Fuel Filter/seperator drain o-ring replacement...my first write up - Page 10 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 99 & up 7.3L Power Stroke Engine and Drivetrain > 99 & up 7.3L Power Stroke Engine and Drivetrain FAQ
99 & up 7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 99 & up 7.3L Power Stroke Engine and Drivetrain forum.
Old 02-06-2007, 02:10 PM   #136 (permalink)
Re: Fuel Filter/seperator drain o-ring replacement...my first write up
Small parts cost $4.95 for 25 O-rings, but my shipping cost $8.95 from Florida to Arizona.
AZF350 is offline
Old 02-06-2007, 02:24 PM   #137 (permalink)
I am going to be changing my O-rings this weekend, I want to change the filter too. Is there any suggestions on make and/or part numbers that work best? I have Ford, NAPA and all the other standard parts stores to choose from, but I want something that is not going to hurt my performance or do any harm to the engine. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
AZF350 is offline
Old 02-13-2007, 04:03 PM   #138 (permalink)
Thanks for the excellent post.
I finally got around to changing my o'rings after putting it off for a while. They finally started leaking at a constant drip, so I had no choice prior to heading up to the Bud Shootout last Saturday.
All I have to say ,is I hope ,( for his sake) that I never meet the guy that designed that blasted set up. It was the biggest PITA I could imagine. I would have easily rather R&R'd the transmission or re-braked all four corners. Maybe some sort of specialty tool might have made it easier but my fingers simply don't contort like what is neccesary to accomplish this task. It finally got done though, thank god!
If it ever leaks again. Someone else will be dealing with it.
2002 F250 CC 4X4 Lariat, Really Red, 5 bar TS Toolbox, Extang toolbox toneau, 285/75/16 Bridgestone Dueller AT revos,DPPI 4" 304SST exhaust , AFE Magnum intake w/ PG7,, Autometers , Excur sound insu. panels, pre-pump mod done, in tank mod soon. Suncoast SD21 triple,Suncoast 4R100 Guts, trans-go tugger w/pos lock.Tru-cool Max cooler, remote trans filter, Awesome 4 progam chip from Jody Tipton @ DP tuner purchased thru twildman
cherrybombboat is offline
Old 02-14-2007, 04:23 PM   #139 (permalink)
detroitfd's Avatar
Just did mine. Like others have said, what a royal PITA getting to those 4 bolts.
Someone suggested taping the torx bit in...GREAT idea. I dropped in twice before I remember to tape it. [img]/ubbthreads/images/graemlins/wink.gif[/img]
I don't think mine really needed replaced, as there was just some grime on em, but obviously I replaced em anyway since I already bought em.
Thanks!
Jerry
My PSD X
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, Decel, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ S&B conical filter - Zoodad mod - Suncoast Extreme Duty Trans rebuild w/ TransGo Shift kit, Amsoil synthetic ATF & Magnefine inline filer - BD Triple Disc Billet Torque Converter - 4" Stainless Steel Turbo Back (4" down pipe) Magnaflow exhaust - ATS Turbo housing and 4" intake sleeve - Turbo Master Wastegate Controller - HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter w/ CAT ELC coolant - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge cluster face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub - 4.5" LED marker/turn lights in front bumper - ViAir HD onboard air system w/ 380C compressor, 2.5 gal tank & Grover stutter tone air horn - FireStone RideRite suspension air bags -
TOWING:
2004 Dutchmen 31BH travel trailer
detroitfd is offline
Old 02-17-2007, 08:06 PM   #140 (permalink)
drdenny1's Avatar
Another satisfied customer. 20 Minutes. $5.00 No more leak!!! [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
Thanks guys!
2000 F350 SD 4X4 CC LB Lariat
4"DPPI Turbo back
aFe Magnum
50/80/110 Bill's flip chip W/PMT1,and a DP 120
A-Pillar Autolites Trans/EGT/Boost-GOS Racing
APCM(AIC)
Boost Bleed off
4" Lift W/315's
Dual alt's.
ATS housing
Wicked Wheel
Banks 1.0 A/R housing
ISSPRO TTM
Warn Premium Hubs
J/S IDM
Racor 4500 CCV
ARG SuperPump and Gear
GOS Racing-Head Light Harness
2004 Sprinter 292FWRLS
SOLD: 97 F250HD CC SB 4X4 7.3L E4OD 4.10
drdenny1 is offline
Old 02-18-2007, 07:08 PM   #141 (permalink)
my 16 yr old son did his 00 f250 in about 45 mins. but when looking at my 97 its different(only 2 screws not 4) and the thread from our forum just shows pics from a fuel bowl that has been removed. my question is can i replace my orings without taking the bowl out? thanks.
2000 excursion superchips progamer,(ole ladies ride) no fuel milage increase but the power is there.
2000 f250 4x4,hypertech tuner ,no kitty,4in exhaust turbo back , air raid filter
97 f350 psd, c/c, 4x4,3.55ls, 285/75 goodyear MT/R's
shimmed w/ calif. kit, 10k mod, ported snorkel,hypermax downpipe,ps2000 propane
45hp superchip,pcm code TDE1, TEXAS TROPHY HUNTERS decal!!
looking for hunting opportunities in the north mississippi area or s/w tennessee, deer and hogs , let the littles ones walk
missplaced texan is offline
Old 02-18-2007, 10:33 PM   #142 (permalink)
olddieseldude's Avatar
My Photos: (16)
Check this out from the 94-97 section...
