Considering an 08 F-450 with 6.4 - Advice? - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 12-31-2012, 03:31 PM   #16 (permalink)
Powerstroke2000's Avatar
My Photos: (17)
Originally Posted by guardrail22 View Post
The 6.4 is the best diesel Ford used in the superduty. The 08-10 truck is the best styling.
Find an F450 with the 430 gearing in it, either 08 or 09. Mine has 133000 miles on it, has saved my life once and as long as I have to pull this will be what pulls.
I've got an '09 F450 King Ranch with 85K on it, and it's had some warranty work done, but I'm loving the truck! I load it up with a heavy 9' 10" Arctic Fox camper, and then add an 18' trailer loaded up, and it truly 'hauls' wonderfully, as well as holds back on the hills great as well with 'tow' mode engaged. You just can't go wrong, so long as you do your homework, and have all and any warranty issues topped up prior to receiving it. The tuner/dpf delete can eventually help you out with longevity as well.
2009 F450 4X4 Superduty King Ranch
6.4 Diesel, 4.30's.
Powerstroke2000 is offline   Reply With Quote
Old 12-31-2012, 07:51 PM   #17 (permalink)
450 bigger is better
i have an 08 f-450 with 117,000 miles on it with 4.88 rear .
yes it runs at higher rpm's than other trucks with lesser gears has less gas milage,but if i want better fuel economy i'll drive the mini cooper .
this truck hauls my 32' tow behind , bed filled with 3 dirt bikes like it is empty . i had an 02 f-250 gas and was tired of being under powered and marginal awww factor .This truck turns heads and leaves the others in the dust .
I was looking for the f-350 and found a better deal on the 450 . At the time i wanted a diesel , 05 or newer 30,000$ range and now have more truck than i need. Just do some homework and the money you save buying a used truck can more than pay for the dpf/egr/and mini max set ups .
ironivar is offline   Reply With Quote
Old 01-01-2013, 09:55 PM   #18 (permalink)
guardrail22's Avatar
Ford : F-450 REARVIEW CAM in Ford | eBay Motors
New Truck
2012 F150 SuperCrew Lariat 157" VWE
Traded March 2012
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver, 2010 NAV and Sync
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch
guardrail22 is offline   Reply With Quote
Old 01-02-2013, 04:15 PM   #19 (permalink)
I must have had one of the Bad ones. I had an early build 08' 450. I Traded it in with 45k on it due to three radiators in three years. On the third radiator I asked the dealer what was the diff between this one and the last two? Reply, Not a thing. Fuel milage was also terrible, it had the 4.88's. towed are horse trailers great when it wasn't in for service, just not a reliable truck. I traded it in on a 2012 and couldn't be happier. Moral of the story, if you see a big red 450 for sale with 45k plus out of the seattle area, keep on looking you want nothing to do with it.
westcoast is offline   Reply With Quote
Old 01-04-2013, 08:38 AM   #20 (permalink)
If you got three identical radiators then your dealer didn't know what he was doing. They did make a chnage (they knew they were duds) and not there are aftermarket radiators out there with lifetime guarantees.
Mine went 104000mi and Ford paid for the replacement.
New Truck
Traded March 2012
Traded In Nov 07:
Old 01-04-2013, 10:59 AM   #21 (permalink)
get the 450 you will not regret the larger truck. I'm running a 350 now and its not enough truck with 12,000 lbs. Have already added springs and replaced rear axle. Looking for a super duty or 550 to replace it.
bathexpert is offline   Reply With Quote
Old 01-05-2013, 06:11 PM   #22 (permalink)
http://cgi.ebay.com/ebaymotors/2010-...item5d386761c3
New Truck
Traded March 2012
Traded In Nov 07:
Old 01-05-2013, 11:32 PM   #23 (permalink)
GD, Thanks for the insight, I had a brand new truck that with in 45k it had three radiators. I was glad to see it go, regardless if they new something was a dud or if they had fixed something. my wife drives most of the western states for horse shows and that truck was not reliable, the standin joke was that we should carry a spare radiator in the back for roadside replacment.
Old 01-10-2013, 05:51 PM   #24 (permalink)
Powerstrokin400's Avatar
My Photos: (18)
Originally Posted by senix View Post
6.4 is a good motor. with a vin you can ask the sa at your local dealer to run it for you to see.
Af350 is a 1 ton. F450 is overkill for you.
F350 either srw or dually will do just fine. either 3.73 or 4.30 gears does not matter.
I tow heavy with mine all the time. I would not want a 7.3 or a 6.0. simply because they don't have the power or the nicer interiors. When you spend alot of time behind the wheel that counts.
I have 74K and 1900 hours on my motor and it has been just fine.
Wow!!!! The 7.3 doesn't have the power??????? I guess that's why everyone wants to buy my truck!!!! LOL ;-) I get offers almost daily. The ONLY diesel produced since 10/2002 that can come close to competing with my 2003 F250 7.3 is the new 6.7. I might have an advantage @ 400+ Hp & 850 lbft tq. Every time I look into trading up, the $65,000 sticker shock scares me away.
