Make Your Own: HPOP Line Removal Tool - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 99 & up 7.3L Power Stroke Engine and Drivetrain > 99 & up 7.3L Power Stroke Engine and Drivetrain FAQ
99 & up 7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 99 & up 7.3L Power Stroke Engine and Drivetrain forum.
Old 06-03-2009, 09:46 PM   #1 (permalink)
calico5string's Avatar
My Photos: (14)
I posted this up a while back on another forum, and it recieved some positive response. So, I thought I'd post it up over here, too.
HEY MOD'S: Maybe you can make this a "sticky"?
There is a special tool to "correctly" remove the HPOP lines. The lines and fittings are made by Aeroquip and are called STC connectors (for "Snap To Connect).
You can remove them with a screw driver, but it's a pain-in-the-butt usually, and you take a chance of damaging the connector (hose-end).
I made my own tool after taking dimensions off of a "factory" STC tool. It's pretty straight-forward, if you have access to, and are able to do some simple metal fabrication.
Here is a sketch and a couple of pic's of the tool I made:
One thing I did not mention in the sketch is to go over the slotted area with a small file or emery cloth and debur all of the edges very good.
If you have access to a milling maching, you could also mill the slot (which is actually what I did on this tool), but the "hole & saw" method works quite well also.
Here's a little info on the Aeroquip STC connector.
Once the lines are off, you can remove the fitttings from the pump (and heads) and replace the o-rings. The pump side fittings use a -906 (that's a "dash 906" size) and the head fittings use a -905 size ring.
Once the fittings are installed back into the pump and/or heads, just snap the hoses back into the fittings.
It don't get much easier than that!
Enjoy!
Al in SoCal
2000 F350 SRW CC 4X4
AFE Stage II w/PG-7
Garrett 38R Turbo
Swamps Stage II Single-shots
Stealth Dual-HPOP
ITP Custom-modified Regulated-return Fuel System
DP-Tuner PCM & F-5 chip (Live tuned!)
Autometer Gauges (Pyro, Boost, Eng oil temp)
Non-EBPV Pedestal
AIH Delete
"T444e" Open CCV
4" Custom S/S Exhaust into 5" Dual Aussie Stacks
ZF 6-Spd "Hand-shaker"
Southbend Double-Disc clutch
...plus some other goodies...
calico5string is offline
Old 06-03-2009, 11:32 PM   #2 (permalink)
Epic drawling. Really, good detail. Ill draw it up for you in auto cad. PM your email.
Early 1999 PSD SC 4x4
Old user name: Noservice4you... it didnt sound welcoming.
Savageduty is offline
Old 06-04-2009, 08:52 AM   #3 (permalink)
pm me a copy thanks deadeye58
deadeye58 is offline
Old 06-05-2009, 10:33 AM   #4 (permalink)
Thanks, good tip. I am going to change my o-rings soon and can make and use that tool rather than buy one.
Oneof6 is offline
Old 10-20-2010, 07:18 PM   #5 (permalink)
woodnthings8's Avatar
A video of how to disconnect them!
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 11-02-2010, 07:32 AM   #6 (permalink)
Hey All,
For some reason, I can not see the pictures or drawings that you all have posted here. I need to change the HPOP riungs, and would like to get as much info and the drawing of the tool so I can get this done. If you have the drawing for the tool in ACAD, please send it to me, and if not, send me the picture of what you have, and I will put it ACAD and post it for everyone.
Regards,
Mark
2001 F-250, 4X4, CC, LWB, Bullydog Chip, Magnaflow Intake, Back up sensors, A pillar EGT; Tranny Temp; Boost Gauges, 285/75R16 Mud Terrains
mb_nomad is offline
Old 11-02-2010, 08:43 AM   #7 (permalink)
Try this:
http://photos.thedieselstop.com/data/500/STC_Tool.jpg
Ken
TSB Information
Old 12-22-2010, 10:45 PM   #8 (permalink)
Chinookman's Avatar
Since we can't book mark threads as in days of old can we get this one to be added to the FAQs ?? This is really cool even if we are not yet in need of it...in time some of us will be!
Thank you for the excellent ideas, pics and drawing....
C-man
2003 7.3 CC XLT Sport short box 2wd dark shadow gray ,AIS Intake Kit, MBRP 4" w/3.5" D/P & 5" SS tip;Wicked Wheel ;Ultra Duty Aluminum Diff.cover JNB kit "HUTCH MOD" and Dahl 100 fuel filter. Silverstar lamps,203 T-stat w/Red billet housing. Fumoto DV w/nipple, AIH mod, Zoodad, Amsoil BMK-11 Oil ByPass Kit,fuel reg. shim @ 0.055 for 65-68 psi. Harpooned tank,Hx Mod, Coolant Filter, Po'man's Fx mod,CCV mod & 6.0 tranny cooler! Pull Rite Super Glide 14k Hitch.
Truck stuff, old Chinooks and refueling a reactor
Saved by Grace, not by choice
6 turning, 2 burning-Love the smell of JP-4
CH-47C Super 'C' 73'-75'
Chinookman is offline
Old 12-22-2010, 11:26 PM   #9 (permalink)
C-man
It is in the 7.3L Engine and Drive-train FAQ area
Ken
TSB Information
Old 12-24-2010, 05:40 PM   #10 (permalink)
My Photos: (5)
Send a message via AIM to ig0fastr
hpop tool
I've borrowed the ford dealership's master mechanic's hpop tool, twice, and it had an offset to it that is as important as the end of the tool. helps to get around things. put it in a vice and make a 1/2" offset a half inch after the fork. good luck!
Dave Laferriere
ig0fastr is offline
Old 12-09-2011, 01:56 PM   #11 (permalink)
Supporting Member
F450fleet's Avatar
FYI, most of the time I use the little double ended collet wrench that came with my air die grinder. It works perfect.
I maintain 11 PSD's (mostly 6.0's) and have constant heartburn!
F450fleet is offline
