2009 F350 Shortbox to tall for 5th wheel camper - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 11-11-2009, 12:41 PM   #1 (permalink)
So my new truck is too tall for my trailer that already has the axles flipped. It was suggested I replace the 4" blocks on the truck with 2" blocks. Anyone done this? If so wher did you get the parts - any old ford parts center? I guess the other option
2011 F350 CC SWB - Lariat 3:55 w/20" wheels - Oxford white.
afacey is offline
Old 11-11-2009, 01:12 PM   #2 (permalink)
69mach1377's Avatar
Will 2" do it?
That has been done with older trucks before...
2000 F250 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, otherwise mostly stock.
24' 5th wheel camping trailer, no RV parks...just the woods.
2005 VW Passat 2.0 TDI, 40+ mpg hiway
1969 Mustang Mach1 HotWheel, 377 clevor, R&P steering, 3.50 posi, 2003 Mach1 Wheels (17s)
69mach1377 is offline
Old 11-11-2009, 01:16 PM   #3 (permalink)
Pretty sure 2" will do it. The alternative is to have the shackles cut and reattached to a 2-3" extention on the trailer.
afacey is offline
Old 11-11-2009, 01:22 PM   #4 (permalink)
I wouldn't raise the trailer any more. Higher CG and winds suck. Find someone to swap blocks with. Plenty of people want the taller blocks in their 250's, so it should cost you nothing IF you are comfortable reusing U-bolts.......So, uh, where are you located? I've been thinking about raising my 250 to 350 heights, but I need to check my roof clearance at my garage door!
Jerry
Black 2010 Ford F250 XLT Crewcab Longbed 4x4 6.8L V10. Special Ordered. 295/70r18 Nitto Terra Grapplers on black powdercoated stock wheels, Harley Davidson Edition headlights. FX4 Grille. Recon smoked cab lights and mirror lenses. Factory bumpers and nerf bars have been powdercoated black.Husky Mudflaps,custom black 4" exhaust, AirAid intake, X3 tuner from 5 Star Tuning, AutoVentShade door sill protectors. Soon will black out the badges.
Jerry Miller is offline
Old 11-11-2009, 03:27 PM   #5 (permalink)
SmokeyWren's Avatar
My Photos: (44)
10 years ago we had the same problem. Ford issued TSBs to fix the problem, but usually the result was vibration in the driveline that Ford couldn't fix. So the only TSB left is 99-14-5. That one mentions TSB 98-17-2 which was to remove the spacer blocks altogather. That should be a no-brainer because 4x2s don't have spacer blocks. But folks had vibration problems when they tried to completely remove the blocks from 4x4s, so Ford cancelled that TSB. Maybe you can find it in some ancient lists of old TSBs.
Click on the following link for TSB 99-14-5. Note it's a lot more complicated than it at first sounds. You must replace the blocks, U-bolts, shocks, brake hoses and stabilizer bar links. And you have to adjust - and may have to replace - the driveshaft center support bearing.
And the part numbers in that old TSB probably won't fit your newer truck, so use the TSB as a how-to guide but don't rely on the parts list.
TSB 99-14-5
Every suspension expert in the world says you must always replace u-bolts every time you remove them. So don't be an idiot that tries to get by cheap without replacing the old u-bolts.
SmokeyWren is online now
Old 11-11-2009, 05:17 PM   #6 (permalink)
What kind of 5er do you have? I am in the midst of trading my 08 f150 for a 08 f350 and I am afraid of the same thing. I had to take the blocks out of my 150 to fit
Canuk is offline
Old 11-12-2009, 12:10 AM   #7 (permalink)
Yeah where are you located, I would happily swap blocks with you. My 5er is plenty tall for this.
2008 F250 Powerstroke
FordMudder is offline
Old 11-12-2009, 03:29 AM   #8 (permalink)
I am agreeing that you should not raise 5er more than fliped axels. Are you to close at bed rails or at hitch point in which case there are several bolt on hitch options for both truck and 5er to rectifie the problem. I had a trailer with 31/2 inches between trailer and bed on level ground. Supriseingly I never had them touch.
2004 F250 CC 6.0 PS , no mods
da-bees is offline
Old 11-12-2009, 05:05 AM   #9 (permalink)
JuggyGales's Avatar
also, what size carrier bearing spacer would he need? I put one in when i did my small lift, but what about lowering the rear of the truck? is there a spacer already on the 350s?
pm sent about swappin blocks, mine are sittin in the garage...
'08 F-250 FX4 PSD CC, SB, SRW, ReadtLift 3.5" SST, TransferFlow 50 gal, Obama interior,
JuggyGales is offline
Old 11-12-2009, 02:24 PM   #10 (permalink)
BTW, I agree about repacing the U-bolts. However, plenty of add-a-leaf kits from major suspension lift companies have people reuse the old rear u-bolts all the time. If I were to reuse a u-bolt, it would be the rear ones, not the fronts (although we don't have front u-bolts now) Replacements are the better option.
Jerry
