2008- 2010 General QuestionsGeneral questions related to 2008-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Anyone know how to disable or change the time amount on the Auto shutdown on the 2010 F-450?
01 F-550 XLT,4x4, 7.3, 6spd Truckcraft flatbed w/9 ton hoist, 9' Fisher M/C plow, Fisher 2.5 yard Poly caster Gooseneck ball, Auto Meter Pro Comp gauges in the pillar, 4" turbo back straight pipe,wicked wheel, prepump mod, zoodad air box mod, AFE stage II, shimmed fuel psi, DI Mini Me 530's, Boost blow off,TS 6 pos chip, Michelin XDE's.
06 F-350, 6.0 4x4, Ext cab, Short bed, SRW, Auto, Lariat, fisher 9'6" SS Extreme V plow, Fisher Poly caster, Rhino liner, Donahoe 2.5" levelling kit, Toyo M/T's 35x12.50x18's, 4 gauge pillar with Auto Meter Pro Comps, MBRP Turbo back exhaust, Stage 1 fuel system, SCT tuner, Pro Tech Aluminum Head ache rack,
2010 F-450 King Ranch 4X4. Fisher SS 9'6" Extreme V plow, 2.5 yard Fisher Poly Caster, Pro Tech head ache rack, Good Year G124 265/70X19.5's, Icon levelling kit,
Thanks whats the trick to setting up the PTO switch to be used like an auxilary idle controller?
If your truck has the optional upfitter switches, it's relativerly easy. If not, it's a little tougher.
The elevated idle control logic is programmed into the PCM, but it's not activated unless your upfitter or Ford dealer did it. Instructions on how to do it are in the body builders advisory series (BBAS) on fleet.ford.com https://www.fleet.ford.com/truckbbas...bodybuild.html
Great Thank you guys for your help! Any other cheap mods I can do while I give her time to break in?
