7.3L Wiring Schematic Printable, very handy. - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 99 & up 7.3L Power Stroke Engine and Drivetrain > 99 & up 7.3L Power Stroke Engine and Drivetrain FAQ
99 & up 7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 99 & up 7.3L Power Stroke Engine and Drivetrain forum.
Old 05-19-2010, 12:08 PM   #1 (permalink)
van_350sd's Avatar
My Photos: (80)
Handy Wiring Diagram that shows a Paper Trail of how the Electrical System Works for the 7.3L Powerstroke Engines, all Trucks, Excursions, Vans.
It was a Copy I had to PhotoShop to make it Readable & Printable.
it's very detailed and shows how every wire for each component routes to the PCM.
Use the Page Setup Mac or Properties Win and Print the Image Orientation, click Landscape,
it will fit most of the page this way.
best,
Russ
2000 E350-Super Duty-ExplorerExt. Mobile LivingRoom-7.3LPSD-3:55LS-Dual AmsoilEaA Air Filters-AutoMeter Phantom Guages-Pyro(Pre)-Boost-Tranny+Hobbs Hour Meter-C2 Pyro(Post) WaterTemp - 4"SS MagnaFlow Wrapped w/ Thermo-Tec 2" Header Tape-SonnaxValve+Tricumulator Shift Springs-Mag-Hytec Tranny+Rear End Cover-1 UpFront Spring Option-Bilstein's-Centramatic's-35 Gallon MainTank+TraxII TransferFlow 27 Gallon Aft.Aux.Tank=62 Gallon Range-ACPM/AIC-DualBattery+Alt-450 FilterMAGx2-Fumoto-ALL Amsoil-Bob's 203*&Billet Housing-Alcoa Classics-Explorer Conversion Installed DynaMat Complete Interior - 4 Leather Captain Chairs/BackSeat/Bed-Hellwig Sway Front/Rear-48"Hi-Lift-C02PowerTank5#SnapOn1/2"ImpactMG725-H3RCleanAgentHalotron2.5#
van_350sd is offline
Old 05-19-2010, 12:20 PM   #2 (permalink)
handy indeed. Now I just need an engine run + line for my hour meter... (shameless threadsteal)
2000 F350 7.3l auto 4x4 CCLB Dually lariat, my new baby purchased 8-22-11 . 66/74/1.15 S300 turbo, TS chip from swamps (daily with 60 tune), HPX (not normal spot, using rear most ports), proper gauges.
1999 F250 7.3l auto 4x4 rclb (not 1999.5) ex-work truck. Now being used for parts due to engine problems . Mods:80 Econo tune from DP, straight piped, Coolant filter, WW, EBV delete, 203* t-stat, TC lockup switch+LED, Hutch mod, Harpooned fuel tank, above mirror gauges, engine runtime hour meter. Pre-pump spin on filter+water separator and much more to come.
AutoEnginuity w/ Ford Enhanced - Tampa Bay area, FL. Just buy me dinner + fuel
Demoh is offline
Old 05-24-2010, 03:29 PM   #3 (permalink)
MarcS's Avatar
Very helpful! thank you
MarcS
2001 F-350 CC LB Lariat 4x4. 135K.
Edge juice with attitude.
4" straight pipe.
K&N intake.
4" lift with 16's wrapped with 35's.
Transmission temperature gauge on steering column
-Possibly an ATS ported compressor housing, DP tuner, and some new gauges soon to come....along with some cosmetic touches
MarcS is offline
Old 05-25-2010, 12:02 PM   #4 (permalink)
woodnthings8's Avatar
Here is a slightly different version more specific to the '02 models.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 05-25-2010, 12:25 PM   #5 (permalink)
klhansen's Avatar
My Photos: (169)
Good stuff, guys.
Moving into the 7.3L Engine & Drivetrain FAQ subforum so it doesn't fall off the radar.
Hard or no-start? Check Here
klhansen is offline
Old 06-22-2010, 12:49 PM   #6 (permalink)
Originally Posted by klhansen View Post
Good stuff, guys.
Adding a PDF of this for downloading and printing along with basic DTC Code Diagnosis.
File Type: pdf 7.3L_Powerstroke_Powertrain_System.pdf (844.2 KB, 1121 views)
Ken
TSB Information
Old 08-04-2010, 07:13 PM   #7 (permalink)
Absolute's Avatar
can someone post the stereo schematic, my posts seem to have disappeared, and I need it, bad. got my stereo wired, all works but the back speakers seem low on power. They sound muffled, and I have to put almost all power to the back to make it sound even, if I move it slightly to the fronts, they take over and drown the backs. Could this be reversed + and - on the backs. Fronts sound good, wires to back must be right as they are working on proper sides, but just sound weak. More bass like, fronts nice sound, more treble. Any ideas
2002 F350 Super Duty, Crew Cab,Long box,4x4, 7.3 PSD,Full Load, Edge Evolution Juice Attitude chip and tuner for motor and tranny with 5 settings and change on the fly, nice rims, BFG all terrain Tires, tire pressure monitors
Absolute is offline
Old 11-02-2010, 10:18 AM   #8 (permalink)
as long as we are talking electrical i do not know if this is the right place to ask this, but in my 2002 f 350 7.3, i am having radio/power window problems. at any time, running down the road, engine running and parked, cold start, or any time my windows and radio go off. the clock display stays on, and i do not loose the memory. power may return at any time, 1 min to 1 day. i have changed the fuse panel, which worked for about 2 weeks, then problem returned. i have since tried ign sw, and moving/ replacing the acc delay relay, but problem persists. any thoughts on this??? even on a site like just answer, anyone that tries to fix it thinks about it then runs away. there are other posts on this site about the same problem. sorry for the long reply.
ibewjwjon is offline
Old 05-21-2011, 08:50 PM   #9 (permalink)
7.3stroke'n's Avatar
nice this is sweet
97 F-250 7.3L powerstroke HD 4x4 super cab short bed 5 speed manual shift. "Stanadyne additive 01 f-350 4x4 super duty 7.3l powerstroke dually.
7.3stroke'n is offline
Old 06-10-2011, 10:45 PM   #10 (permalink)
Any luck finding the problem? My windows, radio, dome light, gauges stopped working. All fuses are good.
Ram77mus is offline
Old 12-15-2011, 12:47 PM   #11 (permalink)
Buford_T_Justice's Avatar
Hope this helps. (attached should be a PDF if I did it right)
Buford_T_Justice is offline
