Bed Damaged behind cab - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 02-27-2010, 09:02 PM   #1 (permalink)
derekuk101's Avatar
I had two 200lb protein tubs in the bed and had to slam on the brakes and they moved and hit the front of the bed and bent it towards the cab. There wasn't any damage to the cab. Curious to see if this has happen to anyone else, and if so how much did it cost to fix? I checked our old farm truck and it has the same dent in it behind the cab. I'll need to decide if this is worth fixing or not. Btw the truck is a 2008 250 crew cab.
derekuk101 is offline
Old 03-01-2010, 12:07 PM   #2 (permalink)
The same thing happened to my buddys Dodge hauling the same kind of tubs. I think he is looking into a tool box, back rack, or box cover to mask it somewhat - he said its not a cheap fix! He wants to pull it back somewhat and cover it up. I had something similar happen once but it was to the tailgate when some suitcase style tractor weights slid backwards on my plastic box liner and bowed my tailgate quite badly!
2008 F-250 Lariat SRW 4x4 CC SWB...
··· 6.4L & Torqshift w/3.73
··· Dark Stone Metallic / Pueblo gold
··· Readylift 3.5" levelling kit
... Toyo MT 315/70/18(bigger than 35-12.50-18)
----- --- BIG$HOW -------<Õ¿Õ¬
Bigshow is offline
Old 03-02-2010, 08:49 AM   #3 (permalink)
General suggestion (not directed to you). I have a cab rack. I love it. It's saved my bacon countless times. It will add rigidity to the bed, but if the stuff you're hauling is not tall enough to clear the lip of the bed, you still may have that issue with shifting loads causing damage to the bed. Otherwise, it does a great job of ensuring that the cab is protected and adding rigidity to the bed. Fix the bed. Then future future hauling, place the load up towards the head of the bed and then use a combination of your stakepockets and anchors to secure your load. If you've got the cab rack, you can use that as well.
2008 F250 PSD XLT Super Cab Long Bed (4x2)
2006 Nissan Titan, 6 inch Procomp lift (4x2)
2000 Nissan Frontier, Custom Motorsports 8 inch lift (4x2)
timid1 is offline
Old 03-02-2010, 08:53 AM   #4 (permalink)
senix's Avatar
You could try to pull it back. Could you get a long piece of 2x4 in between the bed length wise? One person on each end and pull towards the bed of the truck?
Just a though. I would want a little clearance to still be there so it doesn't rub.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 14K.
senix is offline
Old 03-02-2010, 02:32 PM   #5 (permalink)
Getrdun's Avatar
Contact your local paintless dent repair guy. They can do miracles with their tools and fairly affordable. Plus while you have him there, take care of any door dings elsewhere on your truck.
Getrdun (aka Chad)
Construction Executive, Reside in CA but still call South Dakota home
Retired Navy after 20 years in 2008
2008 F-350 King Ranch DRW, Tow Boss, 4x4, Navigation, DVD, Oxford White, (i.e. everything but sunroof) (mine on Mar 6, 2007)
Getrdun is offline
Old 12-06-2010, 07:34 AM   #6 (permalink)
What did you end up doing? I am facing the same problems now and am considering pulling the bed off and trying to pound the dent back out.
02 SWB CC 4x4 auto, AIS, DPTunerF5, FTVB, 4" Banks Monster SS Exhaust, HPOXover, AirDog, Amsoil ByPass, Centramatics
blackout is offline
Old 12-06-2010, 12:11 PM   #7 (permalink)
tvandyck7's Avatar
If it bent the top lip out of whack (which it sounds like it did), PDR is hopeless.
If it were mine and I was trying to get out cheap, I would pull the bed off, straighten it as much as possible and then take it to the Line-X shop. Depending on how straight you get it, Line-X might cover it up.
The only problem with all of this is, once bent (if it was creased), the top lip will have a weak spot from then on even if you straighten it out.
Post some pictures so that we can see how bad it is.
2009 F-250 6.4L PSD CC SB Lariat Ultimate FX4, 3.73LS
Mod List:
-51 gal RDS direct fill auxillary fuel tank
-SEIC High Idle
-H&S Black Maxx Running the Hot Damn +300 Tune
-S&B Dry CAI
-Diamond Eye 5" Turbo Back Race Exhaust
-Custom 10" Sub Box Behind the Center Console
-Coastaltech SYNC-LP1 Lockpick
-Westin Bull Bar
-Westin Taillight Guards
-Recon LED Smoked Dodge Cab Marker/Clearance Lights
-Billet Fender Vent Inserts
-Zone Offroad 4" Lift
-20x10 BMF Novakane 8's
-35x12.50r20 Nitto Trail Grapplers
-'11 Super Duty Rear Seat Cargo Tray w/410W Power Inverter
tvandyck7 is offline
Old 12-08-2010, 11:22 PM   #8 (permalink)
use a come along hooked up to the tie down hooks and pull till straight all u can really do for cheap
chodifer is offline
