Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 6.0L Power Stroke Engine and Drivetrain > 6.0L Power Stroke Engine and Drivetrain FAQ
6.0L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the 6.0L Power Stroke Engine and Drivetrain forum.
Old 10-03-2007, 05:05 PM   #31 (permalink)
My Photos: (38)
Re: Seprentine belt - but what about the fan clutch wires?!
The second alternator is different than the primary. Different part numbers, and a different case.
Down low on the outboard side of the passenger side battery there should be a connector. The connector should have a green jumper wire in it. This is the connection for a second alternator. The parts list to convert to two alternators would probably go like this:
Second alternator
alternator bracket
ilder pulley and bracket
second tensioner
second belt
new primary belt - different length with the additional idler
alternator wiring harness
CAC tube
Fan shroud (bolted to engine)
idlers for second belt
harmonic balancer
PCM reprogram
If all the parts are in hand, it shouldn't be that big of a job. Probably a few hours...
The vehicles:
2000 Pontiac Sunfire (absolutely no extras)
1997 Ford Explod ..err.. Explorer (without the Firestone Rollover option)
1965 Ford Mustang (daily commuter until original owner's death)
1998 Trek 4300 (with upgraded brakes and Manitou Black fork)
The man:
Certified Trans Daddy
Master Certified Diesel *****
GregH is offline
Old 11-29-2007, 09:22 PM   #32 (permalink)
well I don't have to worry about cutting mine it was cut when motor was changed I thought it looked different and now I know so I guess I'll put screws in mine or order a new one from ford, thanks for letting me know it didn't have to be cut.
kyjeeper is offline
Old 02-10-2008, 10:17 PM   #33 (permalink)
Send a message via AIM to willi017
The dealer wanted $480.00 labor to change the single belt . Said they had to remove the Radiator and shroud ....
willi017 is offline
Old 04-10-2008, 01:08 PM   #34 (permalink)
Yesterday myself and a friend took on the task of replacing the serpentine belt and replacing an idler pulley. I have the single alternator set-up so we did the work without cutting the shroud or removing the shroud, but we did remove the plastic wing above the shroud. The whole process was no easy task, particularly putting the belt back on. I read most of the posts about this topic, but there is very little tips given for putting the belt back on. I was wondering if anyone has any tips or tricks they used for the install? Where did you start at? Is it just that much easier to go ahead and remove the shroud?
Thanks,
John
2003 F350 6.0 PSD 4X4 SRW
Engine13 is offline
Old 09-25-2008, 09:12 PM   #35 (permalink)
i have a sound more like a deep chirp. i think it is the belt. it only happens at idle, if it comes up at all it goes away. does not do it when it is cold. i know this is tough without hearing it, but do you think it could be the belt. if not i am only left with internal motor
1996 Crew Cab 7.3 DRW 5sp Banks Power kit, Luk Clutch, Air ride, Down pipe,Exhaust brake, 219,000m
1996 Super cab 7.3 Auto DRW, stock, 764,000m (RIP)
1986 Reg Cab 6.9 4x4 Auto 61,000m
1997 Crew Cab Centurion Conversion DRW 162,000m auto stock (wifes truck)
2005 Crew Cab F350 DRW 4X4 sport auto 6.0 leather 145,000
NCCER certified Heavy equipment operator
dirttracker05 is offline
