Fuel Filter/seperator drain o-ring replacement...my first write up - Page 12 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 99 & up 7.3L Power Stroke Engine and Drivetrain > 99 & up 7.3L Power Stroke Engine and Drivetrain FAQ
99 & up 7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 99 & up 7.3L Power Stroke Engine and Drivetrain forum.
Old 05-29-2007, 12:26 PM   #166 (permalink)
Re: seperator o-ring replacement...my first write up
Good info so I ordered 10 from Oringsusa and they should be here in a few days.
I had some extra ones from Home Depot when I did this about 3 years ago but could not find them. They were just plain rubber and lasted as long as the originals. They started leaking a couple of weeks ago. I used a Craftsman ratchet tool to do mine the last time and it took about half an hour.
Just in case I am going to pickyp a couple of extra screws from the dealer in case I drop one.
2OOO F-250 4WD Crew Cab, 248,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator H2O Pump. AIS Severe Duty Filter, Switched 10K MOD, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Optima Redtops,Mesa, Arizona
PRDATR is offline
Old 07-01-2007, 11:02 AM   #167 (permalink)
Re: Fuel Filter/seperator drain o-ring replacement...my first write up
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
Toreador Red '02 F250 Lariat SD 7.3 CC 4X4 SB AT w/ 180K miles. Installed '06 front end (Bumper/light assemblies/grille/fog lights) SiverStar bulbs in the turn signals. Upgrade from the dinky "sport mirrors" to the big tow mirrors with lights and heated glass - 90hp Superchip Performance-Tow program. Quad door pillar Pod w/Boost/EGT/Voltage/Tranny Temp gauges. Magnaflow SS 4" Exhaust w/5" SS Tip. AIS intake with fender sleeve and ZooDad Mod. Turbo Intercooler Pipe foil insulation removed, AIH Delete, CCV Mod, Wicked Wheel installed. Slotted and cross-drilled front brake rotors. Jimmy-Jammers on all four doors, Ford Factory alarm. Garmin 2720 Navigation System with traffic receiver. AirLift Super Duty brand air bags on rear springs. Centramatic Wheel Balancers on all four wheels. New 6.0 "31 row" tansmission cooler. Been running straight BioDiesel (B-100) (made from soybeans, palm oil, and cotton seed oil) for the last 60K.
rmd1960 is offline
Old 07-01-2007, 03:41 PM   #168 (permalink)
Folks,
Dumb question: Is the size of the O-Ring a #90 or #202...I see both numbers referenced in the great attachments!
Thanks,
Shamish
2002 F250 XLT 4WD SC SB with 6 Speed and Manual Shift Transfer Case. Pillar pod-o-gauges, Warn Premium Hubs, AIS, Fumoto, Edge 3” leveling kit on the front (with adjustable pan-rod bar), 4” blocks on the rear, Eaton Posi, Bilstein 5100s and 285 X 75 X 16 BFG MTs all around. Oil pan coated with POR-15 and Silver Krylon (to reflect the mind-rays). Fleetrite ELC and Dieselsite coolant filter.
Shamish is offline
Old 07-01-2007, 05:20 PM   #169 (permalink)
Viton AS568A-202 O-Ring Seals.
Good luck,
Jim
2000 F250 SD Lariat, SC, SB, 4x4, 7.3L PSD, 6-Spd ZF, 8,800 GVWR, 20,000 GCVW, Reese Class-V Tow Beast Receiver Hitch, Prodigy V2.6, 4" MBRP Stainless Steel Exhaust, AIS Induction Air Filter, AutoEnginuity
2002 26' FT2200 Weekend Warrior Toy Hauler, 102" Wide-Body, 11,100 GVWR, Reese Titan 14,000 lb Trunnion Heavy Duty WD Hitch, DC HP Sway Ctrl, Onan 4BGE-P Emerald Plus GenSet
jlrsn is offline
Old 07-01-2007, 08:04 PM   #170 (permalink)
If you are getting them from O Rings USA they are the -75 202.
I believe the ones I bought a few years ago at Home Depot were trade size 90, so probably both.
The size is 1/2 1/4 x 1/8
PRDATR is offline
Old 07-29-2007, 08:28 PM   #171 (permalink)
I replaced my O rings with Viton #202's about 5 months ago and they have already started to leak. I checked with the local dealer and he said he is selling a lot more drain kits and doesn't know why, I suggested it might be the age of the equipment or ULSD or both, he wanted over $80.00 for the kit, thanks but no thanks, replaced the rings again and everything is dry as a bone. Has anyone else had such a short life out of a set????
