Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain > 7.3L Power Stroke Engine and Drivetrain FAQ
7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 7.3L Power Stroke Engine and Drivetrain forum.
Old 12-31-2007, 08:22 PM   #1 (permalink)
My Photos: (5)
o-ring sizes, can we get a "sticky"
1. For the fuel drain valve it is #202 viton.
2. For the HPOP hoses and aftermarket crossovers- it is a #5 boss o-ring or -905 (90 durometer .414 ID .072 wd)
Can someone add the pedistal o-rings, IPR o-ring and whatever else they might know? It would likely save time for all of us. It beats searching through the archives. Thanks
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 85,100 miles. truck Pictures
clydesdale is offline
Old 12-31-2007, 09:42 PM   #2 (permalink)
jgarden's Avatar
Re: o-ring sizes, can we get a "sticky"
Here is some info (credit goes to Calico5 - from an old post he made):
The o-rings on the HPOP system are standard SAE straight-thread ORB (o-ring boss) type.
For the -6 fitting (the ones on the HPOP) the o-ring is a "-906" (.468" id x .078" wd).
For the -5 fitting (the ones in the heads), the o-ring is a "-905" (.414" id x .072" wd). The durometer (hardness) should be 90 for all ORB o-rings.
These o-ring numbers are specific to the SAE o-ring boss fittings. "Regular" o-ring numbers and dimensions are slightly different (although, in a pinch, a "regular" one will work!)
Viton is the prefered material, however BUNA-N will work, but the temp. rating is limited to about +230*F (viton's good to +400*F).
The ORB o-rings are generally available from any good hydraulic or industrial equipment supplier. HERE is one source (scroll down the page a bit!).
I was thinking of making up a www page with all the oring sizes. All I need is TIIIIIIIIIIIME.
TDS member #49 - 1999.5 (Built 4/26/99) White F350, CC, SRW, LWB, Lariat, AIC, 4R100 (4th transmission before 85k - gotta love this tranny), 6.0 trans cooler, manual shift 4wd, 3 inch leveling kit, KING reservoir shocks, 285-75-16 Bridgestone REVOs, Performance Friction Pads all around, Powerslot Cryo'd rotors in front, CD player, Infinity REF 6800CS speakers (front and rear), Garmin 2610 GPS (hardwired), 40/20/40 leather seats, heated turn signal- TT mirrors, Titan V hitch, weatherguard box, DP Tuner 4 Position chip (love it), AIS intake, Diesel Site CAC Boots, 4" Magnaflow exhaust, Diesel Innovations Up Pipe, gutted EBPV, Non EBPV Turbo Pedestal, X-Monitor. NO STEERING WHEN BRAKES ARE APPLIED!
Jack
jgarden is offline
Old 01-01-2008, 05:05 AM   #3 (permalink)
Good info
2000 F250 SC 4A SB OEM TC, OEM Trans, OEM Turbo, OEM Injectors, OEM Airbox, OEM CAC, Quad Pod W/4 Autometers, 3 Guage cubby-hole, Jody-isized, Fuel System Mods, Mag Hy-Tec, Schaefers 9000, Transgo, Interior is soundproofed, 3.5" DP SS XL Magnaflow, LPG, 106k miles, NVK5 to MNMO, 2200 WATT BI-AMP, 18"s, Best MPG-22.80, Best MPT-760 miles.
FORD-DIESEL.COM MODS--Heater Hose Cutoff Valve, T/C lock, EBV brake, MIAH Plug, QD's removed, Wrapped CAC Tubes, Double Clamped Coolant Hoses, Zoodad, Relocated License plate, painless fuse box. Other RSB Mods
388HP 818Ft.Lbs.@ 130MPH. 4th gear dyno run, 2.1 60, Home-Made Traction bars.
This is a Street truck, 18+MPG(No LP), 14.2 at 98mph, 13 sec Motor, 14 sec Truck(NO Traction)
2004/03 CC SB Auto 6L W/OCT flash, 19+MPG, 20%Bio, AFE, Magnaflow XL SS 4" Exhaust, 75K, Heater By-pass mod, 21.1 MPG best.
2006.5 Jetta DSG 14K 41MPG Best
2005.5 VW Jetta 1.9 TDI 49MPG Best 73K
Kubota 7800 30 HP Hydrostatic 4X4
All Diesels
1969 Mach1 351C 4M 9"
Mach1 is offline
Old 01-02-2008, 09:36 AM   #4 (permalink)
My Photos: (5)
I can't find the ipr o-ring size but I believe I found the turbo pedistal o-rings in the archives. But if you know the IPR size, it would help.
Klhansen had found this a while ago:
Found the sizes for the turbo pedestal o-rings.
The smaller ones (supply) are -205 (0.421" ID x 0.139 thickness)and the larger ones (drain) are -211 (0.796 ID x .0139 thickness).
I usually get them from International for about $1 each. They have a yellow coating on them for what it's worth. The one's you could pick up at a plubming shop or hardware wouldn't have the coating.
