Fuel Filter/seperator drain o-ring replacement...my first write up - Page 4 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 99 & up 7.3L Power Stroke Engine and Drivetrain > 99 & up 7.3L Power Stroke Engine and Drivetrain FAQ
99 & up 7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 99 & up 7.3L Power Stroke Engine and Drivetrain forum.
Old 11-25-2006, 03:31 AM   #46 (permalink)
Re: Fuel Filter/seperator drain o-ring replacement...my first write up
Thank you very much for the How to on the "O" ring replacements.
I just started my truck after being cold soaked for a week (0 thru 12 below) in the Valley.
Anyway I started my truck and noticed a spill under the front end and looked to see my drain hose leaking at a fast drip,drip,drip,drip. I placed a container under the hose and it slow to a drip,,,,drip,,,,drip. I guess warming up the truck slowed down the drip.
So tonight I look to find this great article on O-ring replacement.
Fantastic [img]/ubbthreads/images/graemlins/grin.gif[/img]
Y2K Ford F350 7.3 PSD C/C LB 4x4 Auto truck with 138,586 miles, Gulf Coast oil by-pass filter Mdl 0-1, Mag-Hytec Differential cover, Mag-Hytec Transmission pan, Tricumulator springs and Sonnax valve. DELO 400 5W-40 synthetic Motor Oil.
ArmedSoldier is offline
Old 11-25-2006, 04:11 PM   #47 (permalink)
My truck was leaking fuel like a seive from the top of the fuel seperator where the yellow lever attaches too. You could see it just pour out of the top of the thing when yhe engine was running.. It got so bad I couldn't drive the truck.. And then much to my surprise ! I came upon this sticky.. What a blessing to find such a post ! I went to ford and bought the whole kit.. $60.00 Not to mention I had to rent a car for a couple of days. I installed the the new seperator with a #20 torx bit in one of those "snake" drivers with a cordless drill driver.. It was still a pain in the "Arse" because of the tight area in which to work, especially when getting the peice of tubing connected to the seperator.. All in all it only took me 2 1/2 hours to complete the whole repair including picking everything up,,,
Thanks for a great post..
99 F250 SD PSD
Bypass filters on the Engine,Transmission,Fuel, Coolant.
Mykro is offline
Old 11-25-2006, 11:25 PM   #48 (permalink)
A fuel leak developed on my bosses '01 F250 today. Not knowing what the problem may be, we quick rushed it to a repair shop. We were quoted a new injection pump and labor to the tune of $850-900!
There was diesel in the center engine valley, and dripping down the engine block near the transmission on the ground.
The shop is unable to do anything until Monday, so no money has been spent yet. How can I tell if this is the fuel drain valve leaking?
The truck is not running roughly, but it does leak when the ignition is turned on and the pump kicks on. It seemed to not leak as bad when the truck was warm.
What exactly do I look for?
Thanks,
Scott
2003 eXcursion bone stock for now.....
Carolina_FX4 is offline
Old 11-26-2006, 02:09 AM   #49 (permalink)
klhansen's Avatar
My Photos: (169)
Thanks,
Scott
Take a look at the very first post in this thread, and click on the photo labeled "lever turned and draining".
You can see the valve very well in that photo and the hose that connects to it (slip fit). Most likely that's where your leak is.
Also, I'd recommend not taking the truck back to that shop. There's no injection pump that pumps fuel in the valley of a 99& up 7.3L. There is the High Pressure Oil Pump, but as the name indicates, it pumps oil, not fuel. At the very least, they need to get their terminology straight. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Hard or no-start? Check Here
klhansen is offline
Old 11-26-2006, 02:14 AM   #50 (permalink)
klhansen's Avatar
My Photos: (169)
To the readers of this thread.
DO NOT ASK ANYONE TO SELL YOU O-RINGS, OR OFFER TO SELL YOUR EXCESS ONES IN THIS OR ANY OTHER THREAD. Doing so is a violation of TDS rules.
There have been a number of sources posted, and some posters have mentioned buying in large quantities. If you want to buy some of their excess, use PM to contact them. If you have excess to sell, put them in the For Sale section of the site.
Any posts asking or offering to buy will be deleted. Please save myself and the other moderators time by not posting them in the first place.
klhansen is offline
Old 11-26-2006, 03:09 PM   #51 (permalink)
You need to look down into the "valley" with the engine running with a flash light.. If it is leaking around the fuel seperator you'll see it leaking.. Also... Go buy one of those mirrors you can extend and adjust so you can see where it is leaking..