RickN
White '99+ F250 SD XLT 4x2 SRW, 7.3PSD, 6spd, SuperCab, Short Bed
(mods listed in comments under photo in above link)
olddieseldude is offline
Old 02-19-2007, 09:26 AM   #143 (permalink)
Just did mine this weekend.Thanks for the post.Mine was leaking pretty bad.Did a search on the site and there was the fix.Thanks guys.
John
1999 F-250 Extended Cab,4x4,Auto Tranny,Westach Boost and EGT gauge,Auto Meter Tranny Gauge,BDS Leveling Kit,4" Bully Dog Exhaust,BFG A/T Radials - Bobby Orr is still the best Hockey player in my book
http://community.webshots.com/user/seanpatsdad
Seanpatsdad is offline
Old 02-22-2007, 10:40 PM   #144 (permalink)
dvb
Just stumbled across this thread .... just for the record my 2002 has 3 0-rings in the "yellow lever assembly". There is a 3rd o-ring inside the drain valve tube assembly .. where the yellow lever attaches to the white plastic ball valves.
You can push out the white plastic ball valves from within the black mounting tube and you will see the 3rd o-ring.
Dan.
... 2002, F-350, Lariat, Oxford White, CC, 4X4, DRW, 172 WB, PSD, Auto Trans, Dana 60 front & 80 rear 4.10 axles, Camper Pkg, Dual Alt's, Off-Road Pkg, Class ? Hitch, Tubular Steps, ESOF, Adj. Pedals, Line-X bedliner, Three ISSPRO gauges, BrakeSmart brake controller, Oilguard bypass oil filter, Heater hose ball valve, Magnefine tranny filter, Magnefine power steering/power brakes filter, Baldwin coolant filter, Reese 20K 5'er hitch, Fumoto oil drain valve, Rancho RS9000X shocks, Centramatic wheel balancers on front & Rear, AIS air filter/intake system, Blue Ox Bedsaver, Truck Covers USA's "rigid roll top bed cover".
2006, (34') Hitchhiker II, 32.5 FKSBG 5'er
MOR/ryde "IS" suspension, Kodiak hydraulic disc brakes.
Not as lean, not as mean, but still a Marine ---- Semper Fi ----
http://community.webshots.com/user/xdvbx
dvb is offline
Old 02-22-2007, 11:10 PM   #145 (permalink)
That Drain Valve Stem Top O-Ring is a AS568A-013 O-Ring. So far I haven't read of anyone having any leakage from that location.
2000 F250 SD Lariat, SC, SB, 4x4, 7.3L PSD, 6-Spd ZF, 8,800 GVWR, 20,000 GCVW, Reese Class-V Tow Beast Receiver Hitch, Prodigy V2.6, 4" MBRP Stainless Steel Exhaust, AIS Induction Air Filter, AutoEnginuity
2002 26' FT2200 Weekend Warrior Toy Hauler, 102" Wide-Body, 11,100 GVWR, Reese Titan 14,000 lb Trunnion Heavy Duty WD Hitch, DC HP Sway Ctrl, Onan 4BGE-P Emerald Plus GenSet
jlrsn is offline
Old 02-24-2007, 08:00 PM   #146 (permalink)
Hi,
Thanks very much for all the great info!
I chickened out and bought a new drain valve because
it was so hard to get the thing off (E-350 VAN).
It took me all day to get it done, but no leaks so it
was worth it.
If there was a problem I wanted it to be possible to
get it back together over a weekend.
Also thanks to the person who posted the Parker Vibra-loc
Mcmasters-carr numbers, I bought bags of 10 each and sure
enough, some are now lost in the valley somewhere, never to be seen again.
Frank
1983 300TD = Retired: (Diesel yard ornament) 369,000
1985 300SD = Son's Diesel cruiser 350,000
1985 300TD = Dad's Diesel wagon 180,000
1992 Kubota Diesel tractor = mutant lawn mower 340hrs
2000 Ford Powerstroke Diesel = Wife's Toyota crusher 225,000
2004 Chevy Blazer = Daughters gas SUV 46,000
tcnofh1 is offline
Old 02-24-2007, 11:49 PM   #147 (permalink)
again my question is what do i need to move out of the way to get to the 2 screws on my 97 they are at the bottom. so i dont take too much off. the pics the 1 guy gave is of a removed fuel filter bowl my daughter could change the o-rings out if that were the case. if i gotta take the filter bowl off for access i will but i just didnt want to over do it.thanks
Old 02-26-2007, 04:02 AM   #148 (permalink)
klhansen's Avatar
My Photos: (169)
Another member posted that question in the thread where I posted the pics. I had to tell him that I didn't know, as the fuel bowl was borrowed for the pics.
I'd suggest you post your question in the 94-97 forum. I'm sure someone there will have the answer.
Hard or no-start? Check Here
klhansen is offline
Old 02-26-2007, 12:24 PM   #149 (permalink)
joedirt's Avatar
damn,...this thread took off fast...lol...
1994.5 f250 powerstroke, 4" exhaust straight piped, 5-speed, tymar, edge ez, standard cab
joedirt is offline
Old 02-26-2007, 10:06 PM   #150 (permalink)
klhansen's Avatar
My Photos: (169)
Good stuff, and helped along by the ULSD issue.
Doesn't hurt that it's at the top of the list, either. [img]/ubbthreads/images/graemlins/grin.gif[/img]
klhansen is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
