Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain > 7.3L Power Stroke Engine and Drivetrain FAQ
7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 7.3L Power Stroke Engine and Drivetrain forum.
Old 10-30-2006, 06:23 PM   #1 (permalink)
Fuel Filter/seperator drain o-ring replacement...my first write up
[moderator's note] The photo links in this post are broken, but one of the members (his one and only post) put together a PDF of this post with the photos here: http://www.thedieselstop.com/forums/f47/fuel-filter-seperator-drain-o-ring-replacement-my-first-write-up-125558/index13.html#post1484534
[/end note]
well,...mine started leaking last week....noticed the raw fuel smell and diesel on my front axle....
went to ford and they wanted close to $40 for a "kit"...so i searced around locally and found some 1/2"od x 1/4"id x 1/8" thick orings from a place called filter services in se portland....payed $.30 for both...
on with the tech....
find the tube on the passengers side block......
drain tube
thats the drain tube........hook up a hose long enough to reach a bucket (so it dont just dump fuel right onto the ground and make a mess).....
hose placement
remove the cover that goes over the fuel filter housing (this is a good time to replace the filter).....
filter cover
removed......
cover removed
find the drain valve behind the filter housing and move the yellow lever to the right to drain the fuel from the filter housing.....
yellow lever
lever turned and draining
this is where the bucket and hose comes in handy......
bucket
let it drain completely,...then your ready to pull it apart....heres what i used.....allen style torx bit.....this is a #20 torx.....this seemed alot easier than a bit in a 1/4" drive ratchet,...but use whatever works for you,...its very tight back there.....
#20 torx
once removed,...take the assembly to a clean dry place and remove the old o-rings from the back of the valve.....
removed...
o-ring comparison.....
i used a pick tool to remove the old o-rings......to install the new ones,...just push them into place and they will fit like a glove
o-rings installed
now just put it back together and remove hose and discard of the fuel properly.....
before cranking it up right away,...get in and turn the key and wait for about 60 seconds for the fuel pump to fill the filter housing back up....
done!!
99.5 powerstroke f250 lariot 4x4,...6" lift...17"x10" amp wheels...37"toyo mt's...3.5 dp,..4" straight pipe side exit,..di 4-way chip..50/70/110/140 hp tunes,..t/c lockup mod,..afe stage 2 intake,...ats housing....gauges,...big head actuater,..ccv mod..
87 sami with yota axles...529 gears...spool rear...lunchbox front...3-link and volvo coils....rears up front shackle reversal...4:16:1 t-case gears...34/10.50 ltb's.....diy beadlocks..
joedirt is offline
Old 10-30-2006, 08:30 PM   #2 (permalink)
My Photos: (21)
Re: seperator o-ring replacement...my first write up
Nice write-up! hopefully a moderator will make this a sticky...I have a feeling this procedure will come in handy over the next few months...
Chris
1999 F-250 Power-Stroke
Crew Cab Shortbox Lariat 4X4
Fumoto, Turbo-Master, MBRP 4", Billet Triple Disc TC, HD TransGo Tugger, AIS, Triple Pod, Autometer Phantoms, SPDiesel Overboost Eliminator, SCT Tuned by Tadd @ Elite Diesel Performance 75/100/125 and DP-Tuner 80 Econo PCM, Sirius Radio...
2006 Jeep Liberty Sport CRD 4X4...
MY GALLERY
Tough_Guy is offline
Old 10-30-2006, 08:48 PM   #3 (permalink)
yeah, I'm not sure if its age, cold, fuel, or a combination that is causing the o-ring failures. But I put it up there with the cps failure. Its not IF its gonna fail, but WHEN its gonna fail.
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
Old 10-30-2006, 09:09 PM   #4 (permalink)
Good Job!!!
Early 99 F-250 Super duty 7.3 PSD Lariat 4x4 SC SRW. Front leveling kit,BFG 295.75.R16. Coolant filter kit, AIS air filter,UNITY spotlights, Sylvania Silverstars, ISSPRO EV A-Pillar gauges, FTVB. Dark burl wood dash kit.Warn Premium Hubs.Heater core bypass mod.
Intercooler boots from Bob Riley.MBRP 4" turbo back T-304 stainless exhaust.Diablo Predator programmer. Heated, lighted Trailer Tow Mirrors with on/off switch. 2003 oem headlights. Wet Okole seat covers. Oil Guard.
Dieselsite fuel pressure regulator. ITP Diesel Stainless HX crossover.Husky Liner floor mats.Wolverine oil pan heater.Dynatrac hub/bearing kit.Isspro EV Oil,Water temp,& Volt in above mirror pod. 7.3 Powerstroke stainless engine cover.Headlight wire harness upgrade.Stainless rear fender liners.AirDog FP100.Fluidampr.SDHQ SS Brake Lines.DTLS.BTS trans & 6.0 cooler.87 F250 XLT Lariat 4x4. C6 auto. U.S.Gear Overdrive. ATS Turbo. Coolant filter kit.
xlrs is offline
Old 10-31-2006, 12:24 AM   #5 (permalink)
some more info to add.....