2002 F350 7.3 SRW Lariat ext. cab, 6 spd, 4X4 long box, Banks 6 gun tuner, 4 inch monster exhaust, Stancor GPR, Rancho 9000's, Zoo Dad, Dieselsite boots, Rhino spray on liner, 203 thermostat, South Bend clutch, Bellowed up pipes, coolant filter, AFE, CCV mod, 19.5 Rickson wheels with 245/70/19.5 Michelins, Power slot rotors and Hawk pads, Mag-Hytec differential cover, Sirius radio, Pillar gauge, Fumoto valve.
sixspeeddroner is offline
Old 07-29-2007, 08:37 PM   #172 (permalink)
Sabre2th's Avatar
Just curious, but do you happen to use any additives containing acetone? Viton doesn't like it..... And to the above posts that refer to these o-rings as being -75's or -90's, that's definately not the size. It's probably the hardness rating (durometer) 75 or 90 durometer are pretty standard for orings. The size required for our drain valves is #202, and on the ones that have the stem seal, it's #013.
Tom
Black 1999.5 F250SD XLT AUTO 4x4 reg. cab(6/99), Pre-pump & Tank Mods, AFE Intake, Racor Filter/Separator, HX Mod, ZooDad, WW, Power-pedal Mod, Pop-up gooseneck ball,Brush Guard, 3.5" lift, BFG Commercial AT tires (265/75), 65hp ATS chip, and #2 cologne. Ball joints replaced, and thinking about a BTM and shocks....!
Drain valve repair write-up with pics
Sabre2th is offline
Old 07-30-2007, 12:35 AM   #173 (permalink)
Only thing I've used since the truck was new is Stanadyne Performance Formula
Old 08-28-2007, 02:28 PM   #174 (permalink)
dieselpwrdude's Avatar
Swet deal E o thanks for writing that up.
2003 XLT 250 Ford Super Duty Ext Cab. PSD 7.3 Stock.
dieselpwrdude is offline
Old 10-28-2007, 09:13 AM   #175 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MaxRules</div><div class="ubbcode-body">Found my drain valve leaking yesterday. I ordered 10 Vitons from smallparts.com, only $5.60 shipped to me. My biggest concern is what this new diesel fuel is doing to the rest of the system/engine. There is absolutely no doubt in my mind this leak was caused soley by the ULSD. With all the sue happy people in this world, I'm suprised the EPA isn't paying for all these repairs yet. A lawyer should jump all over this. I might slip in a puddle of leaked diesel and spill hot McDonald's coffee on myself.</div></div>
I believe the concept of "Sovereign Immunity" would come into play.
GOD BLESS OUR TROOPS!! - GOD BLESS AMERICA!!
Rick M is offline
Old 10-28-2007, 10:51 AM   #176 (permalink)
Been thinking on this a lot since I have the smell, a puddle on the slab, and just ordered a kit from the e-bay site that has the three o-rings in it to effect the repair.
However, I find myself wondering about something, how does the o-rings we are replacing cause the fuel to drip from the drain tube? Those o-rings are for the seal between the fuel filter housing and the drain assembly so any leak they have would/should go into the valley. It would seem that when we see fuel dripping from the drain tube that there is a leak in the valve seat/seal itself. A comparison would be a faucet dripping versus the pipe threads between the faucet and pipe leaking. The faucet/pipe joint is what these o-rings are addressing, right?? And that leak should run down the engine not drip out the pipe, right?? Can someone help me with this? What am I missing in the equation??
Rick M is offline
Old 10-29-2007, 06:48 PM   #177 (permalink)
In case you're lost in this sea of posts, I highly recommend the method of using a small piece of plastic tube you can put your torx bit in while after the bolts are loose, it's a lot easier to spin the tube then a wrench or just the bit with your fingers.
1999.5 F250 PSD 4x4 SC - 305/70R16 Pro Comp A/Ts - 46637 DIY Intake - Auto Enginuity
Jett is offline
Old 11-01-2007, 04:24 PM   #178 (permalink)
Just got through changing my o-rings out. Took about 35-45 minutes, sped along by my neighbor's 1/4" air ratchet. Took my time and replaced the ring around the shaft. While it was out I noticed that the ball area of the fuel end had some of the yellow coating that was on the factory rings adhered to it so cleaned it off to get the ball slick. Wonder if those flakes would have been enough to cause a dribbling leak?
Rick M is offline
Old 11-02-2007, 01:03 PM   #179 (permalink)
Wanted to put this in an edit, but even though I am logged in the edit option does not appear.
Anyway, I am hoping the rings seat on the drain assembly balls because after a short drive yesterday to get the oil warmed up to change there was evidence of fuel leaking out of the extended tubing I had left on the metal drain tube. Maybe after it sets for awhile all will conform and not leak anymore. This is a real pain mechanism.
Rick M is offline
Old 11-07-2007, 12:33 PM   #180 (permalink)
06Clone's Avatar
My Photos: (5)
Haven't logged in in a year. Can anyone tell me what is the best drop in fuel filter for my 7.3? I was searching for a 1 or 2 micron drop in and found nothing for a 7.3 on Google.
Doug
06Clone is offline
