most likely they are metric...most of my hpop and fuel bowl bolts were.
I droped one of my thermostat bolts when i added a 203 t-stat.. disapeared into no mans land..i just added another from the local store..ended up swaping all of them since the other two now had a different size head...
early 99 f350 4x4 crew cab
work in progress
Thanks 4 all the o-ring help. I changed my 99 -- 7.3. easy job because of everyone.
i bought 100 viton o-rings to get a good price. if anyone needs them, i can send them for $2.00 each. send a self addressed stamped envlope and $2.00 each for as many as you need. again THANKS to everyone, hope i can payback favor.
well,...mine started leaking last week....noticed the raw fuel smell and diesel on my front axle....
went to ford and they wanted close to $40 for a "kit"...so i searced around locally and found some 1/2"od x 1/4"id x 1/8" thick orings from a place called filter services in se portland....payed $.30 for both...
..........done!!
Thanks SOOOO much, not as easy to get to on a Quigley E350, but that fixed it.
-mike
Does Any One Know Which Way The Little Yellow Handle Face In The Off Position, (fuel Filter Drain Valve )on The 2000 F350 7.3 Litre? Mine Is Stopped Up And No Fuel Is Draining From Either Position. Thank You
I'm not sure on your 2000 but it should point to the passenger side to drain. If it doesn't even with the lid cracked open try it with the engine running.
joedirt,
Is there anyway to resend your fuel seperator directions with NEW photos? For some reason none of them will open on any of our computers. I know I need to do this on my truck, but would like to go at it with a little more confidence.
Thx,
Dusty in Cali.
99 f250 4x4 single cab, long bed with 4" lift, 35" coopers, 4" exhaust and a DP tuner
I did it a few weeks ago and boy it's murder on your knees, but technically very simple. Try not to drop screws/tools into the valley of the engine. I dropped one of the four screws, but was lucky that it landed where I could see and reach it. I had to first get some of the wiring out of the way by disconnecting them, otherwise I couldn't get my small 1/4 ratchet in there and use it as intended.
2001 F-250 Super Cab 2WD 7.3L PSD Automatic
Hey everyone... thanks so much for the information here.
I think I have the same problem like everyone else here... I have an 02 7.3 and its leaking fuel in this area.
Someone mentioned the 02's have a "third" O ring. Did I understand correctly that it DID NOT need to be replaced to fix the leak problem?
I'm going to attempt to do this very soon... not a mechanic by any means, but this sounds like something I can do if I can find the O rings.
Thanks so much everyone for all of this information. You guys have saved me a few times here with advice and technical information about my truck, not to mention all of the cool mods I have done as well, from your ideas...
This is some great information. Thanks for taking the time to take pics and posting them. I have had a leak there for about two months just could not pin point it. But know i can save a few gallons.
P.S. got to love the low sulfur...
2000 , F-350 , Crew Cab , 4X4 , 6 Speed on the floor , 100 Horse chip , 4 inch Exahust with 6 inch Tip , 315x75x16 Mud Dawgs on custom rims!!!
I just replaced my o rings... put it all together and it was still leaking. There is a another thing next to the fuel drain valve with a wire harness on it and the same screws as the fuel valve I took it apart thinking there was an o ring in there... well there were different ones in this one.
Anyway, I put that back together and it seemed like the screws were pretty loose when I took it apart and I tightened them down pretty good, and so far I haven't seen any fuel dripping.
So those of you considering this repair, try tightening your screws first. I hope this fixes my leak.
My yellow drain valve is pointing to the passenger side by the way...
Someone mentioned there may be 3 o rings in the newer trucks. I couldn't find a third one. I have a 2002 250.
Thanks everyone for all of the posts and the help.
FYI - the links to the pictures are dead/timing out - are they still there?
'99 F250 PSD CC AUTO, Lariat, 565,000 km's, Raider cap, K&N air filter, spray in liner, stainless grill inserts, and command start for those -40 mornings, no more running out in my briefs to fire her up!
