Fuel Filter/seperator drain o-ring replacement...my first write up - Page 13 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 99 & up 7.3L Power Stroke Engine and Drivetrain > 99 & up 7.3L Power Stroke Engine and Drivetrain FAQ
99 & up 7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 99 & up 7.3L Power Stroke Engine and Drivetrain forum.
Old 11-08-2007, 11:14 PM   #181 (permalink)
Re: Fuel Filter/seperator drain o-ring replacement...my first write up
Okay, I found this post because I have the fuel smell and a drip off of the engine. This is my step-dads truck. He had the leak appear last year about this time and it sealed up after a few hours and he hasn't seen it since then. That is what prompted me to start looking for a solution I changed the o-rings out this evening. Has anyone continued to have a drip after the fact, possibly from residual fuel on the valley still dripping down?
My drip is coming off of the dust cover. There is a little dimple on the very center of the dust cover that it seems like it is dripping out from.
I have fuel all over the valley and then this drip. Does this sound like the same issue? Have others had this drip from the same location? I think I read all but one page of this post. I probably skipped the page that says if your drip is off of the dust cover it is a different issue!
My next course of action is to check/change the WIF sensor o-rings.
Thanks for the help.
Jeff
Turbo1Ton is offline
Old 11-10-2007, 11:18 PM   #182 (permalink)
78Southwind's Avatar
Great post. I'll be changing out the o-rings when I replace the fuel filter.
2000 Excursion Limited (BUILD DATE
05/31/2000) 4X4, 7.3 PSD, 3.5" LIFT and SuperChip
78Southwind is offline
Old 11-11-2007, 03:16 PM   #183 (permalink)
Add another one to the list. Mine started to leak this week when the temperature dropped. Checked everywhere to find the O-rings, ended up ordering them through http://www.smallparts.com.Can't wait to change them.
Capt79 is offline
Old 01-16-2008, 02:14 PM   #184 (permalink)
fuel filter seperator drain o ring replacement
just got two new sets off ebay for a total of $4 with shipping got to me in less than a week their viton and their suppose to stand up to just about anything
2000 Ford F250 7.3l diesel of course with 137,086 original miles, new waterpump, AEM intake, ATS Turbo Housing, TS Performance 6 pos chip, guages (exhaust temp, boost, onboard air gauge), 4 inch MBRP exhaust to the turbo, CB Radio always on ch. 14, 60 gal. Aux. Tank/tool box in bed, Rotella Oil 15w40 soon to have HPOX on there, Train Horn hehe, Viair Onboard air (150psi),Pioneer head unit, some kind a drop in bedliner, 32in Nitto tires, and cant forget the pintle hitch
hit_cb is offline
Old 01-16-2008, 02:48 PM   #185 (permalink)
Anyone have a set they want to sell me for cheap? I was thinking about changing my fuel filter so I might as well do this at the same time.
2002 F250 Crew-Cab Short-Box 4x4 Off-Road 7.3L
283 HP/ 570 Lbs/Ft
BTS Trans
BTS 4-Stage FlipChip
AFE stage 1 Intake System
Silverline 4" T-304 Stainless Turbo-Back Exhaust-Donahoe Racing "Edge 4.5" Plush Ride lift
BFG all terrain 35" tires
Niner1190 is offline
Old 01-21-2008, 02:06 AM   #186 (permalink)
Thanks for writing this up! I'm gonna get it done tomorrow assuming I can find the o-rings!
I wanted to be able to have the instructions with pictures with me when I do this so I made a pdf of the post with pics. o-ring replacement.pdf Hope it's not out of line to post this!
mrwink is offline
Old 01-28-2008, 12:58 PM   #187 (permalink)
With nice weather yesterday, I finally got around to doing this o-ring fix [fortunately, hadn't needed the truck recently ....]. As noted, the process is straightforward, but the space is so cramped that its a pain in the arse to unscrew the T20 torx screws and remove the valve. I couldn't find a 1/4 drive T20 socket closeby, so I ended up using one of those cheap 90 degree angled T20 key [like a hex key]. I don't have real big hands, but it was tough to fit back in there, especially spread-eagled over th engine and reaching down behind the filter. Ended up dropping the key, and one of T20 screws, down into the valley multiple times [requiring a second trip to the local Advance Auto for one of those flexible recovery grippers]. Ended up taking a couple hours, what with the trips to Advance, so be prepared. I had previously installed a drain line on the purge outlet, so I avoided any more diesel mess. As expected, this fixed the leak!
