This is how to repair the "non-serviceable" plug on the HPOP - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 99 & up 7.3L Power Stroke Engine and Drivetrain > 99 & up 7.3L Power Stroke Engine and Drivetrain FAQ
99 & up 7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 99 & up 7.3L Power Stroke Engine and Drivetrain forum.
Old 09-21-2007, 04:43 PM   #1 (permalink)
This is how to repair the plug that is on the bottom of the HPOP (the plug that you have to remove the HPOP to get to). This plug is listed in the service manual as "non-serviceable"/"do not remove".
After tracking down the leak on my HPOP, I found it to be the plug on the bottom that is not serviced in any of the kits that I read about. After hearing the horror stories about people trying to repair this leak only to have the threads strip out or the HPOP not build pressure afterwards, I made a trip to the local International dealer. I was able to speak with a very knowledgable service guy that informed me that there is indeed a service kit for this problem. He stated that the DT466 I-6 engine uses a very similar HPOP and there was actually a recall that addressed this issue. The recall was only for the I-6 though so that is why many people wouldn't know about it. He took me back and showed me how to fix the problem and while I was there I picked up the repair kit that has the instructions,new plug, o-ring, and loctite (the kit contains extra parts that aren't used on the 7.3 HPOP). The part # for this kit is 1842906C92. I would scan the instructions but I do not have a scanner, sorry. The instructions basically state that the plug should be heated before removal whch should reduce the chances of stripping out the threads. Also, before any plug is removed, the HPOP should be positioned straight up and down with the machined face down and the snap ring end up so that the "ferry plug check ball" is not disturbed. I hope this helps alot of people that don't want to/can't pony up the money for a new pump.
2003 F250 7.3 CC SWB 4X4 - Stock except for:
-Switched 10K mod that I never use
-TQ lock up switch that I never use
-305/70/16 Bridgestone Dueler A/T
joshmcoley is offline
Old 09-28-2007, 01:17 PM   #2 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Re: This is how to repair the "non-serviceable" plug on the HPOP
In my case, the threads came out with the plug. It would have needed a heli-coil to repair it. Does the International repair kit for this plug solve that problem?
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
Old 09-28-2007, 01:37 PM   #3 (permalink)
Possibly, the new plug has about 1/8" more threads on it than the old plug and this may be all that is needed to reach the proper install torque.
Old 10-09-2007, 10:59 AM   #4 (permalink)
I have a small leak leaving oil in the valley and I checked all connections on the sides of the HPOP and found nothing but when I rubbed under the pump, I found fresh oil. Does this sound more like the plug you are talking about or the ICP? I have read about "O" rings, ICP & bad pumps so I am alittle confused on what to look at next. I don't want to pony up for a new pump either if I can fix it myself.
2000 Ford 7.3L CC 4X4 4" lift, XM radio, FS2500 Oil Bypass, AFE Stage I PG7 intake, 4" MBRP single exhaust, WW, Zoodad, 203*, 40 gallon combo tank, triple gauges and 3 pos DT Tuner chip -- ALL STOLEN from PARKING LOT
DLBartley is offline
Old 10-09-2007, 12:22 PM   #5 (permalink)
I think I meant IPR not ICP.
Old 02-05-2008, 08:07 PM   #6 (permalink)
I just did the same fix and purchased the kit from International as well, about $75.00. I cleaned up the threads and used the original plug, not the one included in the kit.
Mine blew the original O ring and the plug was easy to turn without much force, no heating needed.
Only have a few hundred miles on it since it has been re-installed but t is not leaking.
PayToPlay is offline
Old 06-05-2008, 02:04 PM   #7 (permalink)
When urs leaked did it pour out or just drip?? cuz i thought mine was the rear main seal so i changed it put it all back together and it was still leakin as bad as it was. its a 99' f250 6 speed..
Hillbilly Deluxe32 is offline
Old 05-06-2009, 11:49 AM   #8 (permalink)
Help with abbreviations
What is a "HPOP"? Or an "IP". Is there a place I could use to look up these abbreviations? I know it's easier to use them, but being fairly new at this, I have no clue what you're talking about.
ataboc is offline
Old 05-06-2009, 03:57 PM   #9 (permalink)
Broncofever3's Avatar
Post HPOP= High Pressure Oil Pump
HPOP High Pressure Oil Pump
IP Injector Pressure should be IPS Injector Pressure Sensor or IPR Injector Pressure Regulator They are all part of the high pressure oil system that runs the injectors.
Hope this helps Sound kind of strange untill you get used to it.
Keep learning, it's a good thing..........
99 F-250 crew short 4x4 auto PSD.
Build date is 1/99
Stage 2 injectors
ATS housing on stock turbo
4" exhaust
SS crossover
ITP regulated return w/intank mod, prefilter
ITP MAP regulator
DP Tuner F5 6pos. chip
3 gauges
Aftermarket intake/filter
Toms Woods valve body
Broncofever3 is offline
Old 06-12-2010, 03:14 AM   #10 (permalink)
ron68coug's Avatar
My Photos: (5)
good luck on reusing the plug, it only worked a couple months for me, then blew all of the threads out with the plug, along with a bunch of oil. Seattle injector had a new Bosch hpop for $250+-.
01 F-350 CC DRW 4x4, bright red, 7.3 stock, 44k miles, leather heated seats , alum. headache rack, new Toyo M/T 315/75R16's x 6, 6" Superlift lift kit, Pro Comp traction bars, bilstein shocks, Fred Goeske 2" pilot hub wheel spacers, Viair 480C compressor, and Nathan train horns.
ron68coug is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
