2008- 2010 General QuestionsGeneral questions related to 2008-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
has anyone had or heard of the rubber on inside of 2001 F350 tank coming off and clogging the fuel system? Had to get towed home. Fuel filter full of black rubber from inside the tank.
I cannot find a thread on it..
'00 Lariat LE, CC, 4x4, Dually, Fully Loaded,K&N air filter, DynaFlow muffler, Class V DrawTite,LineX, HypoIII programmed, AirLift bags,
Haulmark trailer with 2 Harleys in back, also towing a 24' True World Marine boat.
The only "rubber" inside the tank is the pickup foot. The lining on steel tanks isn't rubber and there is no lining in the poly tanks. There are rubber hoses on the way to the pump - I wonder if they are breaking down. Have you been running anything other than #2 pump diesel?
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
