I am not a big safety first guy but It should probably be added that the battery cables should be removed prior to doing this as I just got through with this install and there is a large 8-10 gauge positivly charged cable and lug just protruding to he outside edge of the fuse box. When you unscrew the 4 10mm head bolts and the fuse box is pulled out it can easily touch and ground itself on the metal areas of the dash. I know this because it happened to me and I started to unintentionally arc weld. Now I was listening to the radio and had the key on during this so maybe just the key off would do it but it was a pretty big spark. Great post though. It worked out great!
2006, F-350, 6.0, 4x4, Lariat, Crew Cab, Long Bed
Leer model 180 bed cap
MagnaFlow 4" turbo back muffler & exhaust system
Firestone #2400 Ride-Rite rear air bags
Isspro four gauge pillar set
HID Bi-Xenon headlights
Accufab intake elbow
DFuser coolant filter
Bilsteins all around
HFCM drain plug
Up-idle switch
Fumoto valve
Zoodad
Bear Hunter-
What is "cold weather strategy"? I live in North Idaho, it gets cold here. I was thinking I was going to install this in the morning, but I want my truck to warm up right.
Thanks-
2003 F-350 6.0L CC/SRW/SB 3.73 Auto..
Edge Juice Platinum w/ Attitude just to monitor
Xcal2 w/ID tow w/JAKE,Street,Extreme Street
K&N FIPK kit
NO TURBO or ELECTRIC PROBLEMS
3 injectors, 1 set of head gaskets @ 95,000 miles
rebuilt tranny, plates and soleniods
built 03/27/03
Bear Hunter-
Thanks-
The cold weather strategy automatically bumps your rpms up to like 900. The high idle Mod does not affect this factory feature.
__________________ TRUCK PICS Lifted by Truck-Toyz JAKD 2007 Dark Stone Harley Davidson Edition Super Duty Custom Built By Trucktoyzperformance.com
Special Thanks to: Trucktoyzperformance, Autometer, Rize Industries, MBRP, Line-X of Friendswood TX, Accufab Racing, Painless Performance, Retrax, OilGuard, and DC Customs
i guess i wont be trying this out on my rig.. i own a 03.5 6.0L.. this mod is only for the 05 and up correct?? i have to buy the ford AIC module then huh??? the BCP seems like a really good feature to be able to use, guess i have a reason to buy a new truck..
K&N FIPK kit
built 03/27/03
I have a 2007 6.0 without the upfitter switchs. I would like to add the high idle but I am a little confused. I have a 2004 that I have modified by putting a switch between the white/Lt blue wire located near the OBD II connector (12 volt with ING on) and the Lt blue/yellow wire near the e-brake. No Lt blue/yellow wire on the 2007. I connected 12 volts to the solid orange wire, like the article said, on the 2007 - idle did not increase. HELP
Can this be done on a 6-speed? It's a 06.
Yes...I finally got around to doing mine today. I used BCP method..uses the purple with green tracer wire, it's wrapped to the harness directly above the e-brake.
Went with the PTO option...works like a charm and brother was right on the tight space...I'm 6'5" 330 Lbs and hands like a Grizzly....tha part was pretty tricky [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img]
Thanks to the author for the instructions!
2006 F250 6.0 CC FX4 SWB White/Tan, Pro Comp 2.5" Leveling Kit, 33X12.50X17 Mickey Thompson MTZ's sittin on factory 5 spokes. Isspro EV's Tranny, EGT, Boost and a Quadzilla Xzillaraider-
