IS Born July 18-20/05 Delivered Aug 02/05.
0/6 F250,Lariat,s/cab,FX4x4,lwb,Auto,Captians,Tow Command,10,000lb gvw,upfitter,pedals,6-cd,3.73, ETC.
Y2K Komfort 24FSG Fiver With Slide Out,4 Trojans,120/watt/solar,Honda Generator/EU3000
Was Y2K,PSD,4x4,AUTO,XLT,Supercab,Wedgewood Blue & Silver, Most of the good stuff. 9/4/99 Roseville, Calif. K&N,Weathertech,Lund,Pro-Flaps,Line X,PPIII
My Daily Driver:
1986 F-250 2WD, Regular Cab, LWB, 6.9, T-19, Sterling 10.25", open 3.55's, XLT Lariat, Texas Sesquicentennial Limited Edition, No Restrictor Plate, manually switched high idle/advanced timing, and an awesome custom shift knob thanks to Bruce Roosa / Koolknobs.
279,000 miles and counting, hoping for a US Gear OD and a Hypermax Turbocharger one day.
My first truck:
1982 F-250 4WD, Extended Cab, LWB, 5.8, C6 to T-19 swap, BW 1345, Dana 44 TTB/Dana 60 Semi Floater, open 3.55's. About four different colors (not counting rust), currently on loan to my little brother. Maybe one day it can be home to a 6.9L too.
Work Truck:
1992 F-700 Flatbed w/ dump, 7.0L BIG BLOCK GASSER, 5-speed trans (Clark?), 26,000 lb GVWR. Rides like a tank
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
1990 F250 7.3 IDI with 5 speed manual ZF transmission
__________________ 1992 F350 7.3 Liter IDI Four door long bed 4x4 5 Speed Manual ZF. Future: ATS Turbo, John Deere green paint job, gear vendor overdrive kit, Herculiner for the bed, and WVO fuel kit. Also 1990 F250 7.3 Liter IDI two door supercab with 5 Speed Manual ZF planning to sell after I pull my cd player, CB radio, and slider back glass out.
