Audiophile Subwoofer - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 09-21-2009, 09:55 AM   #1 (permalink)
Will an Audiophile subwoofer from a 2009 F250, plug right into a premium sound system on a 2009 F250? Is the wiring harness present behind the back seat although it's not a Audiophile system?
bowser is offline
Old 09-23-2009, 01:23 PM   #2 (permalink)
FX4Driver's Avatar
I don't know for sure but would think so. I would imagine only one harness for the radio to save costs.
Perhaps the dealer where you bought your truck would let you look at one with the Audiophile system.
Bill
2008 F350 FX4 CC PSD SB
Most everything but Nav & DVD
Line-X bedliner
BakFlip tonneau cover
Reese 5th wheel hitch
Autodimming mirror with Homelink, compass & temp
HD radio and iPod adapter
FX4Driver is offline
Old 09-24-2009, 05:46 PM   #3 (permalink)
the other question is, does the radio have the output for the sub???
2008 F-450 Lariat loaded on order 7/3/07 delivered 9/13/2007 Pueblo Gold and all the goodies except Nav radio and moonroof and Fisher 8'6" X-blade
2005
F-350 Lariat LOADED CC SRW LB 6.0 SOLD
Med. Wedgewood Blue
All Options except moon roof
8'6" Fisher X-blade SS
2003 PSD 6.0 Lariat CC SB SOLD
All options but the moon roof
Scottb NY is offline
Old 09-24-2009, 05:55 PM   #4 (permalink)
F450Mikey's Avatar
Nope! I had a loaner with Audiophile system and tore the interior panels out to check it all out. Totally different harness and the radio is different (I am told).
2008 F450 Dark Shadow Gray Lariat "Pick Up" Job 1
2006 Weekend Warrior FSC 2800
2005 Honda CRF 450R
F450Mikey is offline
Old 12-29-2009, 02:58 PM   #5 (permalink)
I went ahead a ordered a used OEM subwoofer (oem box, speaker, amp) from a 2008 f250. I want to put it in my 2009 Lariat F250 with the standard premium sound radio. I figured there has to be a way to make this work. I understand it goes behind the rear seat on the driver side. The problem is I haven't the foggiest idea on how to hook it up. I may have to take it to an install shop. As a matter of fact, I can't figure out how to pull out the radio - there are no places for the usual tools to be inserted.
bowser is offline
Old 12-30-2009, 12:38 AM   #6 (permalink)
The harness atleast on my 08 F250xlt without the premium sound was hanging up under the dash by the radio. As far as removing the radio from what I remember its a screw on each side towards the bottom. The one is behind the panel with aux line input on the right side and the other is behind the same looking panel on the left side. Both have a small slot you stick a screwdriver into to release. Then after you take the 2 screws out it should pop off if I remember right. Then there will be 4 screws to remove the radio. The radio will need to have 3 plugins on it instead of 2 for the sub to work. You'll plug the hanging harness behind the dash into that then the other end has to be under the carpet somewere. I did it on my 07 F150 and it was under the carpet in one of the slits for a seat bolt.
ndmtnsledder is offline
Old 01-10-2010, 12:09 AM   #7 (permalink)
Couldn't find the harness, so had to run the wire. Hooked up the power on cable (ign) to one of the aux switches. Connedted the sub to the speaker wires. Getting good sub sound.
bowser is offline
Old 01-29-2010, 07:09 PM   #8 (permalink)
I'm exactly in the same boat. I have a 2010 F-250 and just ordered the full OEM Navigation system that comes with a separate amp. Then, I bought a used OEM sub. Now, I haven't been under the dash yet, but I did search in the back for the wiring harness...anyone know if it's there or how far it goes back? Thanks
georgeobryan is offline
Old 01-30-2010, 08:07 PM   #9 (permalink)
I failed to mention that I did find an unused wiring harness behind the radio, but it didn't look like it had any contacts in it. After removing the rear seat, I didn't find the other end of the harness. So, that's why I had to run new wiring to the radio and splice into the speaker wiring with a subwoofer kit available from most installation shops.
georgeobryan, I have a feeling that if your truck did not come with a subwoofer, you are going to have to do what I did. However, the new system you ordered should have a plugging for the subwoofer wiring. So, make sure you order the subwoofer adapter/plug for that system.
bowser is offline
Old 02-09-2010, 04:43 AM   #10 (permalink)
freekyFX4's Avatar
I removed my Audiophile sub/amp and it's sitting in a closet, where it has been for two years.
2008 F250 FX4 PSD - 35x12.5x20 Toyo Open Country M/T - 2" Leveling Kit - Nathan K5LA Train Horn - Four PIAA 525 SMR Lamps - Warn HD Winch Bumper
Got patriotism? Buy American!
freekyFX4 is offline
Old 02-11-2010, 07:53 AM   #11 (permalink)
I've read that there is a junction at the base of the right rear passenger pillar that connects to the unused wiring harness that you mentioned. Anyone else know if this is true and if so, a wiring diagram?
Old 02-18-2010, 10:02 AM   #12 (permalink)
bump...
