Re: FAQ: Popular Modifications You Might See Referenced on the Forum
So you guys took care of the key-in ignition buzzer but how about the ever so annoying seat belt dinger! Anything else you can do besides wear the seatbelt,or stick other the belt in, or push the button every time you start it?
01 F-250 Superduty XL 133,500 miles
31,500 miles on veggie
Ditched the Auto trans 4R100
6-speed Handrattla...
Clutch pedal
FASS pump
DP 80hp econo tune
Veggie oil undercoating and bedliner
Homemade veggie kit based on FN74
4" exhaust
DIY Tymar
tool box
rear springs
Shocks
275/75/16 BFG A/T's
203* T-stat
fuel pump
Water Pump
IDM
Dents
Rust
brakes
Front caliper
ball joints
all u-joints
2 fuses
more rust............
There is a procedure in the manual called BeltMinder Disable that you can follow. Or, you can reach under the seat and unplug the wire that goes to the seatbelt.
Ryan Arthur
2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat Performance Mods: ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator and tee, ATS ported housing, Banks Big Head, CCV Mod, DP-Tuner flip chip, BTS valve body ||| LEDs everywhere: taillights/running boards/mirrors/rear, side lights wired as turn signals, upgraded headlight harness w/ Xtravisions, aux backup lights in bumper ||| Misc. Mods: no more dingers, newer cupholder, fumoto, C-Betrs, locking fuel cap, mud flaps, wannabe air horn, Line-X, behind-seat storage shelf, intercooler foil wrap removed, SS HPX My Truck Pics
Thanks. Yes its a 7.3. With the "Breather housing" On the left cover, and I found the pics of the mod so now Im feeling rather noobish.... Heh..
"Blizzard" The big white bio-burning 03 7.3 4x4. 6637, straight piped stock exhaust, and a "New" secret blend of Haul a$$ing mods and upgrades. Suffice to say, its not the fastest, but it quite possibly is one of the quickest.
I didnt see the chrome badge (acetone) trick. Dont buy chrome badges when they are already on your truck! Tape off outside of the stock badges to protect paint. Soak a rag with nailpolish remover, or acetone. Spend an hour or two wiping away the black paint on your fender and door badges. The finished product is a chromed badge. Just like the one you can buy. I used Q-Tips on the door badge to get in-between the small lettering.
"DIRTS FOR RACIN', ASPHALTS FOR GETTIN' THERE"
99.5 f350 6speed, srw, cc, mods, DP F-5, boost -pyro guages, 5" exhuast, 165,000 miles
Yeh guys I did the Ic foil wrap mod and I was wondering anyone else did it how did they get all the old insulation off the pipe. Thanks
i did this mod to my truck you just peel it off as best as you can then i used 2 cans of brake cleaner and a wire brush to get the rest of off i ended up polishing both tubes when i was done hope this helps you
02 f250 4x4 w/ a 7.3 it has a 4in exhaust from the turbo back, s&b cold air intake, hyper junk stage 3 programmer, idm mod, foil delete mod w/ polished boost tubes, fuel cross over, hpx line, torque converter lock up mod, cvc mod, magnatec trans pan 4qrt over, 6in lift w/ 315 75 r16 bfg all terrains.
Overhead console light always bright.... I unplugged the light blue wire with red tracer as in the picture, but the light in the overhead console would not work at all afterwards. I saw a post where a guy with the same truck (2002 F-350) did it with success. What am I missing?
I just repaired my power door locks on a 2001 F250 Ext Cab (2 door). I wrote up my process and took some pictures. You are welcome to use this link (too much to say in a paragraph). Ill keep the images with the write up.
Mod Name: Power Door Lock Repair with tin foil
Mod Difficulty: Medium
Tools Required: Torx, drill, screwdriver, needle nose pliers, nut driver, tin foil, awl
Time to Perform: 2 hours
Mod Description: Repair weak working (may just click) power door locks.
Helpful Links: PowerDoorLockRepair
Bruce & Carolyn Wittmeier
2001 Ford F250 PSD, Ext cab, Shortbed, Island Blue/Silver, 4X4 Off-road, SOF Auto, Alum Wheels, DP-Tuner 40/80/120HP, Chrome Step, Line-X bedliner, Jordan Ultima 2020, AirLift 5000 Airbags, DiPricol gauges
87 f250 4wd LB ex cab 460 bored .60 edelbrock intake, towing cam glasspacks-6 mpg 8 on good day- my pride & joy once towed my '85 j-co j-crane 28' 5er
99 F250 7.3(engine stamped june of '99) 250K white ex cab lb, 2wd jl audio slash 4ch amp, jl 8" sub, focal components front, infinity coax rear, 10 disc changer
-tymar intake, no muff -bullydog egt, autometer boost -f5 chip w/80t, 80e, 60t, 100, 140 extreme(140 is amazing!) -ats housing/banks big head Chrome fender trim, 265 nitto terra graps, nerf bars, billet grille, '06 headlights, chrome door handles, louvered 5er tailgate
77ish chevy 1500 w/350 bored .30, torqer cam, some sort of intake man, hi perf elec. ignition, elec. fuel pump & fan, headers & single chamber flowmasters, kc lights, 9" lift, 40" tsl boggers, yukon lockers front & rear, dana 60 rearend, 3sp w/granny gear
ONE BAD MUDDER
I did this repair as well. After doing the passenger side and seeing how the actuator attaches to the latch, I discovered that it's not necessary to remove the entire latch. Simply remove the actuator from the latch by pressing the locking tab and pulling it off. Remove the connector and it will come right out.
Took me 2 hours on the first one and about 15 minutes on the other one.
Early '99 F250 SD, 4X4, SuperCab, Long Bed, 7.3L "PowerStroke" Diesel, Auto, PMT1 PCM w/DPTuner 80 tow, 190K miles,
Volant intake, ISSPRO gauges, BDS front leveling kit, 4" straight piped, Dick Cepek 18x9 DC1-Chrome, Nitto Terra Grappler 325/65R18,
Pro GOD, Pro Guns, Pro Life Important Notice, Pro Life changes when someone breaks in.
