Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain > 7.3L Power Stroke Engine and Drivetrain FAQ
7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 7.3L Power Stroke Engine and Drivetrain forum.
Old 01-20-2008, 11:42 PM   #91 (permalink)
Thanx
Many thanx to cool cannuck & jlhansen. My 03 goes into warranty never land next month, your posts on testing the starting system will be priceless when I go on my own. Until I came to your posts the little "secrets" about the glow plugs and starting system drove me nuts. I just got to know a pretty decent Ford Teck who lives in town. Still, I have spent many years doing 99% of my own repairs. With the info you share I will be able to continue the fun!
Thanks again!!
03 F350 CC LWB, 3.73's, 6 Speed, Stock 7.3,
custom rear bumper w/ hitch, Reese 5th wheel, a work truck!
jwvonl is offline
Old 01-11-2009, 10:53 PM   #92 (permalink)
Quick Question.
I don't understand where people get it from, but I live in wisconsin and many people around me seem to think that running your block heater damages your engine or something. where does that come from?
It only helps, wether it's 30 F or -30 F.
matkinson659 is offline
Old 01-11-2009, 11:06 PM   #93 (permalink)
klhansen's Avatar
My Photos: (107)
Originally Posted by matkinson659 View Post
Quick Question.
I'm with you. I can't see where it hurts the engine at all. 1000 watts versus what burning the fuel in the engine puts out is really insignificant. Heck, I even leave mine plugged in after starting while I do stuff like scrape the ice off windows. I even tried to drive off with it plugged in the other day.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 01-11-2009, 11:48 PM   #94 (permalink)
My brother did that with his old 6.5 chevy. We had to put a new plug on th truck. Now he has an 04 four door dually. he has gone from a truck that would not start unless plugged in, to a truck he doesn't have to plug in. Im still wary of his new truck though, he had a huge puddle of anti-freeze under it the other day, and he took it in to get looked at. they pressurized the system for 2 days and sdidn't find anything.
Old 01-15-2009, 02:54 PM   #95 (permalink)
Supporting Member
Years ago, in the cities in Saskatchewan, many of the parking lots had plugin for each slot, so folks could plug their car in during the day while they work.
I dunno if its still like that.
My father had a trick, he had installed a small electric room heater, under the dash of his car, and then plugged it in also, in addition to the block heater. He had a separate circuit out to the car to carry the load.
Then when he got up to go to work, the car would start easily and the windshield was melted and clear.
1999 Ford F250 Supercab 2WD Powerstroke, Line - X, Fumoto Oil Drain valve, 6637 air filter system, and more to come..
PeterL is offline
Old 01-17-2009, 07:45 PM   #96 (permalink)
well my brother seems to think he read somewhere that on the newer trucks
(his 04 Powerstroke) you're not supposed to plug them in until it's colder than -20 F
Old 02-04-2009, 07:43 PM   #97 (permalink)
Weird Cold Start Problem
I am having an issue with my 01 F250. I have never had any issues in the past with it cranking in cold weather down to -18 until today.
The truck cranks fine in the morning after it has been on the block heater. The last few days we have had high temps in the teens and after sitting in the parking lot all day, it has been really difficult to start. I had to cycle it 6-10 times to get it to crank. Today, it failed to start. It sounds like the batteries are fine and that it is not getting fuel.
The last two tanks of diesel were purchased at the local Shell station rather than at my usual Marathon station. I do run the White bottle DFS in the wintertime.
So..................
Is it batteries? - I am overdue for new ones.
Is it possible I got a bad tank of fuel?
Is it something else like the Glow Plugs.
Thanks for any help.
Jeff
2001 F250 SuperDuty, 7.3 PSD, CC, White/Khaki, Century BC, 2007 34'SO Airstream Classic
TowDaddy is offline
Old 02-06-2009, 08:46 AM   #98 (permalink)
I have a 2000 F350, when it starts up in the cold the exaust will suck in for a bit, then blow out, anyone have any ideas what that could be?
Daveysmustangs is offline
Old 02-07-2009, 08:21 AM   #99 (permalink)
I'm not sure bout that. I know my brothers old chevy was the same way. we found out that the glow plug tower, which cycles the glow plugs was bad.
Check the batteries and glow plugs. Maybe ask around to find out about what runs the glow plugs. It is called a glow plug tower on my brothers chevy, it might be called something else on a ford.
Old 02-10-2009, 12:11 PM   #100 (permalink)
Buckshot341's Avatar
what weight oil are you running? could also be your gpr going out, or bad gp;s
Its a work in progress: 2001 Ford F-250 7.3 Powerstroke 60,000 miles. Have big dreams for this truck. LT305/75R16 mickey thompson mtx, Sirius satelite radio, Muffler Delete with 6 inch tip at a 45 out the back. KC Slim Lite Off Road lights. Bumper Guard. 2 10" subs with Alpine deck. Garmin GPS. DP Tuner- No start, 1200 rpm hi idle, 60hp Tow, 80hp econ, 100 hp performance, 120 hp Race, 140 hp aggressive. Isspro white dial chrome bezel blue pointer Pyro, Boost, and Trans temp in 3 pod a pilar mount
Buckshot341 is offline
Old 02-21-2009, 05:08 PM   #101 (permalink)
xfordtdm's Avatar
Originally Posted by cnowotny View Post
Thanks for the informative post cool_canuck. As far as batteries go, is there a recommended type of battery that works best for cold temperatures? is it worth paying extra for deep cycle batteries perhaps?
Interstate batteries are the best. They will run you 50 dollars more (each). I will not put anything else in my vehicles.
My friend swears by his Optimas. They are pricey also.
xfordtdm is offline