For those that are interested, the "Ford Kit" is the following part numbers:
94-98 F5TZ-9A153-A
98.5-03 F81Z-9A153-AA
The O-rings themselves should be a standard #202 o-ring (on the 94-97 trucks, I dont know on the 99+ trucks). Make sure to get VITON, as some rubber O-rings do NOT get along with diesel or Bio-Diesel.
joedirt is offline
Old 10-31-2006, 02:12 AM   #6 (permalink)
jgarden's Avatar
Post deleted by klhansen
TDS member #49 - 1999.5 (Built 4/26/99) White F350, CC, SRW, LWB, Lariat, AIC, 4R100 (4th transmission before 85k - gotta love this tranny), 6.0 trans cooler, manual shift 4wd, 3 inch leveling kit, KING reservoir shocks, 285-75-16 Bridgestone REVOs, Performance Friction Pads all around, Powerslot Cryo'd rotors in front, CD player, Infinity REF 6800CS speakers (front and rear), Garmin 2610 GPS (hardwired), 40/20/40 leather seats, heated turn signal- TT mirrors, Titan V hitch, weatherguard box, DP Tuner 4 Position chip (love it), AIS intake, Diesel Site CAC Boots, 4" Magnaflow exhaust, Diesel Innovations Up Pipe, gutted EBPV, Non EBPV Turbo Pedestal, X-Monitor. NO STEERING WHEN BRAKES ARE APPLIED!
Jack
jgarden is offline
Old 10-31-2006, 07:11 AM   #7 (permalink)
I just odrered a bag of the correct o-rings for this application.The o-rings I ordered are made of Viton which has excellent chemical and oil resistance. Temperature range is -15° to +400° F. Durometer hardness is A75. Meets SAE J200.Other guys have used different kinds of rubber but I understand Viton is suppose to be the best for this application. O-ring size 1/2"OD X 1/4"ID X 1/8" thick.The drian valve at the dealer is about $38(includes o-rings), the o-ring kit (4 o-rings) is about $32. When I ordered the o-rings I have, they came in a large quantity.
I have more than I need if you would like to buy a couple of them P.M. me. ($5.00 a pair)
2000 F550 Rollback: Diablo Predator, HX, AFE stage 1, Zoodad, Walker BTM, so far.....
1990 F350 Rollback: 351W, C6
No_Neck_Shrek is offline
Old 10-31-2006, 10:20 AM   #8 (permalink)
HEY MODERATORS!
STICKY THIS THREAD PLEASE! GOOD JOB!
2000 F-350 SRW SB Lariat 4x4 195,000 miles and counting
1982 Jeep CJ-8 Scrambler
1950 Willys Jeepster VJ
http://www.rocketcityrockcrawlers.com/
Pics: http://community.webshots.com/album/347951916ylEtYs
cj8lvr is offline
Old 10-31-2006, 11:54 AM   #9 (permalink)
Check out www.oringsusa.com, I have ordered O-rings there before and they have excellent service and pricing. The 202 Viton rings are 50 cents apiece, cheaper (17 cents) if you want large quantities. They ship regular mail quickly.
Greg
2002 F350 XL SC Dually 4x4 7.3 PSD 6spd LB
Sunups Starwatch, 1995 Quarter Horse stallion, 11 points calf roping, 5 points heeling, Open ROM, MQHA Res. Champ. Aged Stallion
1984 F250 XL 4x4 6.9 LB Dually conversion
2006 VW Golf TDI 5spd
1977 Case 1070 6 cyl diesel
1992 Bobcat 742B 4 cyl Mitsubishi gas
1958 Ford 961 narrow front 4 cyl gas 5 spd
Gregbooth is offline
Old 11-02-2006, 09:27 AM   #10 (permalink)
My Photos: (5)
I went to the oringsusa website and they have 3 different types of viton o rings. There is viton 75, 75brown and viton 90. Which one is appropriate for our application?
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 85,100 miles. truck Pictures
clydesdale is offline
Old 11-02-2006, 11:26 AM   #11 (permalink)
My Photos: (22)
either one of the 75's should work.
Hammer
Check out what I recently bought:
2002 Quicksilver Z06 Corvette
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red"> Carolina PSD club </font>
Get Your Tuning Here: www.DP-tuner.com and your Fuel kits here: www.ITPdiesel.com
TheHammer69 is offline
Old 11-02-2006, 12:05 PM   #12 (permalink)
My Photos: (5)
Thanks, I ordered from oringusa. They will ship us mail, so the cost will be under 5 bucks for orings and shipping. Thanks
Old 11-02-2006, 01:07 PM   #13 (permalink)
2003f350's Avatar
I was just going to order from them also, but when I went to check out they were going to charge me $10.00 for shipping for 6 small o-rings. How did you get o-rings and shipping for under $5.00 ????
Thanks Ed
2003 F-350 Lariat Supercab 158" WB, 3.73 LS axle
7.3 PSD, auto trans. camper pkg. 12,500 lb. hitch,
adj. pedals. roof lights, Toreador Red, Arizona Beige, Power telescoping mirrors, and C-Betr mirrors. Delivery date Aug. 5, 2002. Reese 16K hitch, Thor Citation- model 29 5P 5th. wheel, Rhino liner.
2003f350 is offline
Old 11-02-2006, 01:10 PM   #14 (permalink)
My Photos: (5)
Yep, I called them. Just click the option that is for "collect" or something like that. Then in the comment box, write "please send us mail and you have my permission to charge my card the postage". They qouted me roughly $1.80 to cover shipping.
Old 11-02-2006, 01:13 PM   #15 (permalink)
2003f350's Avatar
THanks for the quick reply, I 'll try what you did and see what happens.
Thanks Ed
2003f350 is offline
