Fuel Filter/seperator drain o-ring replacement...my first write up - Page 8 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 99 & up 7.3L Power Stroke Engine and Drivetrain > 99 & up 7.3L Power Stroke Engine and Drivetrain FAQ
99 & up 7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 99 & up 7.3L Power Stroke Engine and Drivetrain forum.
Old 01-05-2007, 04:13 PM   #106 (permalink)
Re: Fuel Filter/seperator drain o-ring replacement...my first write up
Stewart,
I also learn something new every day! I have a lot of old outdated publications archived but use the Internet to keep me up to date. One quick easy to understand source for up to date compatibility of O-Ring Seals to the fluids they are exposed to is:
O-Ring Fluid Compatibility
I have other URLs that I use but they get really technical.
I used to have thousands of O-Ring Seals in stock for my aircraft as a Certificated Commercial Air Carrier and I really liked the shelf life of the Viton as I had to provide the traceability of the materials used to the FAA and the 20 year shelf life made it easy as long as I maintained the Certs provided with the O-Rings.
I don't think the O-Rings that you used are going to have a catastrophic failure but I'd keep some AS568A-202 Vitons on hand for the next time you're changing out your Fuel Filter Element. The AS568A-202 O-Rings are the same as the McMaster-Carr P/N: 9464 K118 O-Rings.
Good luck,
Jim
2000 F250 SD Lariat, SC, SB, 4x4, 7.3L PSD, 6-Spd ZF, 8,800 GVWR, 20,000 GCVW, Reese Class-V Tow Beast Receiver Hitch, Prodigy V2.6, 4" MBRP Stainless Steel Exhaust, AIS Induction Air Filter, AutoEnginuity
2002 26' FT2200 Weekend Warrior Toy Hauler, 102" Wide-Body, 11,100 GVWR, Reese Titan 14,000 lb Trunnion Heavy Duty WD Hitch, DC HP Sway Ctrl, Onan 4BGE-P Emerald Plus GenSet
jlrsn is offline
Old 01-05-2007, 05:21 PM   #107 (permalink)
klhansen's Avatar
My Photos: (169)
Viton is the best choice for the Fuel Drain Valve. Good luck,
I'm only going by the info from the web, but according to the information at the McMaster-Carr website, the PTFE O-Rings are as good, if not better, than the Viton O-Rings.
Stewart
I think you may have trouble with PTFE o-rings. They may be more resistant to just about anything, but they're rated at Shore D:55 for hardness (approximately Shore A:100) while both Buna N and Viton are at Shore A:70-75. The "extra hard" PTFE may not physically seal as well as the softer "hard" Viton o-rings. Besides that, they're more expensive (granted not much in the big picture at $0.80 each vs $0.22 each for Viton)
I think I'd stick with Viton.
Hard or no-start? Check Here
klhansen is offline
Old 01-06-2007, 04:29 AM   #108 (permalink)
Stewart_H's Avatar
Considering what I spend on my vehicle mods and maintenance, $10 bucks really isn't much.
Oh well, if the PTFE O-Rings don't seal well enough because they're too hard, I'll just pick up a pack of Viton rings.
I already gave away the extra PTFE O-Rings that were in the package I got, so it won't be a big deal to me if I have to order more O-Rings. I'll just have more to give away! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Stewart
1999 F150 Lightning
- WMS built engine
2002 F250 Lariat SC 4x2
- 4" turbo back, AFE Stage 1, JW valve body, AC codes, Live Tuned by Jody
2000 7.3L PSD Excursion
- John Wood built 4R100, AFE Stage 2, MBRP 4" SS turbo back, Beans 1.0 housing & WW, DP-Tuner F5 chip, V & B code spring upgrade, Bilsteins, Hellwig rear sway, ITP O/boost Annihilator and pre-pump mod.
Stewart_H is offline
Old 01-11-2007, 07:10 PM   #109 (permalink)
myf350's Avatar
Add one more set of o-rings to the list. Mine started yesterday. I had already bought the parts, just haven't changed them yet, now I will have to.
99(10/98) F350 psd auto cc long bed srw 4x4, DP-TUNER, ISSPRO gauges, ccv and tc mods, tymar air filter, 4 inch straight exh., sonnax and tricum., 6.0 TC, added cab lights, lifted front end, Timbrens in the rear, King Ranch wheels
250K and counting
myf350 is offline
Old 01-12-2007, 05:49 PM   #110 (permalink)
thanks for the info i saved the $100.00 laber cost from the dealer.one quick tip stuff a rag under the drain valve so you don"t lose the small screws when you drop them.like i did . LOL
2000 F250 superduty 4x4
batmans4x4 is offline
Old 01-13-2007, 10:37 PM   #111 (permalink)
Found my drain valve leaking yesterday. I ordered 10 Vitons from smallparts.com, only $5.60 shipped to me. My biggest concern is what this new diesel fuel is doing to the rest of the system/engine. There is absolutely no doubt in my mind this leak was caused soley by the ULSD. With all the sue happy people in this world, I'm suprised the EPA isn't paying for all these repairs yet. A lawyer should jump all over this. I might slip in a puddle of leaked diesel and spill hot McDonald's coffee on myself.
