Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain > 7.3L Power Stroke Engine and Drivetrain FAQ
7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 7.3L Power Stroke Engine and Drivetrain forum.
Old 09-21-2007, 04:43 PM   #1 (permalink)
This is how to repair the "non-serviceable" plug on the HPOP
This is how to repair the plug that is on the bottom of the HPOP (the plug that you have to remove the HPOP to get to). This plug is listed in the service manual as "non-serviceable"/"do not remove".
After tracking down the leak on my HPOP, I found it to be the plug on the bottom that is not serviced in any of the kits that I read about. After hearing the horror stories about people trying to repair this leak only to have the threads strip out or the HPOP not build pressure afterwards, I made a trip to the local International dealer. I was able to speak with a very knowledgable service guy that informed me that there is indeed a service kit for this problem. He stated that the DT466 I-6 engine uses a very similar HPOP and there was actually a recall that addressed this issue. The recall was only for the I-6 though so that is why many people wouldn't know about it. He took me back and showed me how to fix the problem and while I was there I picked up the repair kit that has the instructions,new plug, o-ring, and loctite (the kit contains extra parts that aren't used on the 7.3 HPOP). The part # for this kit is 1842906C92. I would scan the instructions but I do not have a scanner, sorry. The instructions basically state that the plug should be heated before removal whch should reduce the chances of stripping out the threads. Also, before any plug is removed, the HPOP should be positioned straight up and down with the machined face down and the snap ring end up so that the "ferry plug check ball" is not disturbed. I hope this helps alot of people that don't want to/can't pony up the money for a new pump.
2003 F250 7.3 CC SWB 4X4 - Stock except for:
-Switched 10K mod that I never use
-TQ lock up switch that I never use
-305/70/16 Bridgestone Dueler A/T
joshmcoley is offline
Old 09-28-2007, 01:17 PM   #2 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Re: This is how to repair the "non-serviceable" plug on the HPOP
In my case, the threads came out with the plug. It would have needed a heli-coil to repair it. Does the International repair kit for this plug solve that problem?
haul_n_horses2 is offline
Old 09-28-2007, 01:37 PM   #3 (permalink)
Possibly, the new plug has about 1/8" more threads on it than the old plug and this may be all that is needed to reach the proper install torque.
Old 10-09-2007, 10:59 AM   #4 (permalink)
I have a small leak leaving oil in the valley and I checked all connections on the sides of the HPOP and found nothing but when I rubbed under the pump, I found fresh oil. Does this sound more like the plug you are talking about or the ICP? I have read about "O" rings, ICP & bad pumps so I am alittle confused on what to look at next. I don't want to pony up for a new pump either if I can fix it myself.
2000 Ford 7.3L CC 4X4 4" lift, XM radio, FS2500 Oil Bypass, AFE Stage I PG7 intake, 4" MBRP single exhaust, WW, Zoodad, 203*, 40 gallon combo tank, triple gauges and 3 pos DT Tuner chip -- ALL STOLEN from PARKING LOT
DLBartley is offline
Old 10-09-2007, 12:22 PM   #5 (permalink)
I think I meant IPR not ICP.
Old 02-05-2008, 08:07 PM   #6 (permalink)
I just did the same fix and purchased the kit from International as well, about $75.00. I cleaned up the threads and used the original plug, not the one included in the kit.
Mine blew the original O ring and the plug was easy to turn without much force, no heating needed.
Only have a few hundred miles on it since it has been re-installed but t is not leaking.
PayToPlay is offline
Old 06-05-2008, 02:04 PM   #7 (permalink)
When urs leaked did it pour out or just drip?? cuz i thought mine was the rear main seal so i changed it put it all back together and it was still leakin as bad as it was. its a 99' f250 6 speed..
Hillbilly Deluxe32 is offline