Old 01-03-2008, 03:06 AM   #5 (permalink)
klhansen's Avatar
My Photos: (107)
Here's what I have (gleaned from a number of sources - some I measured and compared with a chart I found at http://www.oringsUSA.com)
Application ------------------------- Size
Turbo Pedestal Supply o-rings --- –205
Turbo Pedestal Return o-rings --- –211
Fuel Drain Valve o-rings ---------- –202
Fuel Drain Valve Stem o-rings --- –013
HPOP hose/plug o-rings ---------- –906
IPR O-ring (large) ----------------- -114
IPR O-ring (small) ----------------- -012
Locking Hub external o-ring ------ -152
Locking Hub dial o-ring ----------- -142
o-rings for HP oil should be Viton 90 durometer.
I'll move this up into the 7.3L Engine & Drivetrain FAQ forum. Feel free to add more info.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 01-25-2008, 01:11 AM   #6 (permalink)
anyone know where i can find the giant O-ring/gasket that goes inside the turbo housing???
2000 Ford F250 7.3l diesel of course with 137,086 original miles, new waterpump, AEM intake, ATS Turbo Housing, TS Performance 6 pos chip, guages (exhaust temp, boost, onboard air gauge), 4 inch MBRP exhaust to the turbo, CB Radio always on ch. 14, 60 gal. Aux. Tank/tool box in bed, Rotella Oil 15w40 soon to have HPOX on there, Train Horn hehe, Viair Onboard air (150psi),Pioneer head unit, some kind a drop in bedliner, 32in Nitto tires, and cant forget the pintle hitch
hit_cb is offline
Old 01-25-2008, 02:46 PM   #7 (permalink)
firemediceric's Avatar
Can anyone list the sizes and an after market source for the O-rings on the fuel filter?
Without buying the entire filter, I would like to be able to have an x-tra O-ring for the lid, the beveled one and the one that goes around the filter element.
1999 F-350 and 1981 Mercedes 300 SD. Both running a single tank WVO blend.
Truck: Tymar type intake, Zoo Dad, muffler delete, CCV mod, By-pass coolant filter, Dahl 100 fuel filter Harpoon & Hutch mod, upgrade to 3/8" fuel line and HP oil X-over, Oil Guard by-pass, Scan gauge II. Loving veg. oil
Mercedes: Installed a Goldenrod fuel/water seperator and injector line heaters. Also loving Veg oil for fuel.
firemediceric is offline
Old 01-25-2008, 10:08 PM   #8 (permalink)
klhansen's Avatar
My Photos: (107)
You could check that link I posted a couple of posts up, but I don't think you'll find the fuel filter lid o-ring, unless you special order and buy them by the 1000's. They are a triangular cross section, not a normal round x-section o-ring.
For the round x-section one at the base of the filter element, you could measure it and match it up to a stock size. For something that big though, it's tough to get a correct diameter without a measuring cone (see the link for info on those). You could get close by using a caliper on the filter element and taking a bit off to account for stretching the o-ring on.
klhansen is offline
Old 10-19-2008, 11:57 AM   #9 (permalink)
I found this while doing a search. It lists sizes, vendors, and part numbers for the o-rings on the 7.3
Powerstroke O-Ring Chart
I hope it helps someone.
Pete
y2k f-250, sc, 6 sp, 4x4, banks stinger and brake, bores rookie sticks, pace edwards roll top bed cover
petr is offline
Old 05-29-2009, 02:16 PM   #10 (permalink)
calico5string's Avatar
My Photos: (14)
Just an FYI to the list above:
HPO fittings on the PUMP use a -906 o-ring (as they are -6 SAE/ORB fittings).
The fittings in the heads are -5 SAE/ORB, and use a -905 o-ring.
Always good info, BTW!
Al in SoCal
2000 F350 SRW CC 4X4
AFE Stage II w/PG-7
Garrett 38R Turbo
Swamps Stage II Single-shots
Stealth Dual-HPOP
ITP Custom-modified Regulated-return Fuel System
DP-Tuner PCM & F-5 chip (Live tuned!)
Autometer Gauges (Pyro, Boost, Eng oil temp)
Non-EBPV Pedestal
AIH Delete
"T444e" Open CCV
4" Custom S/S Exhaust into 5" Dual Aussie Stacks
ZF 6-Spd "Hand-shaker"
Southbend Double-Disc clutch
...plus some other goodies...
calico5string is offline
Old 06-28-2009, 09:47 AM   #11 (permalink)
Internal HPOP Connector O-rings
The internal o-rings in the HPOP connector fittings that go in the HPOP Pump and the heads are -012 in 90 durometer Viton. Make sure the backing ring stays on top (the thread end being the bottom of the fitting).
rrroadster is offline
Old 11-04-2009, 02:28 AM   #12 (permalink)
Hi all!
I've just visited this forum. Happy to get acquainted with you. Thanks.
Free Anime Episodes
hcm2009 is offline
