Originally Posted by RV JUNKIE 350-2000
Does Any One Know Which Way The Little Yellow Handle Face In The Off Position, (fuel Filter Drain Valve )on The 2000 F350 7.3 Litre? Mine Is Stopped Up And No Fuel Is Draining From Either Position. Thank You
I'm not sure on your 2000 but it should point to the passenger side to drain. If it doesn't even with the lid cracked open try it with the engine running.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