2001 F-250 Powerstroke, auto, super cab, short bed, 4x4. Bright red with silver on the bottom, lighted visor, chrome step bumpers and fender trim.
1988 F-150 302 V8 five speed, full bed, 2x4. Over 207,000 miles and runs like it just rolled off the assembly line.
maxrules is offline
Old 01-14-2007, 09:40 PM   #112 (permalink)
olddieseldude's Avatar
My Photos: (16)
Has anyone put a part number or size to the (3rd) o-ring that fits around the drain valve stem? It's much smaller in cross section and larger in ID than the other two o-rings being discussed in this thread.
Also I temperarily patched my leak this past weekend (I didn't have the real o-rings yet) but on the subject of tools to use, I found that my 1/4" thumb ratchet worked very well with a torx bit to get the screws in and out. I did have to break them loose with a regular 1/4" ratchet but the thumb ratchet removed them and replaced them quickly.
I also found removing the drain tube hose from the valve (without breaking the drain valve) to be the toughest part of the job.
Also, it was a good time to tighten my turbo tube hose clamps. All but one needed tightening.
RickN
White '99+ F250 SD XLT 4x2 SRW, 7.3PSD, 6spd, SuperCab, Short Bed
(mods listed in comments under photo in above link)
olddieseldude is offline
Old 01-16-2007, 10:14 PM   #113 (permalink)
My Photos: (16)
I found it, #013 - .426 ID x 0.070 Thk.
Correct me if I'm wrong though. After thinking about it a little it would seem to me that that o-ring sees no fuel until the drain valve is opened, is that true?
Old 01-16-2007, 10:24 PM   #114 (permalink)
klhansen's Avatar
My Photos: (169)
I measured that o-ring and came up with the same size.
You are right, the stem o-ring doesn't see any pressure. Not sure why it's even there. The two -202's will fix up the valve.
klhansen is offline
Old 01-18-2007, 11:45 AM   #115 (permalink)
Thanks for torque spec, Jim. That's around 2 ft/lbs so I think I'm good.
Airline Pilot, Huh? I flew Tomcats in the Navy.
1999.5 F250 4x4 PSDw/Manual Tranny Crew Cab Long Bed White with Leer Cap
LUK Clutch / Bridgestone 285/75/R16
Wheel67 is offline
Old 01-18-2007, 02:49 PM   #116 (permalink)
I put in the Torque Specs as members requested it but facing reality 25" lbs is basically snug. I have the calibrated Torque Screwdrivers that cover 25" lbs but it is almost impossible to get the tool into the area to torque the screws without major disassembly.
That Tomcat was one really impressive flying machine! I initially flew round engines (R2000, R2800) in the propeller days but retired flying a G4 Internationally.
jlrsn is offline
Old 01-19-2007, 01:04 PM   #117 (permalink)
Send a message via ICQ to kcastle
Add another truck to the list of o-ring replacements. On the bright side, I found a minor coolant leak around my thermostat housing.
My Truck
2000 F250 Crew Cab 7.3L Diesel, BTS Tranny, AFE intake, AIT heater delete, GTP38R turbo, EBV delete, 6 position BTS chip, Adrenaline HPOP, In tank and pre-pump mods, Custom polished skid plates and air tank, 37 BFG AT, 4.10 gears
kcastle is offline
Old 01-19-2007, 07:09 PM   #118 (permalink)
You can add me to the list too.
444-4D is online now
Old 01-19-2007, 09:24 PM   #119 (permalink)
After 3 tanks of ULSD - add me to the list. Changed them out 2 days ago!
MM
2001 F-350 Tan Crew Cab XLT (build date of both truck and engine: 9/2000), SRW, LB, 3.73, 4x4, Auto, DP 4 position chip (stock, 40 tow, 80 econo, 120 *GO BABY GO*), AIS w/ fender mod, motoblue 4" turbo back, mini air regulator set to 23lbs to fool MAP, Bilsteins, Autometer Z-series, Heater Bypass, Topper, AstroStart Remote Starter
2004 Jayco 325bhs 5er - no mods....YET...can you mod a 5th wheel trailer????
2001 Yamaha V-Star 1100 Custom. Cobra Power Pro 2 into 1 exhaust, SS Custom 420 Cams, Dyna3000 ignition, K&N pods, jetted, saddlebags, floorboards, sissybar, and a rear rack. Just give it a twist and hang on!
1968 Ford Mustang Coupe - 302 4bbl, c4 trans, 9" rear end, Shelby race suspension, custom dual exhaust, factory air (not hang on) and cruise! Almost one of a kind! Good looks
mushing_madness is offline
Old 01-19-2007, 10:00 PM   #120 (permalink)
Raymondb's Avatar
I knew it was coming and thought I had the proper o-rings on hand.
Ended up ordering from McMaster's web-site.
Dang things won't be here 'til Tuesday.
prt
'99 F250 7.3L SC SB
Powered by DP-Tuner
No more cupthrowers!!!
Next - ITP fuel system and Stage 1's
Carolina PSD
Raymondb is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