99 F250 SD PSD
Mykro is offline
Old 11-26-2006, 11:11 PM   #52 (permalink)
Thanks everyone, will be looking tomorrow. We may just pull it apart and change the o-rings anyway since it seems to be a big problem nowadays.
Worth the time and effort if it stops the leak!
Old 11-26-2006, 11:25 PM   #53 (permalink)
Re: seperator o-ring replacement...my first write up
Hey guys Im new to this, Could I ask that somwhere we might post a sticky about O-rings sizes and locations used.
I had a inlet pipe O ring leaking. had to give $6 for the darn thing.
I bet these guys at; http://www.oringsusa.com are the original OEM for many gaskets used on our trucks
__________________________________________________
99 F350 4X4 CC Just bought used 234k on the OD
DIY Tymar 6637,EGR bypass,Harpoon mod, all interior/dash lights are LED/blue
ddan2 is offline
Old 11-27-2006, 10:19 AM   #54 (permalink)
Wow! What timing! Mine started dripping last week, after a week of raw diesel smell. I took off the cover and, voila! Seepage at the o-rings!
Looks like I have a tiny bit around the fuel filter seal as well, so I'm gonna do 'em both this week.
Gotta love this place! Thanx, all!
Fred
June '99 F350, Crew, Longbed, 6-speed. Superchips loader/reader, MagnaFlow 4" Stainless turbo-back, Donaldson AIS with Fender Sleeve, Ho-Made CCV mod, AIH Delete, Phantom EGT and Boost on the Pillar, towing a 32.5' Forest River RL/DS Fiver.
Living in Palmdale, CA, on the same street where the B-2 was built!
Fredzo44 is offline
Old 11-27-2006, 01:09 PM   #55 (permalink)
Do you only need 2 o-rings?
Any updates or modifications to the replacement proceedure?
Larry
2001 F250 lariot 4x4 Crew Cab w/ short box.
160K, with a Tymar intake and 4" exhaust
I gave up a 10 month old 12K Ram Hemi for a 4 year old 100K deisel. Have not looked back since
I LOVE THE SMELL OF DIESEL
CopperPSD is offline
Old 11-27-2006, 01:32 PM   #56 (permalink)
Are the o-rings the same for the 01 as the earlier model?
Old 11-27-2006, 01:48 PM   #57 (permalink)
Our heater element next to the drain valve is the culprit. Now off to the stealer to get an O-ring kit.
There is a bulletin out by Chevron admitting USLD will cause seals to "shrink" as the nw fuel does not have the old "aromatics" in it that help keep seals swelled.
I will be using some additive in my Excursion fuel to try and help the situation.
Will post results of the bosses 2001- F250 later today.
Old 11-27-2006, 08:36 PM   #58 (permalink)
Joedirt if you get a chance please let me know how many of the o-rings i need and if there is any update to the procedure.
while that is off are there any other o-rings that you suggest I replace.
Larry
Old 11-28-2006, 01:08 PM   #59 (permalink)
Mudraga's Avatar
Larry, There are only two o-rings. They will be the same for your '01 and the procedure is still the same. You might re-read the whole post before you start though as there are some good tips in there.
2002[1/02] Excursion 4x4 Ltd. PSD,Unknown program, K&N GenII FIPK Air Filter, straight pipe exhaust, Autometer Z Series pyrometer and boost gauges, Air Lift SuperDuty air bags with Load Controller II onboard air system, Sonnax Tricumulator, HX hose.
Mudraga is offline
Old 11-28-2006, 11:58 PM   #60 (permalink)
Don't stop at just changing the 2 o-rings on the lever. Change all the ones on the fuel lines leading to the bowl. Only takes a couple more minutes and a couple more $$, but the peice of mind is priceless.
Early 1999 F350 CC/LB 4x4, 7.3L, 3.73LS
*6" Lift
*315/75/16 BFG AT,
*16x10 Outlaw II's(not my favorite rim),
*Warn Hubs
*203 degree T-Stat
*lotsa lights
*Tymar HX hose
*Dual 5 inch stacks
*Tymar Intake
*Isspro guages and color matched triple pod
*Fresh beefed up 4r100 from Greene @ Quality Trans. in Anchorage Alaska
*TS 6 pos chip-no start, high idle, 50, 75, Fuel 7, 140 xtreme....
*Tymar coolant filter kit
*6.uh oh Intercooler
*Firestone RideRite 5,000lbs bags
Next on the list: Stage 1 or 2 injectors, BIG OIL
dslfumes is offline