2002 F350 Supercab Lariat 4x4 7.3L 6 spd. B&W gooseneck, Prodigy brake controller, PAC exhaust brake, WARN manual hubs, Ford AIS, Bilsteins, Michelin LTX, Line-X bedliner, 203F t-stat, Cat ELC coolant, by-pass coolant filter.
Wife's Ride: 2006 Mercedes Benz E320 CDI
Riggodeaux is offline
Old 01-30-2008, 09:37 PM   #188 (permalink)
Motoman's Avatar
Wow good reading here.... just turned 103K on the odometer and saw a fuel leak. Glad to see the exact problem explained here. I went to smallparts.com and ordered the following:
ORV-202
1/4
1/2
1/8
0.234
0.005
0.139
0.004
$2.20
bag of ten.... 2.20 + 4.19 for shipping to AZ.
Will post up pictures of install when the o-rings get here!
Thanks a bunch for the sticky!
Motoman is offline
Old 02-06-2008, 07:43 PM   #189 (permalink)
Just changed out mine today. I used an adaptor, Spinner, 1/4" male to 3/8" female, that made things alot easier to turn those torx out by hand. Will be tough if you have large hands.
FSD38, Adaptor, Spinner, 1/4" male to 3/8" female
2000 XLT LARIAT CC SB 4x4, front leveling kit, rear add a leaf, hd overload spring pack, 3.5" down pipe, straight pipe, foil delete, K&N fipk w/dry charger, oil guard by-pass oil filter, coolant filter, ccv mod, 203* T stat & housing, brv+,redhead steering gear box, auto meter boost,EGT, rear diff and trans temp gauges, Frybrid wvo kit, 6.0 trans cooler, BTS trans, 4 position chip stock, hi idle, 60 hp and 100hp, ((XM radio))
MIspecial is offline
Old 02-16-2008, 11:58 PM   #190 (permalink)
Send a message via AIM to strokenazi45
i have a 2002 power stroke and i just had to replace the o-ring my self .they crack and the diesel eats them up .
strokenazi45 is offline
Old 03-09-2008, 02:49 PM   #191 (permalink)
joedirt's Avatar
been a while since ive been here,...glad its helped a bunch of people
1994.5 f250 powerstroke, 4" exhaust straight piped, 5-speed, tymar, edge ez, standard cab
joedirt is offline
Old 03-11-2008, 06:41 PM   #192 (permalink)
where can i get replacement bolts for the fuel drain kit i dropped one and cant find it ?
nbwilliamson is offline
Old 03-16-2008, 08:12 PM   #193 (permalink)
where to get o-rings:
your local industrial supply, like Welcome to MotionIndustries.com or Applied.com Industrial Bearings, Material Handling, Power Transmission, Fluid Power Products | Applied Industrial Technologies | Applied.com | Applied.com, they will probably have them in stock.
Failing that, go to the one stop shop like McMaster-Carr or MSC Industrial Supply Co. Home Page .... these guys have everything from fasteners to tools to just about any gadget you can think of.
'97 F350 4x4, AT, 110k miles, SRW, 4.10, CAT delete, Crew Cab, Hypermax DP, Chip, WD Filter, Autometer 3-pod pillar mount gauges, Tymar HX mod, -- Ebay ID: stfdfire --
kwitte is offline
Old 03-18-2008, 09:20 AM   #194 (permalink)
I have phillips head screws on my valve.
I have phillips head screws on my drain valve. I don't see where anyone else does. I have a 96. The number 20 torq bit didn't fit lol.
abamadude is offline
Old 03-18-2008, 03:53 PM   #195 (permalink)
klhansen's Avatar
My Photos: (169)
Maybe someone replaced them. The 94-97 fuel bowl I messed with had torx head screws.
Hard or no-start? Check Here
klhansen is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
