Okay, I believe I've updated everything requested up to this post. The FAQ is starting to look really good! I glad to see everyone contributing. Yes, it won't stop ALL the newbies, but it should curb a good amount of them. Like it was said before, even if they ignore this FAQ and post a question already answered here, we can just post a link to this thread and be done with them.
To make the thread cleaner (i.e. smaller), I'm going to go back and edit my posts to null. If your update is in place on the original thread, please do the same thing.
Thanks everyone!
Tony D. Berry
Lafayette, LA
2001 Ford F550, PSD, 4.88, 4R100?
__________________________________________________ ______________________________
Tony, it looks like you may have only copied some parts of the updates I did. Like the CCV mod is lacking some stuff added to the Mod Description, and the others are don't have the tools required, difficulty, etc. sections that I filled in.
What I did when I updated those was I just quoted your post, then added to whatever was there, and didn't remove anything. So I'd just suggest that you take the few that I posted, copy them, and paste them fully in place of those in your original post. That way nothing gets left off and also nothing is replaced, only added to. See what I'm saying? [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
edit - for easier viewing, here are the ones I'm talking about to sub into your original post:
Mod Name: IC Foil Wrap Delete Mod Difficulty: Medium Tools Required: pliers to tear off foil, wire wheel attachment for a handheld drill, WD-40 and/or brake parts cleaner Time to Perform: 1-2 hours Mod Description: Intercooler Foil Wrap is removed to increase turbo
spooling sound. No known benefits to performance except maybe a
small weight savings [img]/ubbthreads/images/graemlins/smirk.gif[/img] This is the Hot side CAC pipe (driver side), and the air in it is much hotter than the air in the engine comparment, so removing the insulation will do nothing to harm performance. Helpful Links:Forum Post
Mod Name: "Key-in-Ignition" Door Dinger Delete Mod Mod Difficulty: Easy Tools Required: Narrow prodding tool such as a very small screw driver Time to Perform: 5-10 minutes Mod Description: Removes that annoying dinging sound when your
key is in the ignition and the door is open. Turn ignition to RUN (do not start), insert prodding tool in hole under ignition and press the small ball/detent while pulling on ignition cylinder - ignition cylinder will come out. Look closely at the removed cylinder and find the small brass contact. You can wrap a bit of tape around it or simply pull it off. Reinsert ignition cylinder; it will click into place. Alternate method is to cut the black with pink tracer wire that runs up to the ignition cylinder. Helpful Links:
Mod Name: CCV Mod Mod Difficulty: Easy to Medium (depends on how much you want to spend) Tools Required: Screw driver for removing screws that hold doghouse breather to valve cover, new o-rings to replace those between breather and doghouse if yours are worn/stretched, and whatever tools necessary to assemble your mod the way you choose to do it (hose, hose clamps at a minimum) Time to Perform: 30-45 Minutes Mod Description: Crankcase Vent tube is rerouted from the
air intake to a small canister that traps oil residue. There are
several options for this mod ranging from a pre-built kit to doing it
all yourself. Also can simply route to the atmosphere: reverse CCV breather dog house that is on driver side valve cover, connect length of clear vinyl or heater hose to the existing elbow via a barbed connector and hose clamps, then route hose up and over brake master cylinder and down along frame rail to your chosen point of termination for the hose. Replace the CCV return piece in the intake tube with a small piece of 4" exhaust pipe. Helpful Links: ryaneverk2 webshots album, includes CCV mod pics for vent-to-atmostphere method Subman's post listing links to various homemade CCV setups
Mod Name: Always Bright Overhead Console Mod Mod Difficulty: Easy Tools Required: Wire snippers Time to Perform: 5 minutes Mod Description: Makes it so that the overhead console display does not dim when you turn on the headlights. Cutting the light blue with red tracer wire located under the passenger side kick panel. Helpful Links:Bill G's site including pic of said wire
Re: FAQ: Popular Modifications You Might See Referenced on the Forum
[ QUOTE ] Mod Name: 10K Mod Mod Difficulty: Easy to Medium Tools Required: 10,000 ohm Resistor, soldering iron, solder. Time to Perform: 10 mins to 1 hour depending on variation used. Mod Description: Insert a 10k ohm resistor across the ICP sensor to fool the computer into boosting injector oil pressure. Makes the computer think the HPOP and IPR are low and increases output. Variations: Variations include Adjustable 10k mod, 18k mod, Diode Clamp Mod. Helpful Links:Ford_Forgotton's 10k mod page
Mod Name: IDM Mod Mod Difficulty: Difficult to Very Difficult Tools Required: Soldering Iron, Solder, Sealant, Hand Tools Time to Perform: 1 hour to mod, 24 hours to cure sealant Mod Description: Originally invented by Joe_Servo. Remove a resistor inside the IDM and replace it with a higher value. Increases the injector driver module output voltage from 110 volts to around 135 volts. Extreme caution encouraged. Damaged IDMs are expensive to replace. Helpful Links:Ford_Forgotton's IDM mod page
aih mod. removing the air intake heater from the intake. the AIH is designed to reduce emissions by heating the air going into the engine at certain cold air, low rpm conditions.
The benefits are not measurable on a dyno, although from looking at it you would think it would help.
If we could develop these things into articles with one sticky post with links to various articles, that would be the best of all.
Thanks for the vote of confidence Kevin, I agree with what you're saying as well. I wanted to help out and figured this would be the easiest solution and would give us some feedback as to the best way to handle it in the future.
