Cabin Temp Regulation - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 01-14-2008, 02:55 PM   #1 (permalink)
lhrhodes's Avatar
Send a message via Yahoo to lhrhodes
Anyone on the forum experiencing difficulty regulating temperature in the cabin of your new 6.4? I've got the lariat pkg in my 250 CC which includes dual climate controls. Sat morning was running the defrost and after getting nice and toasty in the cab, proceeded to lower the temp just a hair. Next thing I know, the defrost is blowing cold air. We're only talking a drop from 85 to 78 on the thermostat, which should not warrant as dramatic a change as I experienced. Anyone have similar issues?
2008 6.4L F250 CC 4x4 Lariat, Job 1 build, Silver Metallic, Torqueshift 5spd Auto, 3.73, ESOF, Block Heater, Camper Pkg, Offroad Pkg, Audiophile Stereo, Leather Captains Chairs, Heated Seats, Tow Command, Upfitter Switches, B&W Turnover Ball
lhrhodes is offline
Old 01-14-2008, 04:33 PM   #2 (permalink)
Re: Cabin Temp Regulation
ive never had that happen before, but maybe it was trying to compensate for the change in temp, by cooling down the cab, what happened when it reached 78 did it maintain? The only prob i have with mine and my 06 as well, is when the snowplow is on, it blocks the air to the ext. temp sensor it will read over 100deg. and a/c will come on when ambient temp is 20's. I cant belive they havent dealt with this its a real P.I.T.A. truck has snowplow prep...i cant be the only one plowing with a lariat
2008 F-350 ex-cab shortbed lariat 4x4 6.4 torqshift 3.73L.S.dark stone w-two tone pueblo gold trim 8ft Fisher minute mount II
1997 F-350 4x4 DRW XL PSD auto, fisher 9ft minute mount, knapheide util body, 8ft SS buyers sander
Chrisb444e is offline
Old 01-14-2008, 05:08 PM   #3 (permalink)
did you have it set to "Auto" by any chance? ive read that the truck cab can be very warm, or think its very warm and if you drop the temp a little bit it will blow cold air. This only on the auto setting though. I just hit the button in the middle and have the arrows showing air blowing on my head and feet. Never had a cold air problem.
04.5 Ram 2500 CTD 600, Bullydog Tuned
Traded for 07.5 GMC Sierra SLT Dmax, Loaded
Traded for 08 F250 6.4 Lariat CCSB, Loaded
Traded for 08 Ram 1500 5.7L Hemi, Lots of options
TurboForMyTurbo is offline
Old 01-14-2008, 05:18 PM   #4 (permalink)
StanMI's Avatar
Bama
78 degrees will feel like cool air to the touch. That feeling might be enhanced from being in the 85 degree temperature and feeling toasty for a time.
Did it feel OK after the temperature regulated ??
2008 F350 Lariat CC Black two tone and darn near everything else.
StanMI is offline
Old 01-14-2008, 05:29 PM   #5 (permalink)
yes it is always on auto, but your right if you put to manual it gets better, but i have to keep cabin air temp set to around 90 to get good heat
Old 01-14-2008, 05:58 PM   #6 (permalink)
lhrhodes's Avatar
I did have the heat on auto. After feeling the cold air blowing, and I mean it was cold, I turned the heat completely OFF. Waited a few minutes and then switched onto manual and did not have any problems. It makes sense that the auto funtion might have been trying to regulate the temp from 85 to 78 by adding cool air. Thanks for the insight.
lhrhodes is offline
Old 01-16-2008, 03:09 PM   #7 (permalink)
Mine does the same thing with my plow on. I called the dealer and there is a TSB on it for snow plows and winter front users. Right now there is no fix but the TSB says to run the heat on defrost mode or vent mode with the temp at 90. Then regulate the heat with the fan. I still have to open the windows or sunroof to get rid of the extra heat.
I thought about moving the external temp sensor from the pass side headlight to the bumper to see if it would help...
08,F450,4X4 Lariet, Crew Cab, 6.4 psd
07,Dodge, Quad Cab Dually, 5.9 Cummins,4X4, 6 Speed
05,Dodge, Quad Cab Dually, 5.9 Cummins,4X4,AT
03,F250,6.0 PSD, 4X4, Shorty,Crew Cab,Lariat,4"Pro Comp Lift.
03,Excursion,Limited,V10,4X4,4"Pro Comp Lift.
03,Harley Davidson, Road King, Lots of chrome..
01,F350,7.3 PSD,4X4,DRW,Crew,4"Pro Comp Lift
Pics: http://community.webshots.com/user/banshee069
banshee069 is offline
Old 01-18-2008, 08:59 AM   #8 (permalink)
yeah its def. annoying this happened on my 06 as well, you would have figured they would have done something about it in the 08 along with all the other improvements. I htink the sensor would be blocked in the bumper as well.
Old 01-22-2008, 12:57 PM   #9 (permalink)
lhrhodes's Avatar
First and foremost, sorry to bump this up to the top of the new '08 powerstroke only forum, but since already here before the upgrade, thought I'd continue where we left off.
Well, it happened again, this time on the MANUAL setting. Not such a drastic temp change, but slowly ratcheting down in 1-2 degree increments every few minutes. By the time I got to 80, the heater was blowing cold air again, out the dash, out the defrost, out the floor, no matter where I directed the fan, I was getting cold air. Shut the heater off and restarted. What do you know, back to hot air again. I'm thinking I may have a faulty thermostat in the heating system. Thoughts?
lhrhodes is offline
Old 01-22-2008, 01:26 PM   #10 (permalink)
I know it would still be blocked by th bumper but I thought maybe, it would not get as much heat from the engine compartment.
