Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain > 7.3L Power Stroke Engine and Drivetrain FAQ
7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 7.3L Power Stroke Engine and Drivetrain forum.
Closed Thread
Old 11-28-2008, 04:42 AM   #16 (permalink)
415_dezl's Avatar
How many miles should you change the gold coolant out...when it's been in there since new? What's the interval? I'm running the original..i thougth i remember 100k miles...am i way off?
2002 F350 Lariat CC SRW 4x4 LB , Shadow Gray, Edge 4.5" w/ dual bilsteins up front/ Toyo Open Country M/T 315-75-16. Stock Motor 7.3, dual alts / 3 guage pillar pod, Auto Meter/ 5" turbo back magnaflow exhaust w/Aeroturbine muffler & 6" Jardine tip/ Husky 24k 5th wheel / Air Lift Bags.
John Wood Transmission / DP tuner / 08' rear diff cover
2005 40' Weekend Warrior 5er, SLC 3905
1977 Tahiti 21' / Berkeley Jet Daycruiser/ 455 Olds.
2000 Sandcars Unlimited / Turbo VW 2275
1988 Ford Thunderbird Turbocoupe 2.3
415_dezl is offline
Old 11-28-2008, 08:12 AM   #17 (permalink)
SmokeyWren's Avatar
My Photos: (42)
Ford says change it the first time at 5 years or 100,000 miles. After the first time, change it every 50,000 miles.
SmokeyWren is offline
Old 11-28-2008, 08:20 AM   #18 (permalink)
415_dezl's Avatar
wow, i'm ready to do it then. DO you guys change hoses no matter what? or have you had luck with a visual inspection. Mine look like they do since day one...is this just being ignorant or should i just change em out
415_dezl is offline
Old 11-28-2008, 05:44 PM   #19 (permalink)
Banned
I wouldn't take that to the bank...Ford says the same thing about their little Focus and the rest of their gasoline engines too.
In fact, Ford says a lot of things...Like your rear differential is lubricated for life...or just add 8-10 oz of SCA to the green coolant every 15K miles rather than use a test strip...etc. But as enthusiasts, we know better. We know our diesel engine has special coolant needs, and that there are more robust coolants available than Ford's Gold.
The Gold is a universal, one-size-fits-all hybrid that contains conventional components, like silicate. And therefore, in a diesel, it should be treated like a coolant that contains those conventional components.
3-years/50K miles is a good change interval for any diesel enthusiast using a coolant containing conventional components. There are better, more robust, longer-life heavy duty diesel coolants available. I listed some in my flush procedure.
It's every 3 years or 50,000 miles, whichever comes first.
Gooch is offline
Old 04-01-2009, 03:17 PM   #20 (permalink)
Coolant filter Location???
Where is the filter in a 2001 Ford 7.3?
Ronchapman is offline
Old 04-04-2009, 08:17 PM   #21 (permalink)
klhansen's Avatar
My Photos: (107)
Unless you add one, there's no coolant filter on a stock Ford 7.3L.
Click on the link in my signature for the location of mine (aftermarket).
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 10-06-2009, 02:54 PM   #22 (permalink)
Buzzard Wing's Avatar
Thanks Gooch! You are really a wealth of information and I appreciate you helping to make it painless.
For disposal of the old antifreeze, I had two options... one was to go to the state sponsored 'hazardous waste' event (well done and free here in RI). But one of my tractor buddies was looking to 'load' his rear tractor tires. Usually they are loaded with calcium chloride (SALT!). The old stuff tested good for temp, so I also saved some to keep on the barn up north. Always good to have some 'spare' stuff around.
I was able to get Rotella ELC by the case for about $14 a gallon. I sent Shell an email asking about it's use in my 2.2l 'Ecotec' Chevy (dex-cool filled aluminum block) as it seems to be a perfect replacement coolant in a 5 year old car. They replied quickly and it's OK as long as it's well flushed (and not in warranty). So I will flush and fill that with one of the 'spare' gallons (holds 8.6 Q).
Also, the new thermostat I got from the dealer has a gasket built in. I bought a gasket anyway, good thing because the old one leaked like crazy with no thermostat (very dried out).
Sure am glad I found Gooch's post!
Larry in RI
Also
01 SD 7.3 PSD
Buzzard Wing is offline
Closed Thread