Anyhow, my little brother is looking into a 2010 F250 with the 6.4L. Trying to steer him away from that fuel sucker. He is on a budget & needs a newer truck. My advice was to go with Dodge from 10/2002 thru 2010, unless he could swing a 6.7L. That is hard for me to say being a "Die Hard" Ford guy. I haven't met many people that are totally happy with the 6.0L or the 6.4L. Biggest complaint, a side from the early "Fire Breathing" 6.4L, is the crappy mileage. The 6.0's just need too much (For my brother's mechanical aptitude) to be reliable. So....... As long winded as this is, and in the event my brother HAS to have a 2010 F250 6.4L, any Cinderella stories????
By the way, NO offense to you 6.0 & 6.4 guys. I'm "Die Hard" Ford, just love the 7.3!
2003 F250 XLT 7.3L, Auto, FX4, Crew Cab, Long Bed, 6.5" Pro-Comp all spring lift & Firestone HD Rear Air Bags, BFG KM2 37x12.50x17 tires on Eagle 17x10 Rims, 4" Turbo Back Exhaust & muffler delete, Bully Dog Programmer, Machined & Bellowed International Up-Pipe Kit, Autometer Overhead Gauges (Boost, Pyrometer, Trans. Temp), Custom Ram-Air with K&N filter, "John Wood" Custom Trans., 6.0 Billet 3 Disk T/C, External T/C Lock-up switch, 6.0 Trans Cooler, Hughes Racing Deep Structural Pan, and a few more goodies. Spinnin' AAM Rear & Dana Spicer Front 4.30:1 Gears, Warn Premium Locking Hubs, Power Stop Cross Drilled & Slotted Rotors w/HD Towing Pads & Stainless Steel Brake Lines...Lots of towing.(13,000 lb 33' Toyhauler & 21' Ski Boat). 102,000 mi.
So. Cal. Fireman
IAFF Local 2342
Other Rides:
2011 Jeep Grand Cherokee Laredo "X" 4X4 HEMI V8
2010 HD Road King Classic
1990 Mustang LX 5.0 Sport, 5spd., 25th Anniversary
Road Course Ready!!!
Powerstrokin400 is offline   Reply With Quote
Old 01-10-2013, 09:04 PM   #25 (permalink)
badbart's Avatar
I agree. For a lot less than $65K I believe I can make a lot of RELIABLE power and torque. $65,000.00?!? Really? That is ridiculous when you really think about it. And next year the'll be $70K, and after that, $75K....it never stops! In this day, what with the economy like it is, houses have sold for less. The real sad thing is, when you drive that $65K truck off the lot it's worth what, $45K? Folks around here can't give away a 6.0. Everyone's afraid of them. 6.4's not a lot better. And now the 6.7's are freaking everyone out over the water in the fuel system. It may be the best truck in the world. Get a little water in the fuel pump....cha-ching!!! $12 grand!!! No thanks. I'll keep my 7.3.
1997 F350 XLT Crew Cab Dually, 7.3 Powerstroke, 4:10 limited slip, K&N Air Filter, MBRP 4" Turbo back w/muffler, Edge programmer, Billet torque converter, Monster tranny cooler.
2004 Cadillac CTS V 5.7 LS6, Tremec 6 speed,
K&N Cold Air, Magnaflow Exhaust, MSD Ignition,
LS7 clutch, Getrag 3:73 posi-trac, 377 RWHP
badbart is offline   Reply With Quote
Old 01-11-2013, 03:17 PM   #26 (permalink)
tfunk88's Avatar
If your 7.3 is putting out 400hp and 850lb-ft of torque, it is far from stock, correct? I have a 6.4 that is putting out about 500hp and 1100lb-ft of torque. All I've done is a DPF delete and a tuner. And my truck is way more relaible than it was simply because of that.
While you may not have met many people who like their 6.4's, my experience has been the opposite. I love MY trucks, and almost every person I've met has said their's is awesome.
I've had 3 of them, and have loved every one. The interior is light years beyond the model year 2007 and prior trucks. And although the fuel mileage is not amazing, it is not bad IF you drive in a reasonable manner. I have had 3 different '08 F450's. The first 2 were automatic 4.30 axle trucks. Both of those averaged 12.5 to 13 mpg combined, about 16 highway if I kept it around 65. I now have a manual transmission truck with 4.88 axle. It got 13-13.5mpg combined and 15mpg at 60-65mph highway. After delete it gets almost 15mpg avg and 17mpg if I go 60 on the highway. The reason it is not so good on the highway is higher speeds create really high revs with that 4.88 axle. Only "engine" problems I have experienced with my trucks is a radiator with the first one and a coolant hose with the second. My second truck DID have the engine replaced due to EGR failure by the previous owner. No issues for me with my current truck, nor were there many for the previous owner from the warranty history report.
Knucklehead Bald Guy
2008 F450 Lariat 4x4 6-spd 4.88's
tfunk88 is offline   Reply With Quote
