kinda Diesel Oracle
I still have the:
