Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain > 7.3L Power Stroke Engine and Drivetrain FAQ
7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 7.3L Power Stroke Engine and Drivetrain forum.
Old 06-14-2008, 06:02 PM   #1 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Cool Forged Rods? - How can I tell?
This is a frequent question on the forums and short of looking for yourself through the inspection port, it was hard to know for sure because apparently some later engines had forged rods after the initial introduction of PMR. I found this recent message on the Hypermax site re:forged rods.
Here is the engine serial number break down for the forged and powdered connecting rods. Check you engine serial number on the valve cover build sticker or you need to look at the block where the oil cooler is bolted to it .
Start of production thru 1425746 are Forged Rods
1425747 thru 1440712 are Powdered Rods
1446713 thru 1498318 are Forged Rods
1498319 thru final production run are all powdered
Or you can break them then you know what you have-Ha Ha-Just kidding
The reason for the break in serial numbers is a "test" run to be sure there were not any issues with the powdered rods. Once the process was production tested the powered rod process was used until the end of production.
Moderators: Perhaps you can make this a sticky as it is a frequently asked question.
haul_n_horses2 is offline
Old 11-25-2008, 04:10 PM   #2 (permalink)
Does anybody have any info as far as dates of production for the listed numbers? I can only read the last three digits on my valve cover and can't find it on the block. Manufacture date listed below the serial number however, is 25 Aug 00.
Anybody know?
2001 F-350 Crew Cab XLT PSD 4x4, Long Bed, 6-speed, 3.73, Manual Transfer, Power TTT Mirrors, 122k miles.
1989 Toyota 4x4 xtracab SR5 V6, Beat to heck with 200k+ miles and still running strong.
catch&release is offline
Old 11-25-2008, 04:47 PM   #3 (permalink)
their was a guy on this site that had all the details for the all the international diesels from the 6.9 right threw the last 7.3 powerstroke. It gave all the updates and changes threw out the entire production cycles for all of these engines. I believe that it was posted in the idi forum. If I remembered correctly it said that up to 2001.5 7.3 powerstroke had forged rods. hope this helps.
macmaniac1 is offline
Old 05-21-2009, 12:50 AM   #4 (permalink)
checking for Forged vs. PMR
Do you guys get this # off the left valve cover off a small white sticker?
If so I got #1566660. Also found BE 002 AA, 15 JAN 2001,
1NVXH07 3ANA do these other mean anything? thanks
2001 Black F250 XLT CC SWB 2WD PSD Auto 3.73ls. MBRP T-409 4" Exh., GTP38R turbo, gutted EBV housing & non-EBV pedestal, Diablo 100hp chip, DieselSite boost relief valve/H.D boots/H.P. X-over line/AIH delete/ 203* T.S. w/ billet housing, custom 12" K&N cone filter intake, Turbomaster wastegate. B&W turnover ball, Edelbrock IAS shocks (hate'm), FTVB, Powerslot Cryo rotors F&R, PML diffy cover w/ RP oil.
on 10-16-09 New Moog ball joints, Ford steering box/water pump/belt idler/tensinor/Belt, rebuilt L/S. and a worn out super loose OE converter. miles 206,011
sam2 is offline
