Detailed FICM Repair Procedure - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 6.0L Power Stroke Engine and Drivetrain > 6.0L Power Stroke Engine and Drivetrain FAQ
6.0L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 6.0L Power Stroke Engine and Drivetrain forum.
Old 12-09-2009, 05:33 PM   #1 (permalink)
DrQuad's Avatar
Well I finally got around to writing a detailed FICM check and repair.
FICM pictures by DrQuad - Photobucket
DrQuad is offline
Old 12-09-2009, 07:03 PM   #2 (permalink)
HeavyAssault's Avatar
My Photos: (6)
I think the pictures aren't small enough........
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 12-09-2009, 10:25 PM   #3 (permalink)
DrQuad's Avatar
The small pics. are to save download time.
Here is the PDF
DrQuad is offline
Old 12-09-2009, 10:31 PM   #4 (permalink)
ace-tron's Avatar
Ficm
Do these compromised solder joints affect cold starts, fuel economy, etc.?
ace-tron is offline
Old 12-09-2009, 10:34 PM   #5 (permalink)
DrQuad's Avatar
Cold starts for sure.
DrQuad is offline
Old 12-10-2009, 10:17 AM   #6 (permalink)
Nice write-up. Are there any special follow-up procedures or tools needed after it's re-installed?
03 F250 SD Crew, Fx4, Lariat-160K
02 F150 XLT Super Cab-135K
07 Toyota Highlander-35K
2Tight is offline
Old 12-10-2009, 06:10 PM   #7 (permalink)
DrQuad's Avatar
None that I used.
DrQuad is offline
Old 12-11-2009, 12:06 PM   #8 (permalink)
Great Job DrQuad!
And it couldn't have come at a better time. My dealer just reflashed my computer and told me my FICM voltage was low.
I think I know what I'll be doing this weekend!
Happy Holidays!
Marc
2005 F-250 Supercab 4x4 Lariat long bed 6 speed, Vegistroke V3 WVO system, integrated brake controller, upfitter switches, TTM, South Texas Outfitters custom front end replacement, Whelen Liberty LED lightbar, Whelen Dominator LED front bar, hidden front strobes, rear LED's and strobes, Rhino liner, Whelen 200 watt siren, Havis Consolidator console, and other hidden goodies. Pictures are in "Shoebox" album.
http://community.webshots.com/user/vtfireftr
VTFireftr is offline
Old 12-14-2009, 02:31 PM   #9 (permalink)
Smile
Outstanding article, Should save the average capable person a lot of money from going to the dealers... Simple fix with the details.....
rbrodder is offline
Old 01-18-2010, 04:06 PM   #10 (permalink)
DrQuad......THANK YOU for this!!!
I LOVE YOU MAN!!!!
'03 250 CC SRW SWB, 4x4, XLT, 6.0 T/S, MBRP Turboback, Custom SCT, DiPricol Pyrometer, Adj Pedals, Reverse Sensors, ARE Z-Series Top, Sprayed bedliner, Remote Start/Keyless Entry, Edge Mini-spring pack, Bilsteins, 285's, Sirius Radio, Dark Highland Green
HBO1 is offline
Old 06-04-2010, 02:01 PM   #11 (permalink)
how do you check the voltage does the ficm still have to be hooked up to the truck when you check it or do you check it out of the truck
herc69 is offline
Old 06-15-2010, 04:43 PM   #12 (permalink)
Has anyone tried this. Mine has 34 volts when buzzing and 47 the rest of the time. BAD?
BIGDOGDIESEL is offline
Old 06-21-2010, 11:14 AM   #13 (permalink)
My 2005 Ex has the classic symptoms. I just check it and when my wife first turned the key to run, I got 34 volts for a few seconds, then it went to 48 and stayed there.
I had her start it and the voltage then read 45 while running.
so.....?
john roe
www.roenation.com
quietman is offline
Old 07-28-2010, 02:55 AM   #14 (permalink)
Quick question on the first page of your writeup - 4 pin FICM check.
It says to check the voltage with the key on, DO NOT START TRUCK. If I do this, my voltage is 48v, and the check procedure passes successfully.
The problem is that if I do start the truck my voltage drops down to 27v and stays there.
Since this is not mentioned in the check, I was wondering if I still need to repair my unit. I have read elsewhere that it also needs to be above 45V while the truck is running.
Just wanted to make sure before I tore into it.
Thanks.
2005 F350 Crew Cab 4x4 SRW LB White Lariat FX4 6.0
4.5" Donahoe Racing Lift with 5" rear blocks. 35x12.5x18 Toyo Open Country M/T's on stock rims. Air Lift rear air bags with onboard compressor.
Sold: 1996 F250 Super Cab LB XLT White 7.3L 124,000mi. 1996 F250 Photo
Sotoman is offline
Old 07-28-2010, 05:53 AM   #15 (permalink)
Paul H's Avatar
My Photos: (10)
That is correct the voltage should be above 45 volts at all times, if not your FICM has a problem.
Paul H
OWNER
2004 Ford F350 6.0L Dualie 214.000 miles with Edge Insight, Early Build 8/03 with 03 engine problem child
1996 Ford F350 7.3L Dualie 337,000 Tony Wildman custom burn,5 inch stacks, good ole girl
FOKISD CLUB MEMBER
FOKISD CLUB SITE WEBMASTER
http://www.fokisd.org/FICM.html
My Pictures
Paul H is offline
