4 in blocks in a Dually - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 11-12-2009, 09:43 PM   #1 (permalink)
If I were to replace the 2.5 in blocks that are between the axle and the springs in my dually with 4 in blocks from a SRW truck what else would I need to change. Would shocks be long enough, would I have to shim the carrier bearing etc. I haul alot of heavy loads and would like the back of the truck to be a little higher.
2008 F-350 Dually XLT 6.4, 6spd, 4.10, Crew cab, Manual 4x4, Forest Green, 5" Diamond Eye Exhaust, AFE Stage 2 Intake, SCT Programmer
GreenDually is offline
Old 11-12-2009, 11:56 PM   #2 (permalink)
l.gerard's Avatar
Might want to change the shocks but the stock ones would probably work OK. Other than that you shouldn't need anything else.
2002 F-350 Crew Cab, DRW to SRW conversion, 6spd, 5'' lift, 16x8 Ultra chrome wheels, 35'' nitto terra grapplers, Rough Country dual front shocks, Bully Dog air & pre filter, Autometer Cobalt pyro & boost gauges, 4'' downpipe with 5'' exhaust,
l.gerard is offline
Old 11-13-2009, 10:03 AM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Ford now has TSB 07-7-2 applicable to '05-'08 pickups. Note it's a lot more complicated than simply changing the spacer blocks.
Here is a severely edited list of the steps required. Refer to the actual TSB before you begin:
1. Remove U-bolts and nuts.
2. Place new spacer blocks on axle and raise axle to bottom of springs, seating springs in axle seat.
3. Install new rear axle U-bolts and nuts
4. Install new rear shock absorbers
5. Replace rear axle brake jounce hose assembly with new assembly. Bleed rear brake system.
6. Replace rear stabilizer bar links with new stabilizer bar links.
7. If necessary, install new (driveshaft) center bearing and/or shim assembly as required.
8. Check driveline angles
9. Adjust headlamp aim
SmokeyWren is offline
Old 11-15-2009, 09:28 AM   #4 (permalink)
I have read that TSB as well. Most of the items in there are unnecessary. Brake hose is fine. Stab links are fine. Shocks are long enough. The only thing that needs changed is the blocks and u-bolts. Some guys have needed to shim the carrier bearing and some haven't. Can't tell you for sure if you will need to, but it's not hard to do if necessary.
2009 - 250SD - Lariat - 4X4 - SB - SC - V10 - 4.30's - Royal Red/Black. Going in on trade the end of the month.
2012 - 350SD - Lariat - 4X4 - SB - SC - 6.7 - 3.55's w/elock, Ingot Silver. Being built Feb 17th. Should pick up around the 1st of March...
taken is offline
