Hard/No Start? Check here first. - Page 6 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 99 & up 7.3L Power Stroke Engine and Drivetrain > 99 & up 7.3L Power Stroke Engine and Drivetrain FAQ
99 & up 7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 99 & up 7.3L Power Stroke Engine and Drivetrain forum.
Closed Thread
Old 02-16-2006, 04:51 PM   #76 (permalink)
klhansen's Avatar
My Photos: (169)
Re: Hard/No Start? Check here first.
IM HAVING THE GPR PROBLEM AND WAS WONDERING IF ANYONE CAN VERIFY WHAT THE STEALERSHIP JUST TOLD ME WAS ACCURATE....HE SAID MY TRUCK TAKES THE MORE EXPENSIVE SOLID STATE UNIT (03/2000 BUILD DATE) OR IF THE NAPA GPR 110 WILL WORK FOR ME...THANX IN ADVANCE [img]/ubbthreads/images/graemlins/shrug.gif[/img]
If you have 2 relays behind the fuel filter, then the GPR 110 or GPR 109 (much cheaper will work).
If you have only 1 relay and an aluminum box with cooling fins on it, then you have a Glow Plug Controller and will need to buy that, if it's truly the controller gone bad.
I think that the Excursions had the GP Controller instead of a GPR.
Hard or no-start? Check Here
klhansen is offline
Old 02-16-2006, 05:13 PM   #77 (permalink)
My Photos: (11)
He has a 2000 X just like Jeff did in <font color="red"> THIS THREAD</font>. I think those with the GPC were some Ca vehicles and some X's, but maybe not all. About the only way to tell is to actually look ... heck, we might even have the second confirmed sighting of a GPR "buss bar" in the wild ... [img]/ubbthreads/images/graemlins/grin.gif[/img]
At any rate he might want to read thru that thread [img]/ubbthreads/images/graemlins/smile.gif[/img]
Larry
<font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Larry M is offline
Old 02-17-2006, 11:30 AM   #78 (permalink)
installking's Avatar
thanx guys for the input i did look and it has the one relay in front and the metal box with the fins behind so im assuming i have the module
2001 excursion limited black w tan
2008 center console
ts 7 switch chip
4" turbo back
7"superlift
20" ultra goliath 20x9
nitto terra grapplers 355/60/20
viper 7601 alarm remote start w smart start
SOLD....... 2008 xlt crew 6.4 4x4 silver 17x9 kmc spy wheels black 315/70/17 bfg tko
clearshiled paint protection
3m tint 20% fronts 5% over factory rear
uriah products rapid hitch
pionner avicz2 ipod control xm navtraffic
2 pioneer tssw1241d subs custom box around rear seat belt
rockford bd100 amp
edge insight
hid headlights (foglights next)
putco smoked led mirror lights
stay tuned!!more to come soon
87 mustang notchback new 391 cu in stroker dart block jegs/kasse heads turbos or big nos undecided??
installking is offline
Old 02-18-2006, 09:19 PM   #79 (permalink)
klhansen's Avatar
My Photos: (169)
I'm going to lock this thread, because it's getting pretty cumbersome.
If you read the info in here and still have a problem, please make a new post, and we'll address your specific problem.
For next season, I'm planning on consolidating the info here in a new, revised FAQ type post.
klhansen is offline
Closed Thread
