Fuel Filter/seperator drain o-ring replacement...my first write up - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 99 & up 7.3L Power Stroke Engine and Drivetrain > 99 & up 7.3L Power Stroke Engine and Drivetrain FAQ
99 & up 7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 99 & up 7.3L Power Stroke Engine and Drivetrain forum.
Old 11-02-2006, 01:28 PM   #16 (permalink)
2003f350's Avatar
Re: seperator o-ring replacement...my first write up
OK I was able to do what Clydesdale said to do, I paid via PayPal, have to wait and see what the shipping is.
Ed
2003 F-350 Lariat Supercab 158" WB, 3.73 LS axle
7.3 PSD, auto trans. camper pkg. 12,500 lb. hitch,
adj. pedals. roof lights, Toreador Red, Arizona Beige, Power telescoping mirrors, and C-Betr mirrors. Delivery date Aug. 5, 2002. Reese 16K hitch, Thor Citation- model 29 5P 5th. wheel, Rhino liner.
2003f350 is offline
Old 11-06-2006, 05:30 PM   #17 (permalink)
O ring USA now charges a $10 "low order" fee.
Any other sources??
Mace is offline
Old 11-06-2006, 06:42 PM   #18 (permalink)
Okay, ordered from
http://www.marcorubber.com/orings.htm
if you buy 100 they are .10cents a piece.
below 100 you still are paying 10.00 for whatever # you are buying.
So, I got a 100 coming. [img]/ubbthreads/images/graemlins/wink.gif[/img]
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
Mace is offline
Old 11-06-2006, 09:54 PM   #19 (permalink)
This site is the best!!!
All three of the PSD's are stinkin like spent diesel fuel.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited triple pod
00 BMW 328CI 2dr silver fully loaded
65 Mustang 289 V8 4brl
69 GTO 400 4spd
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline
Old 11-08-2006, 02:28 PM   #20 (permalink)
Well last week I ordered 4 O rings from www.oringsusa.com. That was Tuesday afternoon and I went ahead and just paid the $12 shipping fee or whatever it was. I just wanted the o rings in as soon as possible. I finally got a notice today with a tracking number that I checked online from FedEx. They never even pushed my order out the door until yesterday! Fortunately, I haven't had much of a problem with my leak since I played around with the valve last week. If you are having problems slowing down the drip, try opening and closing the valve a couple of times with the motor running so the system is pressurized. That was the only way I got mine to stop dripping. Anyhow I'm just posting here so those who order from www.oringsusa.com can be aware of just how long it's taking to get my order to me. They are way to slow in my book and if I'd known I might have looked elsewhere, especially considering their crazy shipping fees.
Max
--RIP-- Totalled 12-08-08. Best truck I ever owned.
99.5 SD F250XLT PSD ExtCab, 4X4, SRW, LWB, 3.73 LS, WedgeWood Blue w/Silver, Edge Evolution Tuner, 4" turbo back MBRP exhaust, Wicked Wheel, Sonnax Valve w/Tricumulator Springs, SuperDuty Air Lift Bags, Edge 2" Mini Springs, Bilstein Shocks, Triple A-pillar w/Autometer Sport Comps. Born on May 23, 1999.
MAXPSD is offline
Old 11-09-2006, 08:35 PM   #21 (permalink)
Re: Fuel Filter/seperator drain o-ring replacement...my first write up
Mine hasn't started to leak yet but just like the spare cps I'm getting prepared. Where'd you find allen wrench style torx bits?
oldscot44 is offline
Old 11-09-2006, 11:00 PM   #22 (permalink)
klhansen's Avatar
My Photos: (169)
I used a torx bit from a screwdriver and a 1/4" socket to fit it into, although I think Sears and other stores would have something like that already made up. I know you can get socket wrench allen bits.
Hard or no-start? Check Here
klhansen is offline
Old 11-10-2006, 11:07 PM   #23 (permalink)
I just received mine for $5.00 & free s&h, from here http://cgi.ebay.com/ebaymotors/ws/eBayIS...s_promot_widget
Came in mail quickly in a standard envelope. I had to buy new assy at dealer for $55.00. & install it cause it was leaking so bad. Now I gotta spare with viton "o"rings. Hope the dealer one is updated to last. Changing in a van is the worst!
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 11-11-2006, 11:44 AM   #24 (permalink)
mmcspadden's Avatar
Funny this morning when I was doing a visual on my truck while starting I noticed a drip from the fuel drain on the side of the engine. Those orings were supposed to be replaced a couple of weeks ago but must have gotten overlooked as it started dripping a bit this morning. PERFECT this was the first thread I saw.
Thanks for all the info. Great post.
Mike
1999.5 F250 PSD 4X4
Mgf. Date 07/99
http://www.mcspadden.cc/themule.html
mmcspadden is offline
Old 11-11-2006, 09:37 PM   #25 (permalink)
Instant207's Avatar
Just replaced the o-rings on my 99 PSD with 108,000. Took 30 mins, completely stopped the leak. Great post Joedirt
2000 F-350 PSD Crew Cab, Long Bed 4x4, Rough County 2.5 Leveling Kit, Clear Gearz rear differential cover with Amsoil 7w140 Severe Gear. Front Differential 75w90 Amsoil Gear lube. Greaseable U-joints. 33" Nitto Terra Grapplers on 16x10 Helo Blasters. AFE Stage II Intake. Foil Delete Mod
Instant207 is offline
Old 11-14-2006, 05:49 AM   #26 (permalink)
I got mine at the local hydraulic cylinder repair shop,they gave me 6 o rings for nothing.Since these are in contact with oil and other fluids i figured they should be okay.So far so good.Tom
gmc89 is offline
Old 11-14-2006, 08:59 AM   #27 (permalink)
Mine started leaking recently. I tried to purchase the o-rings from www.oringsusa.com this morning and they wanted $12 in shipping plus a $10 low order fee.
I ordered from Small Parts, Inc. which only charged $4.95 in shipping with no low order fee.
http://www.smallparts.com/products/descriptions/orv.cfm
Thanks for this thread as you guys have again saved us money and time.
2000 Limited PSD 4x4 Excursion, rear anti-sway bar, Bridgestone Revo's
mikeiky is offline
Old 11-14-2006, 12:12 PM   #28 (permalink)
Did the same thing. Went thru amazon to get to them. I ordered 25 and gave a bunch away to my friends.
John
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 11-15-2006, 03:59 PM   #29 (permalink)
Just got my O rings in and installed, They work perfectly for the fuel drain.
To those that sent PM's. I'll get some pics up and get back to you.
Mace
Now, off to find a good replacement for the F'n clutch hydraulic system [img]/ubbthreads/images/graemlins/mad.gif[/img]
Mace is offline
Old 11-17-2006, 04:17 PM   #30 (permalink)
I found some locally but had to buy way more than I needed, don't know what to do with the extra. Does anyone know if there is a shelf life on Viton?
2000 F-250 XLT, 7.3L PSD, 4x2, Crew Cab, 156 WB, White w/ Grey Int., 4R100, 3.73, Aux. Idle Control, Roof Clearance Lights, Order date to delivery date 8-1/2 weeks!!!!
TxPowerStrokin' is offline