On a related note, could we crank up the timeout on editting posts so I can append some of the newest suggestions (sorry I missed yours Ryan!) to the original post?
Thanks!
Tony D. Berry
Lafayette, LA
Tony, if it's too late to edit your original post, try sending a PM to klhansen, a moderator, and ask him to edit the necessary stuff into your original post. I'm sure he'd be willing to make the necessary changes.
Ryan Arthur
2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat Performance Mods: ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator and tee, ATS ported housing, Banks Big Head, CCV Mod, DP-Tuner flip chip, BTS valve body ||| LEDs everywhere: taillights/running boards/mirrors/rear, side lights wired as turn signals, upgraded headlight harness w/ Xtravisions, aux backup lights in bumper ||| Misc. Mods: no more dingers, newer cupholder, fumoto, C-Betrs, locking fuel cap, mud flaps, wannabe air horn, Line-X, behind-seat storage shelf, intercooler foil wrap removed, SS HPX My Truck Pics
How about this one.
High Pressure Coss over, (HPX Mod) Easy install for the contorsionist (sp) Benefits; Equlizes high pressure oil in heads. And for the naysayers I will quote a PSD Engineer from FOKISD rally two years ago. " it makes sence and can only help equilize the oil pressure in both heads" Cost, I think about 35 bucks.
See ya Beantown
99.5 F-350 XLT 4x4 SC SB PSD Auto 3.73 w/factory rubber floors, Jody PMT1 reflash 80 hp tow, H/X Hose, IAH delete plug, AIS, Zoo Dad, Hutch mods, BTS Trans, Hayden 24K cooler & tranny filter, Banks wheel, EBV GONE, Fumoto Valve, 3.5 down pipe, 4" exhaust w/Magnaflow Muffler and 5" S/S tip, 3" rear blocks, Warn Premium Hubs, Bilstiens, Rancho 5406 stabilizer, Reese 16K 5th wheel rocker hitch w/ slide, Handy V gate, Prodigy, Goodyear ADT2 tires, 03 Excursion wheels, SP Performance C/D & Slotted rotors, Dipricol tranny gauge, Westach Pyro/Boost gauge, Nuvi 1490t GPS, RCI 2970DX peaked and tweaked good for 1/3rd RWHP every time I key the mic!, 10K Predator ant., Amsoil in trans and xfercase. Rotella T-6 5-40w full syn., Rotella ELC, 2003 headlights with Silverstar bulbs, Rear ICC 3 light bar, Luverne S/S running boards w/ 46" LED running lights.
The AIH Mod as well as a number of the other mods is covered in thread links HERE LarryM Little Secrets Sticky at the top of the van forum if you lose the link.
While I love diesels, I don't need one, and unfortunately, after much deliberation its a hobby I currently cannot afford.......... Gone but not forgotten:
1999.5 F250 CC SB XLT 4WD, 7.3 PSD, First F,2nd Diesel, nice but still liked the van better.
2003 E-350 Super Duty Chateau (Club Wagon)7.3PSD, 3rd Clubwagon,First diesel, Never should have sold it....
Another popular Mod for the list. Sonnax Tricumulator Mod- Replaces the Line modulator valve and springs for the shift pistons in the valve body of the transmission for crisper firmer shifts. Best instructions I have seen on how to do it are at www.blackclouddiesel.com They also sell the kit. Difficulty medium to hard,depends on mechanical aptitude. Requires socket set and Inch-pound torque wrench to properly torque valve body upon reinstallation.
removal?! I put one *ON*. Saves the paint from underhood heat.
But, if you want to remove it, its pretty easy. Use a skin wedge, or a door panel removal tool and jam it under all the plastic push tabs that hold it to the hood. Pry them out and off it comes. You may need to play with the hood light a little bit to feed it out of the hood blanket, but its all pretty easy. 10 min job?
I JUST WENT OUT TO MY TRUCK AND DID THE DOOR AJAR ALARM DELETE AND OVERHEAD CONSOLE LIGHT MODS.10 MINUTES AND ALOT LESS ANNOYING!I JUST WISH I KNEW ABOUT THE DOOR DING WHEN I WAS INSTALLING ALL OF MY ELECTRONICS UNDER THE DASH!
'02 Black F-350srw Lariat. 7.3/CC/SB/OR. BTS tranny with 6.0 cooler,coated TN bb1.00 w/Hi-flow outlet,Non-EBP ped,BWD coated/bellowed up-pipes,D.P Tuner.F5(stock,Hi-idle,60tow,80econo,120race),4" SS Magnaflow,BDS stabilizers ,Fluidampr,AFE Stage2w/PG7&pre-filter,Spearco 6.0 IC,PML pan,HPOX,Airdog,ITP reg.return,MAP Maximizer,8 spring front, BFG 315/75/16 AT's,DTS 4.56LS gears,Mag-Hytec cover,Dieselsite SS ESOF lines,coolant filter,203* stat w/billet&Fleetrite,Optix fuel on column,Ultra-Lite trans,pyro,boost on pillar.All fluids Mobil1,Energy polys,Centramatic,Fumoto,Billet,Line-X,Husky box,Extang,EGR,Alpine,Viper,Dynamat,Sirius,PIAA,Hu sky-Liner,Bilsteins. Door ding,overhead console,Snowman,Zoodad,Harpoon,AIH,Marinco,CCV,foi l mods. Hawks and Powerslot cryo's
